Question about Whirlpool Refrigerators
I have a ten year old Whirlpool 19.7 cu ft refrigerator that has inadequate freezing. I've checked the defrost system and it is fine. Model # ED20DBXEWo1. My question is it worth fixing. My assumption is it will require a professional to repair.
  • 481 Answers
  • if the defrost system is working fine then before you replace it or call a professional,
  • thoroughly clean the coils under the machine and make sure the airflow is not obstructed in any way.
  • it also could be a weak compressor ; expensive professional repair.
let me know how it turns out. Mike
Posted on Jul 02, 2008
FREEZER SIDE OF SIDE BY SIDE FREEZES UP
You have one or more of your defrost components that are bad. Namely defrost heater, defrost thermostat, and defrost timer / board depending on model.
Nov 04, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water Shute freezing up in ice maker
freezer maybe turnedup to high ck manufacturing recommendations
Feb 06, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in bottom try more than can be evaporated by fan pan overflowing Model Gs6nbexrs00 Serial ss2448296 4 1/2 years old
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check the door seals...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Have a whirlpool refrig. both sides freezing up even when set on lowest level model # ed5phaxtsoo cleaned coils fan runs allthe time.
heatman101
Sep 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge model GD5YHAXTL 01 gets too cold. Milk is freezing. So far I have cleaned it out and it is currently unplugged.
heatman101
Sep 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer does not keep ice cream frozen
You are having a problem with one of the three main components of the the defrost system. Look into rear of your freezer to see if ice and frost is beginning to build up on the rear panel. If yes begin manual defrost by unplugging and remove contents of freeze. Even better send me the model number of your Whirlpool. That is how I tell you were the problem began most likely. Look around the door frame and inside the fresh food section sea Breeze
Apr 12, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Refrigerator is too cold and freezes food.
Good day,
If the machine is under one year old, all working components are under factory warranty. Call for warranty service from selling dealer, or if you moved out of the area, an authorized Whirlpool warranty dealer.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Servis fridge / frezer not colling or freezing
i would firstly do a complete defrost- incase there has been a fault with the frost free system. if after a full defrost it runs ok then there was a fault somewhere in the defrost system including either defrost heater, cut out or possible jammed circulation fan.
Feb 05, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
51 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
