Question about Umax Astra 4450 Flatbed Scanner
Umax Astra 4450 Flatbed...Scanner link failure
My Astra 4450 Flatbed has been working for 5 years.
It has suddenly stopped working. A message comes up saying .."Scanner link failure. Scanner Test suggests, 1) the power is not on...(but the small green "power on" light up front is ON suggesting that power is going thru).
2) Your scanner is not on before your system starts. (It has NEVER been
essential to power on the scanner before the system starts. I have only
powered it on when necessary to use the scanner whilst my PC is on.)
3) Error message. :"Scanner access failure".....but I have tried another
voltage converter which works well on another scanner. I have also tried
the other scanner's USB and identical leads to my Astra 4450...but to no avail. I notice that the scanners lid light does not come on. Could this be the only problem?? Where can I purchase a new one??
  • 2 more comments
  • utareq Aug 06, 2008
    I can't working this scanner
    I can not Umax Astra 4450 software install in my computer
  • Drexbat21 Feb 15, 2009
    I have the 4400. Also having the same exact problem.
  • thomasbrown Apr 15, 2009
    astra 4400 same problem with newly installed software from umax site.
  • 3 Answers
SOURCE: Umax Astra 2000P Power Supply
You can use any over the counter 12 volt power supply from a DIY or computer shop, just make sure the tip of the
plug is switched to + and the ring is negitive
also that the power supply is rated at about 18
watts or higher
Posted on Aug 10, 2008
SOURCE: driver for Umax AstraNet iA101 for Windows Vista
http://www.nodevice.in/driver/AstraNET_iA_101/get25337.html
http://driverscollection.com/?file_id=1907
http://www.driverfiles.net/Scanners/UMAX/AstraNET-iA101/download/page,sh,28808,139,11,.html
Posted on Nov 29, 2008
SOURCE: Umax Astra 3600 Flatbed scanner driver
http://www.downloadsource.net/17564/UMAX-Scanner-Astra-3600-Driver-Windows-98SE-ME-2000-XP/
there you can find the driver.
Posted on Aug 22, 2009
SOURCE: No driver for Umax Astra 1220U Scanner to use with a Macintosh.
go to: http://forums.macnn.com/82/applications/201141/umax-1220u-scanning-solution-os-x/
Posted on Feb 13, 2010
SOURCE: UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Posted on Mar 20, 2010
Umax astra 4400 driver for Windows 7 (64-bit) Help seash driver
To install driver for Umax Astra 4400/4450 on Windows 7 you need to do the following.
1. Install VueScan from http://www.hamrick.com/ - It is only need it for C:\VueScan\scanner.inf with list of drivers
2. Manually install driver from Umax Astra 3400 - You can follow these instructions to install driver manuallyhttp://pcsupport.about.com/od/fixt [...] dows-7.htm
3. Install Umax Astra 4400/4450 software (VistaScan) for Windows XP - Can be found at http://www.umax.com/download/index.jsp
4. Reboot
5. Now you can scan using VistaScan (C:\VistaScan\Vista32.exe), but only the with flatbed option.
This solution is from Russian forum: http://forum.ixbt.com/topic.cgi?id=13:42660#7.
Oct 23, 2010 | Umax PowerLook III Flatbed Scanner
Driver for windows7
Maybe, It doesn't work because the driver you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D
Aug 07, 2010 | Umax Astra 4400 Flatbed Scanner
I have an Error code 10 on the UMAX Astra 1220P scanner
Have you tried to do system restore in order to fix it? if not you can try find out a solution for error code 10 in this link.
Feb 17, 2010 | Umax Astra 1220P Flatbed Scanner
I cant find umax astra driver any where can u help me
No worries, there is an official site of Umax, and I have pasted the link below, please remember, the below link is for 4400 supported for Win XP.
ftp://199.227.239.190/scanners/vscan/astra4400.exe
If you are using any other operating system then please go to the below link and select your operating system and also select scanner model No.
You will get the download link once you click submit, download and install the drivers.
Cheers
Nov 02, 2009 | Umax Astra 4400 Flatbed Scanner
This scanner requires a "Parallel or Centronics" cable and if you have a newer computer, you may only have USB connections. A "USB to CENTRONICS" cable may do the trick, but I'm not sure. Check on the web for one.
Jun 27, 2009 | Umax Astra 1220P Flatbed Scanner
Required Scanner Driver of Model Umax Astra 5600
Hi Friends.. My name is Mr Akheel..
Here i have Umax Astra 5600/5650 Scanner Drivers.. U can download it from below link.. It's true & Working Link... Please Comments after Downloading....
E-Mail : aqeel_softs@yahoo.com
Download Link : http://www.mediafire.com/?0zmyvjzazzm
Apr 03, 2009 | Umax Astra 6400 Flatbed Scanner
Driver Problem
hi sir
i think i must try it in windows xp.
Sep 02, 2008 | Umax Astra 4450 Flatbed Scanner
Aug 14, 2008 | Umax Astra 2000P Flatbed Scanner
Umax astra 4500
i need driver of astra scanner
Jan 09, 2008 | Umax Astra 4450 Flatbed Scanner
Umax Astra 4450 Flatbed Scanner Logo
152 people viewed this question
Top Umax Office Equipment & Supplies Experts
Tony
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
