Hi, If your temperature setting is hot, just adjust it to lower temperature by using your remote commander. Unless you have problem with compressor, refrigerant, motor and controller, you should able set your temperature to meet your comfort. A small split type air conditioner commonly will able set the temperature from 16 - 30 deg. C.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
