WILL NOT AGITATE
FILLS UP, WILL NOT AGITATE, LID IS CLOSED
  • 4 more comments
  • Anonymous Jul 01, 2008
    I have a maytag PAV1000AWW, it will fill with water but will not agitate, it hums a sec. then stops. Can I fix it. Thank you
  • Anonymous Jan 04, 2009
    My Maytag Atlantis (5 years) fills, won't agitate, hums, burnt smell. I unplug for 20 mins and move the dial to spin and drain
  • ttomlin292 Jan 15, 2009
    washer does everything but agitate, it just makes grinding noise durring wash portion of cycle
  • Anonymous Jan 23, 2009
    agitate
  • Anonymous Jan 25, 2009
    Will not agitate
  • jhoubre Feb 14, 2009
    same thing but model lwazoaw
    Problem Solver:
  • 7 Answers
Circut board mounted on timer assy is the problem, tip the console on its back to verify and put in agitate mode, will work in lay back position, then will not work in normal position. unplug board two times and should start working, it gets scrambled just like a computer, because its a computer. must be a relay on the board, this is what happened to me, and is still working 10 loads later, sounded like a motor.
Posted on Jan 30, 2009
Ge 6 cycle washer older model . It fills but why doesn't agitate or rinse?
Sounds like the sensor that detects when the lid is closed is either not making contact or has gone bad. The washer will fill with the lid open but for safety reasons will not function any further.
Sep 02, 2014 | Washing Machines
I am read your posts trying to find a solution to my washer problem my washer fills drains but will not agitate or spin it appears the lid switch is good and the coupler is good. what do yu think the
It sounds like the clutch has gone in the base of the machine. You need a service engineer.
The lid switch is there to make it impossible to have the lid open when the machine is spinning. Opening the lid when the machine is spinning puts the breaks on the clutch. There was a case of a child last year who poked an object into the catch so he could watch the machine spin. He put his arm in for some reason and his arm was ripped off.
Dec 10, 2017 | Kenmore 23822 Top Load Washer
Whirlpool model # LLR6144BQ1 water fills but will not go to wash cycle.
Hi and welcome to FixYa, I am Kelly.
This is usually caused by a failed lid switch that is item 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996
First off put the washer in the spin cycle. With the lid closed see if the washer will spin. No spin also = bad lid switch. If the washer spins but will not agitate then the problem is most likely the water level pressure switch or associated air tubing. (any air leaks and it will not stop filling)
Water level switch is item 12 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996&diagram_id=28209075#d28209075
We test these with NO WATER in the machine and after connecting an external hose with the lid closed with power on by orally passing air into the small air hose we connected. It will click and the washer must agitate. If it clicks and does not agitate... again it points to the lid switch. Disconnecting this water level switch hose with ater in the maching and then re-connecting the hose WILL result in the machine overflowing. Tub MUST be empty.
You check the lid switch as you just open or close the lid. You should hear an audible CLICK as the lid is barely off of its closed position and again as the lid is almost closed. NO CLICK = bad door switch.
These are the 2 most common reasons that will correct the symptom your experiencing more than 90 percent of the time. There is a remote possibility that there is a problem with the motor / motor clutch. Motor clutch problems are noted by odd noises when motor is running and it will not spin or agitate. If the motor will spin the machine but will not agitate the machine it can be a motor winding.
Thanks for choosing FixYa,
Kelly
Mar 13, 2011 | Whirlpool Washing Machines
Washer fills and drains but does not agitate or spin.
It sounds like the problem is in your lid switch. Its a safety feature that if the lid is not closed, it will not spin or agitate. I would start there with your troubleshooting.
Mar 12, 2010 | GE Washing Machines
Fills with water but won't start to agitate. This
the lid switch is bad, u need whirlpool part number # 3949247 usually around 30-50 dollars.. u can see a picture of the part on repairclinic.com and most usually come with instructions so hopefully this helps..
Jan 30, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
My washer fills up then doesn't do anything.
Check the lid switch. Many washers won't work if the lid isn't closed. Without the lid switch, the machine can't tell.
Dec 10, 2009 | Admiral AW22 Top Load Washer
My washer doesn't agitate or spin, it just drains and fills up
That sounds like your lid switch. The lid switch on most models of top load washers will be bypassed on fill and drain. As a safety the lid must be closed for agitate and spin.
The lids switch is a pretty easy part to replace and is inexpensive.
Oct 02, 2009 | GE Washing Machines
Won't agitate or spin
If you mean that when the unit should be agitating or spinning the motor is running, and you lift the lid causing the motor to stop running, it sounds like the coupler.
Mar 31, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore 70 series
Okay...I'm a little confused on your symptoms. You initially said it fills, but doesn't agitate or spin, but drains.
Then, you finished with the washer filling, no agitate or spin, but now doesn't drain.
Which one is it?
The symptoms you describe are usually associated with the following:
1. Fills, may or may not agitate, won't spin or drain - lid switch.
2. Fills, may or may not agitate, won't spin, but still drains - motor coupling.
3. Fills, may or may not agitate, won't spin or spins slow - gear case.
4. Fills, agitates, spins, but does not drain – water pump.
NOTE: These are the more common failure items with these symptoms.
Double check the lid switch by opening and closing the lid. You should hear a clicking noise to indicate the switch is working. The switch is located under the top panel along the wash tub rim on the right-hand side. If not, check to make sure the lid strike (small plastic piece on the lid itself) is in place. This activates the lid switch when the lid is closed. Also, check the mounting screws along the rim (there are two of them) to see if they are tight.
If the motor coupling were bad, the washer would still drain, but there would be a rattling sound as the washer tries to spin or agitate.
If you need replacement parts, go to searspartsdirect.com and type in your model number in the "Search by Model Number" window. The lid switch can be found under the "Top and Cabinet" heading as item number 11 (part #3949238). Instructions on how to replace are located at the following link:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
If you wish to replace the motor coupling, the part can be found under the “Brake/Clutch/Gearcase/Motor/Pump” heading as item number 13 (part #285753A). If you need instructions on how to replace, just follow this link:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Now, there’s a couple of ways to drain the washer. If it’s a simple lid switch problem, you don’t need to drain the washer to replace the switch. With a broken switch repaired, the washer will run and drain by itself. However, if you wish to drain the tub you can use a shop vac to pull a vacuum on the drain hose. This may take a few times depending on the size of the shop vac. These wash tubs typically have about a 35 gallon capacity. If you do not own a shop vac, you can by-pass the lid switch by jumpering the two BLACK wires at the lid switch connector that is connected to the console. CAUTION: Make sure you UNPLUG the washer before jumpering, then plug back in.
I hope this information is helpful to you. If I’m wrong about the symptoms, please post back and update me on what the washer is or is not doing, so I can assist you further.
May 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
