Question about NetGear WGR614 Wireless Router
No connectivity I'm trying since yesterday to connect to the internet with my wireless router and the g card. It is frustraiting!!! What sould I do. It tells me wireless connection 11(subaru) 36 mbps exelent signal strengh limited or no connectivity
  • 70 Answers
There is a possibility that the wireless settings are not similar for the wireless adapter and the router. You can check the wireless settings of the router from its setup page.
1) Connect a computer to the router using a wire
2) Open an Internet browser and access (or if you changed it, use the IP you have set)
3) If it asks for Username and password, defaults are admin for User name, password for Password
4) find the wireless portion and take note of the SSID, channel, Security type and the password
5) Once you have all that, set the wireless settings on your g card.
There are some g cards that has their own wireless utility. If that is the case, you need to open the utility for the G card and set the wireless settings there.
If that does not work, you can try removing all the preferred network and reconnect. If a wireless security key is needed, you have to correctly enter that to fix this problem.
Posted on Jul 02, 2008
My son watch youtube videos on innotab max yesterday it just stop working it seems unable to load the videos it just has 2 round arrows going round
It must be due to slow internet connection. If you have connected the tab with a wireless router, try with the following steps,
1.)Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from before and after following these steps.
Jan 28, 2015 | YouTube Computers & Internet
N600 error 651. My n600 is hardwired to my desktop. my wireless internet connections work fine. The desktop connects to the router no problem, but will not connect to internet. I used the pc yesterday...
If the wireless connects to the internet then the router is fine. Look at re setting the connection on the PC. You might want to check for an update on the driver for your network interface card first.
Feb 20, 2014 | Computers & Internet
Linksys router not recognize internet
Make sure your router's WAN port is set to dynamic IP. If the light on the front doesn't glow/blink for the WAN port, try a different cable. If a different cable doesn't work it's probably toast. :( This problem appears to be directly linked to the relationship between the WAN port and the modem. Given that the devices can connect to the router, but not internet, it has to be the WAN. Sometimes if the modem goes out it will send too much voltage through to the router and fry the WAN. Had that happen to my parents router. If the above doesn't "fix ya" then try a different router.
Worst case, you might have to put a wireless card in your PC and bridge the modem (wired connection) to the wireless card and broadcast for your wireless devices. At least until you get a new router.
Aug 02, 2013 | Dell Computers & Internet
Worked fine up till yesterday now wireless wont work
The wireless cards in the computers need to be configured with the router's wireless settings so the computers can connect to the wireless router.
Resetting the wireless router back to the factory defaults will not let the computers connect to the wireless router without configuring the network card in the computers with the router's wireless settings.
I suggest you configure your wireless router with encryption settings to prevent unauthorized persons accessing your wireless network and Internet connection and your computers.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
Mar 01, 2012 | Computers & Internet
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
Laptops connect to router but still cannot get on internet
It's just a wireless interference problem. All you need to do is change the wireless channel of your router. Login to the router's admin page and look for wireless channel under the WIRELESS tab. Change it to channel 11 and save the settings. That should solve your problem. You can play around with different channels and check which one is the best for your environment. Good Luck!
May 07, 2009 | Linksys Wireless-G WRT54G Router
How do i use my built in wireless connection to connect to the internet,please.
make sure that your wireless or wifi light is on,you may try to press Fn and F2 at the same time to enable or swith on wireless..if wifi is already on,try going to start >> control panel >> network connections,go to wireless network connection and double click it, it will give you a list of wireless network,or right click and then "view available wireless network", if you get an error that windows cannot configure wireless connection,go to start >> all programs >> loo for either dell wlan utility or intel pro wireless, by opening that app,it will also search for wireless network in range,just double click on the network name where you want to connect and you sould be connected provided that "wireless network" doesnt have encryption like wpa or wep key..if your connecting to your home network,you should have wireless router at home and wireless is enabled on the router.
Oct 05, 2008 | Dell Inspiron E1705 Notebook
Can connect through Ethernet but not through Wireless
what is the operating system of your computer and what is the wireless card that it is using?
Jul 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
ADSL Wireless Router
Firstly you may simply have corrupt cookies preventing your internet connection, so go to tools in internet explorer and select internet options and delete temporary internet files and cookies. If you are able check that the network card is working by typing your routers ip address in your web browser and look at DHCP clients and see if your problem pc's ip address is shown. It could simply be that your pc's ip address lease time as ran out, so go to start>run and type ipcongig /flushdns, this should clear the network card settings. Restart pc and and try connecting again.
Jun 27, 2007 | Belkin (F5D6230-3) Wireless Router
NetGear WGR614 Wireless Router Logo
133 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
