Question about LG WD-1045FH Front Load Washer
Fault codes machine runs ok for 10 mins then throws up fault code DE
  • 25 Answers
Found fault to be in motor assy
Posted on Jul 03, 2008
Runs good, after 30 mins stalls no injector pulse and hard to start.after 10-15 mins starts again, spark OK. changed fuel pump,distributor. Same
run the fault codes and check for problem ECM
There is an electronic component failure in the injector circuit that when over heats , shuts that injector circuit down
try replacing the ECM with a known good unit
Dec 09, 2015 | 1988 Ford Tempo
Starts and runs well. gone to the shop stop motor 10 mins now wont' start. calls hubby, now starts ok. this happens many times.
run the fault codes
this happens when an electronic component over heats and will not work until it cools down
Nov 15, 2015 | Cars & Trucks
Error codes 3 and 10
need to test with multimeter, door code error could be a faulty door switch which would hinder machine from operating. I suggest checking the glo bar and ceramic igniter for the going off problem, in electric dryers maybe in gas as well bad motor windings can cause it to go off and on?
Aug 17, 2014 | Maytag Neptune MDG6700A Gas Dryer
Sanyo l18 fault code
DEAR SIR:
E18
Group control wiring error, Main indoor unit not receiving signal for sub indoor units
check your r.control.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 29, 2012 | Sanyo Heating & Cooling
Fault code on zimmer cooler
Zimmer cooler ?? for a car? or do you mean a zimmer frame for a go faster grandad racer with air conditioning fitted for hotterclimates
Mar 10, 2012 | Cars & Trucks
1999 Grand Voyager 2.5td turbo does not pick at around 2000rpm, fuel consumption on the rise and hard to get to higher than 100kph
well there is two options
1.injector nr 1 has sensor that dont work propert.
2. conect your voyager to the pc. there might be error on sensors that need to be removed. then it goes a had. i had this problem with mine. took me 10 min. to fix it
Feb 27, 2012 | Chrysler Voyager Cars & Trucks
How to repair front loader
try this select pause/cancel twice to cancel the cycle that it was on before f8 fault code came on then select drain/spin if there is excessive water in the washer repeatthe fault code should have gone check for blockages ie pump / hoses filter ext if this does not work try unplugging your machine for 10 mins plug back in it should clear fault
Nov 27, 2011 | Kenmore Washing Machines
DE code, machine will not run. door working properly
DE indicates a door lock error.
Either the door lock, wiring or main control board can cause this fault. The door lock is relatively inexpensive so it would be worth trying a new door lock first.
Check the wiring between the door lock and the control board. If a new door lock doesn't fix it and the wiring is ok you are only left with the control board.
Hope this helps.
Aug 06, 2011 | LG WM2042 Front Load Washer
Samsung washing machine reset code
i have samsung
6 kg WA80HAG silver nano
dear'
plz help me to reset washing
machine
thanks
Mar 18, 2008 | Samsung WF337AA Front Load Washer
LG WD-1045FH Front Load Washer Logo
161 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
