Question about Whirlpool Microwave Ovens
Dont know how to use convec oven on model vt 256
    Sergeant:
  • 287 Answers
I assume this is a Whirlpool microwave
try HERE
There is a manual and quick guide link onthis page
Posted on Jul 02, 2008
2 Suggested Answers
MicrowaveSvc
  • 9086 Answers
SOURCE: microwave model vt 256
You can download your unit's IFU (instructions) here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Carousal II Micro/Convec. Model R-9H84
It is there! Go to appliancepartspros.com and check out the plans for the location of all parts. Then get to it.
Sep 06, 2015 | Sharp Microwave Ovens
WHIRLPOOL VT 256 serivce manual
the service manual is difficult to find however you must find to www.manualsfactory.com or www.pdfservicemanual.com
God bless you
Sep 07, 2012 | Amana Microwave Ovens
How hard is it to change a turntable motor on a micro/convec oven?
Depending on the model, it's not usually that hard. Attacking from underneath, what you will find on many models is atht there is a panel at the bottom that ALMOST looks like you can remove it, but it is ni fact solid and the "panel" is in fact part of the bottom of the machine, linked to it by a few bits of solid metal where most of it is free. Personally, I just snip through the bits of metal. and either make up a screw plate to hold it in place later or (If you are absolutely sure no prying fingers are getting near it) leave the thing off (I DO NOT advise you to do that though).
Once you have access then the motor is usually held in place by 3 or 4 screws and has a convenient plug and socket that you can pull and re-plug the new unit.
Jul 07, 2011 | Sharp R-930AK Convection/Microwave Oven
My sharp microwave/convection oven come on, clock counts down but it does not heat nor does the turntable turn. About a week ago the breaker was tripped by it I think but it was fine until now. It doesn't...
It sounds like one of the door micro switches is bad. There are three micro switches typically. A primary interlock, a secondary interlock and a monitor switch. It is most likely the primary or secondary interlock switch. You may need to take your switches to a professional appliance shop to determine which one is bad.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 22, 2011 | Sharp R-930AK Convection/Microwave Oven
My Sylvania micro/convec oven was installed in my RV last year but has never worked correctly. It runs long after the beeping ends and the glass sometimes gets a rainbow haze across the glass. Is this...
With this oven being a combi ventilation and extraction is important, the haze across the plate is
surplus heat, It not cooking but what you hear is the extraction fan running until the oven cavity has cooled down
Feb 12, 2010 | Sharp R-353 Microwave Oven
After Elec outage, Sharp Carousel 2 Mwave/Convec flashes 8's
If you've reset it by unplugging it for a few minutes, the next step would be to see if any moisture has been deposited on it.
This is best accomplished by removing the cover and looking at the circuit board to see if there are any rough and dull white, gray or green deposits.
(There will be a normal green coating on the board, but it is shiny and smooth).
If so, they may be cleaned off with a soft brush (like a tooth brush) or a Q-tip lightly dampened with high grade alcohol, such as 70% or better isopropyl.
We have an incomplete service manual for it here. It will be helpful, but again, it is not complete.
Also see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
One can also unplug the keypad strip (see photo below) and use a soft eraser to gently scrub both sides of the end of the strip and any spots on the boar. Then plug it back in and try it again.
If it still does not work, then the keypad has failed. Sadly, they are no longer available, so the oven would have to be retired. They were great performers...
Jul 09, 2009 | Sharp R-230 Microwave Oven
I dont know how to use my microwave oven for cooking food.
i dont know how to set temperature and cook in microwave ovan
Jan 31, 2009 | LG LMH1017 Convection Microwave Oven
Micro/convection stops every minute
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Nov 21, 2008 | Sharp R-1480 Microwave Oven
Microwave model vt 256
Jul 02, 2008 | Microwave Ovens
Microwave Ovens Logo
124 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
