FixYa.com
Tags:
Eclipse CD5405
Subwoofer Output Not Working...
posted by lilsnoopy778 on Jul 02, 2008
I've had this deck for about a year, everything has worked well. I have subs hooked up to the RCA sub output connectors to an amp and 2 10 inch subwoofers.
I removed my subs to put somthing in my car, put the subs back and now I hardly get anything out of the subs. I took the subs and amp into a shop and verified they are working perfectly. I even hooked my ipod up to the amp and it worked fine. The amp powers up and everything, and only a little bass comes out.
The shop said it is probably the deck that is the issue, has anyone ever had this issue? Everything works find except for that! It sux!
Thanks for any help!
I recently changed the head units in my pathfinder and the subs were working before. I have two Kicker 12'' CVR and a performance teknique 1200 watt 2 channel amp. I had a kenwood head unit but then purchased the Eclipse head unit. I switched RCA cables and my amp isnt blown because i checked with another amp. I can hear the subs when i switch the amp from LPF to HPF, but the subs wont play. there is a amp turn on wire and a amplifier ground wire,...i dont have them hooked anymore, but could that be why? and now i dont have them connected and its still the same results.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 02, 2008
Not Rated (0)
johnnyc85
Rank:Wiz Wiz
Rating: 84%, 56 votes
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these In Dash Receivers problems?
In Dash Receivers
cars
when i put my key in the... Answer This...
Eclipse CD5405
Problem with Eclipse CD5405
Head unit locked up after... Answer This...
Eclipse CD5405
stereo lock up
I have a eclipse CD5405 that is... Answer This...
Eclipse CD5405
stereo locked up
The other day was working on... Answer This...
Eclipse CD5405
need to reboot stereo
truck was loaned to a buddy,... Answer This...
Repair Service
Find In Dash Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
