Question about Goodman Heating & Cooling
I have outdoor Goodman compressing unit, model #cple24-1c. The breaker tripped and I was told to take out the connector located in the box by the unit and reset the breaker. The breaker did not trip again. I was told to replace the electrical whip because we had alot of rain recently. Is this right?
    Scholar:
  • 104 Answers
No, the electrical whip should be able to handle all weather, moisture, and even immersion. The only reason to replace a whip is if it has suffered some kind of physical damage. I recomend keeping an eye on it and if it trips again, have a pro come check out the system because something is not right inside the unit.
Posted on Jul 02, 2008
  • Chris Lyon
    Chris Lyon Jul 04, 2008
    If you would kindly rate my solution as Fix-Ya.
Goodman CKl30 1d how can I tell if the outside box has tripped off?
look for red reset button.look where low voltage wiring comes in to unit.listen for buzz or hum from outdoor unit when thermostat is calling for heat.if heard,could be high voltage fuse or tripped breaker in panel next to unit.if not cautious electrocution can occur.suggest local service company for diagnosis.
USE EXTREME CAUTION WHEN EXAMINING high voltage wiring.
HIGH VOLTAGE SUPPLY. Open high voltage control box and turn off power by pulling dissconnect or switching off breaker.
Sep 08, 2013 | Goodman CLQ36AR49 Air Conditioner
Outside unit will not come on unit is a heatpump model
Common problems:
1. Fuses blown: Located near the outdoor unit, usually in a small box mounted on the side of the house. The electrical line will go in to the outdoor unit from this fuse box. Usually has a door to flip up or sideways, pull a cartridge out and the fuses will be behind the cartridge. If you don't have an ohm meter to check them, just take them to the nearest hardware store they can probably check them for you, or just change them both.
2. Circuit breakers tripped: Located usually in the main breaker box in the house or outside by your elec. meter. If breakers are tripped they will be noticeably different than other breakers. To reset, you have to pull them all the way over and back up. If they are reset , they will remain in the up position and look like the rest of the breakers.
3. Low on refrigerant: Most heat pumps have low pressure switches that will shut the unit down if the unit is low on refrigerant. If you don't have knowledge and tools to check refrigerant, this is when you will have to call a technician. If you do have the proper tools, I can step you through refrig. check.
*also, while you are at it, check the outdoor coil and make sure it is not dirty . On a Ruud you will have to look under and through the outdoor fins of the case. If you see a lot of dirt under the fins, your coil is dirty and you will need to wash it out good with a hose and sprayer. TURN POWER OFF BEFORE SERVICING. Hope this solve your problem. Mark
Jul 12, 2011 | Ruud UAKA037 Air Conditioner
MY OUTDOOR A/C WENT OFF! BUT THE ONE INTHE INSIDE STILL WORKS ,BUT IT IS STILL HOT. WHAT IS THE PROMBLEM???
In most cases the outside unit is on a seperate breaker than the inside unit. Check your breaker box to see if any of the 220 volt breakers are tripped out. There may also be fuses or a breaker at the unit outside.
Sep 11, 2010 | Goodman CKL60AR60 Air Conditioner
Where is the fuse box?
Does the indoor unit run?
It sounds like you're looking in the right place. Check your power panel for a tripped circuit breaker (maybe more than one) or if the home is older, it may have fuses. It's possible that the outdoor disconnect also has fuses but that's not as likely. You can check around the outdoor unit and see if you smell anything burnt.
You can aso turn off the unit at the thermostat, wait a few minutes and see if the unit starts back up, but check the items listed above first.
Jul 17, 2010 | Goodman CKL42AR42 Air Conditioner
Air conditioner just conked out;only 3 yrs old
Is the indoor unit operating? If no turn the fan from auto to on at thermostat. If the fan comes on, that is a sign that you have 24volts
present on thermostat side.
Turn AC unit off outside,turn the thermostat as low as it will go. Open the electrical panel to the outdoor unit. There is a contactor located in the unit, push the plastic bar in the middle of contactor. If it pushes
in, you have low voltage wiring problem from the outdoor unit to the
indoor unit.
If you are skilled or know somebody that is with electrical, turn the power back on to the outdoor unit take a non conductive object and
push the contactor in, the unit may start. If it doesnt start,check the
breaker for the ac unit to make sure it is not tripped.
If the breaker is not tripped and the condensor fan comes on and the
compressor does not come on and the breaker does not trip, then it
is very possible that you will need a new capacitor and while you are
at it put in a hard start kit.
This unit according to you, still should have 2 years left on the compressor warranty.
Jun 18, 2010 | Goodman CLQ36AR49 Air Conditioner
The a/c unit outside doesnt come on but the fan inside of the house is blowing, the unit is not cooling the house. I have a goodman unit.
Hi, this is a split system Goodman. With the j36 in the model number, that tells me it is a 3 1/2 ton unit. If the outdoor condensing unit is off and doing nothing at all, no fan on top running, no compressor or anything, it sounds as though you have lost power to it. The high voltage to the outdoor unit is seperate from the indoor unit. When it is not running, you have only warm air from the indoor unit. Before I have you do anything, go out to the unit. Take a water hose being careful not to bend the fins on the coil, and wash just the coil very good. If its dirty, it can cause the pressures in the system to rise very high and blow a fuse or trip a breaker. When you are done washing it, you should have a electrical box mounted on the wall that feeds power to this unit. First, find your main breaker box to your home. It should be where the meter is. Find it and it will have several different breakers in it. They may or may not be marked. Look for a double - pole 30 to 40 amp breaker that should say a/c, if it was marked. If not, look and touch them, it will be 2 breakers together and feel if they are tripped. If so, turn it off with a hard motion. Then, back on the same way. Watch to see if it holds and does not trip on you. If its ok, go to the outdoor unit. Make sure the thermostat is on auto/cool and turned way down for it to come on. If it was a breaker and its running, more then likely the dirt from coil caused it to over amp and trip. Now, if there is power and breaker is on but still not on, open the box at the unit. It may have a pull out type plug, or breakers. If it has a breaker, turn it off and on like the other. If it doesn't, behind a plastic panel you will have 2- fuses. Turn off power at main box breaker, and remove both fuses. They are cheap, so go get 2 at a hardware store and replace them. You can have them ohmed out to see if one was bad. After installing the new ones and you turn it on, and all is good, that was your problem. May sure you have power to this outside unit. If it was a blown fuse or tripped breaker and this continues to happen, you may have a internal compressor or condenser fan motor problem. Try the things I have said first. This may be the only problem you have. I do this for a living, 33 years and a licensed contractor. Please keep me posted and I will continue to help you if you need me. Let me know after you check everything.
Sincerely,
Shastalaker7 :)
Apr 11, 2010 | Goodman CLJ36AR42 Air Conditioner
Ac unit breaker trips off
First thing to do turn off the breaker in the electrical panel, then open up the AC outdoor unit, including the disconnect box, that should be mounted on the wall near the outdoor unit. Go thru and tighten all of the screws and wire nuts, look for burnt wires, while you are at it.
Turn on the breaker and try again, if it still trips, then we look deeper;
pull the control panel off the outdoor unit and look for the contactor, this is where the power coming into the outdoor unit hooks up to. There will be a set of contacts in the control, check it out and see if the points are badly burnt,
If all off the wire checking still has not helped, it will more than likely be a bad condensor fan motor or a compressor, the compressor is the big black thing in the bottom of the outdoor unit, making sure that all power is turned off, pull the plastic cover off of the side of the compressor, there will be 3 wires, make sure none of them are burnt and touching the metal, if they are, repair the wire and test.
Try this and if you need to know how to troubleshoot to see if it is the fan motor or the compressor, just contact me back.
If this has been helpful, please rate me.
Contact me if I can help you any more.
Sincerely,
Paul
Apr 10, 2010 | Goodman CKL24AR24 Air Conditioner
Goodman ck36-1a not turning on
ok, you have turned the thermostat to the cooling setting? and turned the temp setting down, so the blower comes on.
As far as the outdoor unit, first thing to do is check the breaker in the electrical panel, next check the disconnect box, that should be located on the wall near the outdoor unit.
It will have a breaker or a set of fuses, that need to be checked, if it has fuses, they have to be tested with a ohm meter, and you cannot tell anything about their condition buy looking at them.
Good Luck.
Sincerely,
Paul Gibson
Apr 07, 2010 | Heating & Cooling
Unit will Not turn on
Hello. There is usually a separate circuit breaker in an electrical box near the outdoor component. Chances are it was turned off at that location for the winter. Joe
Apr 03, 2010 | Goodman CLQ36AR49 Air Conditioner
Heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
May 26, 2009 | Goodman CPLE24-1 Air Conditioner
Heating & Cooling Logo
105 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
