SOURCE: instructins to use muvo
Go the the Home page of Creative.com and navigate to the location for the installation software (came with player within its package). Therein you will find an expanded user manual.
SOURCE: fill system error in muvo v 200 usb
i have an problem as i/o errror be connecting with usb port
SOURCE: file system error
It can also be caused by transferring DRM (Digital Rights Management)
encoded media files via the drag and drop method. It is recommended that
you use the drag and drop method to transfer audio files that are not encoded
with DRM. If in doubt, use either Creative MediaSource Organizer or Windows
Media Player to transfer your files.
To resolve this difficulty, we recommend that you format the player and
transfer the content again. You can also download and install the latest
firmware, and select the Format Data Area option during firmware update.
To format a MuVo player, connect it to a USB port on your PC. Open the Windows
Explorer, and locate the Removable Drive listing and right
click on it. Select Format, and choose FAT instead of FAT32 or NTFS. After
the formatting is complete, make sure that you stop your player before disconnecting
it from your PC (see above)
To update or reload the firmware for a MuVo player, select the model of
your player from below.
This firmware upgrade only works with Creative MuVo Micro N200 players.
Do not install this upgrade to other players.
You will lose all content in your player when you install the firmware.
Back up any audio or data files in your player to your computer before
upgrading the firmware.
Before installing the firmware, please complete the following procedures:
To install the firmware for your player, follow the procedures below:
SOURCE: Creative Muvo V100 is not working
My MuVo was having problems until I installed the latest firmware. The
last firmware release was in July 2007. If you haven't updated the
player's firmware since then, try downloading it and installing Creative MuVo V100 Firmware 1.05.01.
If you can't get your computer to even recognize the player anymore, you could try reinstalling the Creative Mass Storage Driver 1.07.00.250.
SOURCE: muvo v100 no music
I've had the same issues with my MuVo V100. I've formatted it,re-installed firmware and used Creative's MP3 Recovery Tool,too.
The only way to get the player recognising " music/ folders" and playing them is to use the 'sync' option in Windows Media Player 11.
Although this is a very long process, it has worked for me. Having said this,it does take a while to find them in the actual player. As the menu appears different??
This is going to be the last time I buy a Creative product.
