Question about Watches
Watch (fossil blue)#ch2334-340406 from 2004 /it need a new seal &band ,can?you help me .
  • mudlad2 Jul 02, 2008
    that"s band/two tone golg &silver.can?,you help me at this time.
  • 3 Answers
SOURCE: watch band
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
1 push pin like you use on bulletin boards with a plastic head
1 small hammer like a tack hammer
1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
1 small block of wood
Try to pick a well lit table in a room where you will not be interrupted.
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
Posted on Dec 31, 2007
SOURCE: How to remove links from Fossil metal band?
I've had a Fossil before, but forgot how easy it is. Thanks for the refresher.
Posted on Jan 14, 2008
  • 2334 Answers
SOURCE: Trouble sizing Fossil Watch CH-2506
Those arrows inside of the watch band are showing direction for pins or clips to come out. If you have two arrows in opposite directions on one link, that means there are two pins or clips and each one must be extracted from arrow pointing side.
If there is only one arrow on the link- there is only one clip or pin and must be extracted the arrow pointing way.
Some watch bands are held together by very specificly made clips or pins. In this case you will need a special tool to extract them.
Posted on Jan 02, 2009
SOURCE: Watch Too Small
Extra links for your Fossil watch can be ordered by calling Metro Service Center at (800) 842-8621.
For all watches we offer up to two additional links. There is a $4 shipping & handling charge for all link orders. If more than two links are needed, you will be charged $3 for each additional link requested.
Please note that each additional link adds approximately  inch to the watchband. Link quantities are limited and are not guaranteed to be in stock.
Posted on Jan 06, 2009
  • 2334 Answers
SOURCE: remove links from fossil metal band
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 07, 2009
I need a replacement band for a fossil watch number 741010; I see a number on the band of 7413500. Could you help me find a replacement band?
On the back of the watch should also be a 6 digit code consisting of 2 letters and 4 numbers. For instance CH3000.
With that code you should be ablte find your strap here:
Oct 17, 2017 | Fossil Watches
Where can I get extra links for the band?
Moto 360 - Extra links for metal watch band - Motorola Support,9141
Your metal watch band can be expanded by adding links. The small gray envelope inside the watch box (see image below) contains four extra metal links.
Order Links & Bands - Fossil
Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
Parts Archives - Citizen Watch - English (US)
Dec 25, 2015 | Watches
Hello, where could I buy, Fossil CE1000 BAND repair parts?
Can't, new watch time or at least new band time
Oct 12, 2012 | Fossil CE1000 Watch
I have a fossil watch which does not fit, i need another clamp
Fossil Links & Bands
Go to "", go to the bottom of the page and you will see a
menu, click on "customer care", and then look under "Product Info" on
the left and you will see "0rdering links and bands"
Mar 31, 2011 | Fossil F2 Dress watch #ES1149 Watch for...
Would you happen to have a watch band pin (link that attaches band directly to the watch casing) for a Fossil Blue Model AM-3515? Great difficulty locating one of these. Thanks for any help on this.
mcdevito75 here, This pin is called a spring bar, while I have many of these I would need the watch to match up the spring bar with the caseing. Best Bet, see a small watch repair shop in your area. Approx. Cost, $5.00 plus install.
Aug 18, 2010 | Fossil Watches
Ihave a fossil blue watch, and need links for the band. where can I locate some?
Contact Fossil customer care and they should be able to supply them. Here is their web address:
Aug 01, 2010 | Fossil Watches
The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
Jul 06, 2010 | Fossil Watches
2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
Dec 08, 2008 | Fossil University of Oklahoma LI2282 Sport...
I need to replace a fossil watch band
call foleys or dillards and ask for the number to the company
and thy can assist you
Jan 06, 2008 | Fossil CH2331 Wrist Watch
Watches Logo
170 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
