Question about Samsung Televison & Video
Just hooked up my new tv to the hdtv cable box and cannot adjust the size of the picture
  • 51 Answers
Check the aspect ,format or hd zoom keys on the remotes depending tv model and cable box models.in cable box its the # key under number nine on tvs will say aspect format or size.
Posted on Jul 02, 2008
How do I enlarge picture
Picture size can be adjusted by using either the TV or cable box remote controls. Just access the menu on either (sometimes both have it), and look for the option to change the picture size.
Oct 21, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Can i set my picture size from the tv buttons on my toshiba theatrewide hd tv
format or screen size is only if it has it adjusted with the button on the original remote or via a cable box if it has it.
Oct 14, 2012 | Toshiba TheaterWide 52HM84 52" Rear...
We just got a new cable box and now the Picture works but no sound. The volume is not muted on the tv or cable box. We've tried connecting the cable box three different ways and still get the same...
Does say a dvd player give sound when connected to the same input? If you have determined that the source is good and the speakers are turned on in the menu then I would replace the main board.
Sep 08, 2011 | Sony KDE-50XS955 50 in. Plasma HDTV
My tv's picture does not cover the entire size of the tv. The picture that shows is the size of a square and my television is a rectangular size. How do I widen the picture?
there should be a button on your remote that adjusts the picture to fit your screen. They have that on most tv's. Are you using a cable box? your cable box also has settings depending on what your using. 1080i, 720p? does it do the same thing with a dvd player or game console hooked up?
Mar 02, 2011 | Sylvania LC370SL8 37 in. LCD Television
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
I can't switch the picture size. When i hit the pic size button, it tells me it's not available. I tried changing the pic size with the tv/video input on our dvd, but it won't change it when its on out hd...
defective hd cable box is possible but each unit has its own picture size adjustment. use your cable box remote and change size there. use tv remote to adjust tv size to auto. dvd the same thing
Nov 10, 2009 | Toshiba 57H82 57" Rear Projection...
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Picture size to wide
I am not convinced that the tv is at fault. The answer may be in the menus of the set top box, if you are using one. If you have cable then put the cable wire directly into the TV to see if the TV is at fault or not. If you have satellite then consider calling your provider to ask if they have a zoom function setting in the box.
Mar 26, 2008 | Televison & Video
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Panasonic PT-47WX53 Horizontal Picture Size
Normally, when I see this problem in the customer's home, I find the main culprit to be the cable or satelite receiver box. The remote for the cable box may have a button on it to change the format or picture size. You may have to go into the menu of the cable box to change the format setting. Hope this helps.
Apr 28, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
Henry  Thomas
Henry Thomas
