Question about Mercury KVM800M Motherboard
My computer have no sound output
My computer before work by windows me. after that when i am install windows xp sound is not recover now iam need from you help to me about solve this provlem.
  • Anonymous Mar 28, 2009
    driver sound msi 7507 i need it
  • 983 Answers
I think the audio driver is not installed ...
try installing the audio driver ...
to hear sound audio codecs are required so just install the audio driver given in the manufacture cd while the purchase of the PC or motherboard ...
if already installed then go to control panel > sound & audio devices there you check the audio is it installed or not if it is installed then it will show the volume panel ... if not it will show you no audio device available ...
then you must install the audio driver ... if installed then also facing this problem then go to control panel >system>device manager>check the sound devices uninstall them & then reinstall the audio driver ...
this must solve your problem ...
if still problem persists then check the speakers & wires correctly ...
& check if it inserted to the audio jack only or not ..
check in audio panel is the volume is muted...
if you still persist the same problem then there may be some problem in the port or loose contact check it ...
any doubts you can reply me
i am always here to assist you
thank you
dnt forget to rate my solution
Posted on Jul 02, 2008
I got this laptop from my uncle everthing was working good,it had vista on it, but since iam a gamer i installed sp3 xp on it, and now i can't install the Sound, so..any help`?
Access the manufacturer's web-site:
and enter the model-number of the computer, and do a search.
Select "download", and select "Windows XP", and select the "audio" device-driver.
Download it, and install it.
Mar 09, 2011 | HP (153147-001) Sound Card
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Dec 29, 2010 | Princeton Digital VL173 Monitor
I installed a windows xp recently and when iam trying to install real tech sound driver its showing an error :software you are trying to install for this hardware AC'97'audio for VIA(R) audio controller...
You have to download the drivers again and then install it again and don't let your computer find the drivers at the time of installation, but you give the path and then install it.
Your problem might be solved
Please rate me if this solution works for you
Thanks......Have a great time
Jul 02, 2010 | Computers & Internet
No sounds output
well you need to install the sound card driver to get sound out from the computer, I can get you the right one if you send me the brand and model. also the windows your using? 2000? xp? vista? other?
May 26, 2009 | Computers & Internet
I have problem with audio and video sound output in my toshiba pc
Hey there, This is a link to a sound Driver from
This is for Windows XP only.
Hope it helps.
Jan 31, 2009 | Toshiba Computers & Internet
"You may be a victim of software counterfeiting. This copy of Windows did not pass genuine Windows validation"
your using pirated software. it will work no worries about that. you can not update it anymore. to update and be safe from internet threats you need to install genuine Windows XP.
Dec 29, 2008 | Microsoft Windows XP Professional With...
Toshiba m200 iam relese the vista &install the xp
you have to make a clean install and not upgrade,boot your pc from the xp cd installer.make sure that your XP installer cd is not damage, try it on another pc and see if it works
Oct 14, 2008 | Toshiba Satellite A135-S4527 Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
you have to use a standard windows start up disk with cd rom support like win 98 works well so the computer will recognize a older version then insert it and boot the computer with the operating system that u want to install but be advised if you have a warranty on the machine you will void the waranty i found out the hard way i had xp on my toshiba laptop and i put windows me on it couple of months later i had a cd rom issue and sent it to the manufacture and found out that the waranty was voided because i put a different operating system on the machine
Aug 14, 2008 | Computers & Internet
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Mercury KVM800M Motherboard Logo
596 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
