Question about Panasonic Televison & Video
I have a panasonic dvd recorder modol dmr-e30 when i load the dvd i get the error message u11 how can i resolve this problem.
  • Jimmy Velez POnce
    Jimmy Velez POnce May 14, 2014
    que significa U11 en un dvd panasonic q sale error y no puede leer el contenido del disco
  • Jimmy Velez POnce
    Panasonic DMR-T3040P, sale error al ingresar un cd dvd, no lo lee y sale ese error, cual es la solucion.
Has anyone found a solution? I was recording movies everyday and then it stopped and says U11. I am using the same discs as before.
Posted on Aug 02, 2010
    Sergeant:
    Champion:
  • 417 Answers
ITS DEPENDS ON WHAT DISC YOUR USING SOME ONLY TAKE DVD+R SOME TAKE DVD-R AND SOME TAKE BOTH DVD+R DVD-R
Posted on Jul 02, 2008
  • dmarklynn Feb 13, 2011
    How can you tell if my DMR-E30 will take only DVD ???? Obviously it will not work on Memorex DVD-R ... but my machine says DVD-RAM/ DVD -R recording right on it ??
Tgo un dvd panasonic y cuando lee del disco interno funciona normalmente pero cuando ingreso un cd dvd me sale error U 11, como puedo solucionar ese problema y aque se debe...
Posted on May 14, 2014
Always get a U11 code when using blank dvd-r to record
You could try using a DVD lens cleaner (wet or dry type, whichever is available; but it MUST be the manufacturer's recommended DVD lens cleaner (or suitable equivalent) - do not use CD/DVD generic cleaners, they might be cheaper, but these do not work and may damage the unit).
If after following the directions on the pack, the recorder still shows U11, then the drive is probably on its way out. Considering the cost of a new DVD-RAM drive is around $300 or so, plus labour (if applicable), it may not be economical in the long term.
Nevertheless, try cleaning the laser lens (either with the DVD cleaner discs), see how you go. I usually try to avoid opening drive units up in cases of cleaning, however, I have found short bursts of compressed air through the drive from front to back usually solves most dust-related problems.
Feb 13, 2011 | Panasonic DMR-E30 DVD Recorder
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
How to convert my Panasonic DMR -E30 dvd recorder from uk region to multi region format
Turn On player with no disc inserted
While pressing Shift on the remote press Setup
Press Enter twice
Move the cursor to Other
Enter the appropriate four-digit region setting, beginning with 000
Press Enter
Press Return twice
Switch unit Off for at least 3 seconds
and here are some other HACKS for your players
like Macrovision bypass ISCSI BAYPASS ETC
http://www.videohelp.com/dvdhacks/panasonic-dmr-e30/1585
Jan 17, 2008 | Panasonic DMR-E30 DVD Recorder
Panasonic DVD recorder #DMR-EH65. It will accept a blank dvd then go into read,I can hear the lens assembly go back and fort several times,then it says disc error.Did the lens life expire?
Hello timmy: The recording process on the dvd recorder side is done is done by a seperate lens from the playback, so there could be something wrong with the writable side of the optical assembly, another thing to consider trying is the cleaning disc if you haven't tried this, another brand of blank disc and finally a firmware update is available from panasonic for the specific model you have, I don't know if you have updated it but here is the overall description: DMR-EH55 DVD Recorder Firmware Update
  • Version UP-317
  • Compatible Models DMR-EH55S
  • Issues Addressed Issues Addressed
    1. Corrects DVD Recorder hang-up or freezing during DVD playback caused by connection to Scientific Atlanta cable box model # 3250.
    2. Resolves U71 error message caused by HDMI connection to Philips TV.
    3. Improves DVD-Video playback of DVD+RW discs.
    4. Prevents DVD Recorder from turning on Panasonic TV's power by HDAVI control (EZ Sync) when connected with HDMI at completion of copying or finalizing.
    5. Resolves SET CLOCK MANUALLY tab being grayed out after a power failure.
I hope this is helpful and the update is available from panasonic.com, all you need is to type the model number in the search windows after you click the support option. Thanks!
Jul 12, 2010 | Panasonic DMRES20D DVD Recorder
Panasonic DMR-E30 with U99 fault
Saludos : Yo tenia el mismo problema. Mi dvd DMR-E30 tenia el
mismo problema . Codigo U99 . Y no funsionaba nada.
Entre a la pagina de soportes de Panasonic y baje el Firmware.
Luego lo grabe en un cd ,el cd lo coloque en la dvd y la dvd se actualiso automaticamente. La dvd funciona perfectamente tanto
con DVD-RAM como con DVD-R. Esta solucion la saque de esta
misma pagina fixya . Gracias Fixya. Att. LACF
Jun 29, 2008 | Panasonic DMR-E30 DVD Recorder
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
U11 Error and Clicking
hi i try to this,but nothing still the same!!!!
Oct 28, 2007 | Panasonic DMR-E30 DVD Recorder
Dmr e85h
http://forum.ecoustics.com/bbs/messages/2/356391.html
This forum has a couple of solutions for resolving this error message. I personally have only had the u99 error with my E85H unit and resolved it with a firmware upgrade. It has worked great for the last 3 years.
Sep 18, 2007 | Panasonic DMRE85HEBSM DVD Recorder
Televison & Video Logo
1,076 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
