Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
'grinding too long then trips out - Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
  • jpradice Jul 02, 2008
Youn want to charge me $10.00. for you Fix. But you you want me to tell you for free.
Posted on Jul 02, 2008
My saeco royal cappuccino grinder tripping power
depending on the model i think the bushes or the motor has failed, grinding could also be the drum, with the motor disconnected (belt removed ) move the drum round by hand if its free and no stiffness then the motor would be at fault. motors for most machines are replaceable, it will have a part number on the motor, they fit them to various machines. if its the drum then it will be the barings and these you will need to buy a replacment kit consists of bearings and seals, there are meany videos on youtube to help people on how to replace the bearings.
Jun 03, 2017 | Washing Machines
Bunn g3 commercial grinder
Humm, G-3 grinders. Okay what common problems I've come across:
* Wrong setting for grind on label. Usually means worn out grinder burrs. But this does not happen often unless you are using it to grind commercial amounts of coffee? It's a retail level grinder meant to be user friendly and simple to use. Say grind a bag of beans once every 10 mins or so even with customers lined up to grind there own. Running a G-3 constantly is usually done by upcoming coffee vendors whom are using it for small flavored bean batches. But expect the burr plates to only last 3 to 6 months. We used to change it every month till the boss bought a bigger pro grinder. (whew!)
* Out of calibration (for grind) This usually happens as soon as it's installed. Either the grinder got banged (Dropped?) around or the lock nut was not tighten down. If caught quickly then it's a simple adjustment. Left unchecked will wear out the burrs or crack the plate.
* Trips out breaker. This is common at retail stores as it's located in a shelf rack that really does not have the required outlets. Many times there is a brewer(s) connected to the same line. It only trips out when one or both brewers are heating and the grinder is running a very fine grind.
* Trips out breaker when grinding espresso or very fine grinds. Worn burrs or slim chance the grinder was miss calibrated (but you would catch this when first installed)
* Shocks the customer. Dry climates or heavy air conditioning will build up static electricity at the chute. There usually a small chain attached to the chute to prevent this. Attach a SHORT metal chain or thin cable to the metal case of the grinder and add a metal clip to attach to the coffee bag. Many use a chain and clip just short enough to keep the bag positioned under the chute. Note many coffee bags come with bag clips. Just make sure the clip and chain can't get stuck in the grinder.
* Not working. This is usually the on/off switch as it gets beat up the most. There is sometimes a safety micro switch under the chute to sense if there is a bag there. I've found may have been defeated.
* No power, check cord, breaker (GFRI) outlet, Plug prongs if broken off or bent.
* power but no motor hum. Tripped thermal breaker (usually a red button on side or back. Some models may have it inside on the motor itself. Call for service to check.
* Turns on but loud hum (may be hot too). Burrs stuck. This could be from adjusting grinder while grinding beans and adjusting to a fine setting. Grinding finer slows down the beans feeding the burrs. Large settings flood the burrs with a lot of beans. Adjustments are usually done when the grinder hopper is completely empty. If loaded and turned down from coarse to fine grind the beans already in the burrs get crushed and stuck between the plates thus locking them in. It may be possible to clear the hopper and open up the grinder to its coarsest setting to jog out the crushed beans. Otherwise call for service to have the burrs cleared manually.
*Finally check with your vendor if your still having problems.
Aloha! ukeboy57
Mar 22, 2017 | Bunn Coffee Makers & Espresso Machines
Motor hums, water leaking out from under toilet,will not grind
If it is not tripping the GFCI Outlet or tripping a breaker, than more than likely the impeller is stuck. You will have to remove it to find out.
Nov 03, 2013 | Star Water Systems PowerFlush Sewage...
Coffee maker trips gfi
Try it in a different outlet (one that is not a GFI). It could be the GFI is bad
Jan 28, 2013 | Solis Master 5000 Espresso Machine
Makes grinding sound during wash cycle
Everything that grinds is saying.........stop using me and find out whats wrong before you use me again.
Could be gearbox or something stuck inside the machine.
Oct 24, 2009 | Maytag Performa PAV3200
Solis Master 5000 trips GFI outlet during brewing.
It sounds like the power filter(capacitor) located under the pump is damaged.
Oct 23, 2009 | Coffee Makers & Espresso Machines
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
26 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
