Question about RCA OPAL M4001 MP3 Player
Screen reads initializing
Our screen reads initializing and won't clear. It wont boot up and the computer won't reccognize it anymore
  • jkattigger Aug 06, 2008
    I have the same problem PLUS the RCA website link for updated software doesn't work.
  • 8,596 Answers
Reset, double-check that firmware is up to date, and check Recovery Tool from RCA's website
Posted on Jul 06, 2008
Is there a way to get the 32 bit or 64 bit windows XP to install on a dell inspiron 6000 ?
as far as i can find out because windows xp does not exists anymore plus xp does not update anymore according to microsoft.
some new laptops will not allow windows xp to be put on..
if your laptop was xp to start with then it should work.
To specify the boot sequence.
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. ...
  2. Choose to enter BIOS setup. ...
  3. Use the arrow keys to select the BOOT tab. ...
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list..
  5. try and boot your disc this way if it still wont have it then your laptop may not allow it.
Nov 20, 2016 | Dell Computers & Internet
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
How do I safely start my computer? I don't have
If you want to boot into safe mode, then press and hold your "F8 Key" while you computer is booting up this wrong bring you to a screen where you can choose to boot in safe mood.
Jan 26, 2012 | Compaq Computers & Internet
Windows wont start up when computer is turned on, at the bottom of the screen, it just says press f for set up or tab for bios memo, then the screen will be blank with just a cursor blinking
If you are interested in solving the problem more easily and quickly. I think you can try this computer boot up suite, a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Jun 25, 2011 | ASUS Eee PC 1000H Laptop
Laptop not booting up after XP install
Can you press f10 to get to the HP recovery screens?
May 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My computer wont boot past Ai lifestyle screen(initial screen)
Boot from windows CD and after all drivers are loaded it will ask you what you want to do
"Install, repair etc" choose Install and then press the R key for repair and follow instructions from there
Feb 02, 2009 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
RCA Opal Initializing Problem
our firmware went bad.
Just got to the RCA website.
search your make and model
download the firmware.
Then hook you mp3 player to usb device of your computer.
After mp3 is hooked to computer
Install the newly downloaded firmware.
Oct 24, 2008 | RCA OPAL M4001 MP3 Player
Hi please help me with my acer 3003 wont boot
try to power up with power cord only and see if it works. If no lights turn on than your motherboard is dead. If it turns on and nothing happens make sure there is memory installed(RAM). If it turns on and you see windows screen than it shuts off than your operating system needs to be installed again. Also, you can try booting in safe mode by hitting f8 when you initially start your computer and see if it stays on and if it does you have a virus most likely. Good luck.
Aug 18, 2008 | Acer Aspire 3000 Notebook
RCA OPAL M4001 MP3 Player Logo
42 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
