Question about HP Pavilion dv6000t 15.4" Notebook Laptop PC PC Notebook
THe hard disk does not start
Helo my hard disk does not start, what should I do? it only has 2 months old
It says that there are sectors that are unreadeable. How can I repear it?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 130 Answers
Perform hard drive self test from notebook BIOS. If the test is failed then the hard drive needs to be replaced.
Posted on Aug 20, 2009
Whenever logs in Windows defender scans the hard disks and gives the bad sector / RAM faults and 37 % unreadable hard disk and ask o purchase the s/w to remove those fault.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
one bad lead will end with a computer error also run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
hope this helps
Mar 27, 2011 | Fujitsu (MHW2120BH) 120 GB SATA Hard Drive
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
Tip
How to speed up your computer's performance?
<p><b>Information:</b><br /> <p>There are some few guidelines that you can follow to maintain your computer and keep it running smoothly. <br /> <p><b>Free Up Disk Space</b><br /> <p>By freeing disk space, you can improve the performance of your computer. The Disk Cleanup tool helps you free up space on your hard disk. The utility identifies files that you can safely delete, and then enables you to choose whether you want to delete some or all of the identified files.<br /> <p><b>Use Disk Cleanup to:</b><br /> <p>&bull; Remove temporary Internet files.<br />&bull; Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).<br />&bull; Empty the Recycle Bin.<br />&bull; Remove Windows temporary files.<br />&bull; Remove optional Windows components that you don't use.<br />&bull; Remove installed programs that you no longer use.<br /> <p> <br /> <p> <br /> <p><b>Tip:</b> Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.<br /> <p> <br /> <p><b>To use Disk Cleanup</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Cleanup. If several drives are available, you might be prompted to specify which drive you want to clean.<br /> <p> <br /> <p> <br /> <p>Disk Cleanup calculates the amount of space you will be able to free.<br /> <p>2. In the Disk Cleanup for dialog box, scroll through the content of the Files to delete list.<br /> <p> <br /> <p> <br /> <p>Choose the files that you want to delete.<br /> <p>3. Clear the check boxes for files that you don't want to delete, and then click OK.<br /> <p>4. When prompted to confirm that you want to delete the specified files, click Yes. <br /> <p>After a few minutes, the process completes and the Disk Cleanup dialog box closes, leaving your computer cleaner and performing better.<br /> <p> <br /> <p> <br /> <p><b>Speed Up Access to Data</b><br /> <p>Disk fragmentation slows the overall performance of your system. When files are fragmented, the computer must search the hard disk when the file is opened to piece it back together. The response time can be significantly longer.<br /> <p>Disk Defragmenter is a Windows utility that consolidates fragmented files and folders on your computer's hard disk so that each occupies a single space on the disk. With your files stored neatly end-to-end, without fragmentation, reading and writing to the disk speeds up.<br /> <p><b>Run Disk Defragmenter</b><br /> <p>In addition to running Disk Defragmenter at regular intervals, optimally monthly, certain events warrant running the utility outside of the monthly rule of thumb.<br /> <p>You should run Disk Defragmenter under the following circumstances:<br /> <p>&bull; You add a large number of files. <br />&bull; Your free disk space nears 15 percent. <br />&bull; You install new programs or a new version of Windows.<br /><br /> <p> <br /> <p><b>To use Disk Defragmenter:</b><br /> <p>1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Disk Defragmenter.<br /> <p> <br /> <p>Click Analyze to start the Disk Defragmenter.<br /> <p>2. In the Disk Defragmenter dialog box, click the drives that you want to defragment, and then click the Analyze button.<br /> <p>After the disk is analyzed, a dialog box appears, letting you know whether you should defragment the analyzed drives.<br /> <p><b>Tip:</b> You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.<br /> <p>3. To defragment the selected drive or drives, click the Defragment button.<br /> <p>After the defragmentation is complete, Disk Defragmenter displays the results.<br /> <p>4. To display detailed information about the defragmented disk or partition, click View Report.<br /> <p>5. To close the View Report dialog box, click Close.<br /> <p>6. To close the Disk Defragmenter utility, click the Close button on the title bar of the window.<br /> <p><b>Detect and Repair Disk Errors</b><br /> <p>In addition to running Disk Cleanup and Disk Defragmenter to optimize the performance of your computer, you can check the integrity of the files stored on your hard disk by running the Error Checking utility.<br /> <p>As you use your hard drive, it can develop bad sectors. Bad sectors slow down hard disk performance and sometimes make data writing (such as file saving) difficult, or even impossible. The Error Checking utility scans the hard drive for bad sectors, and scans for file system errors to see whether certain files or folders are misplaced.<br /> <p>If you use your computer daily, you should try to run this utility weekly to help prevent data loss.<br /> <p><b>To run the Error Checking utility:</b><br /> <p><b>Important:</b> Be sure to close all files before running the Error-Checking utility.<br /> <p>1. Click Start, and then click My Computer.<br />2. In the My Computer window, right-click the hard disk you want to search for bad sectors, and then click Properties.<br />3. In the Properties dialog box, click the Tools tab.<br />4. Click the Check Now button.<br />5. In the Check Disk dialog box, select the Scan for and attempt recovery of bad sectors check box, and then click Start.<br /> <p> <br /> <p>In most circumstances, select Scan for and attempt recovery of bad sectors.<br /> <p>6. If bad sectors are found, choose to fix them.<br /> <p><b>Tip:</b> Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.<br /> <p> <br /> <p>Hope this will help...<br />
on Jan 17, 2011 | Computers & Internet
Hard drive making constant noise on asus g72 laptop, did a defragmentation, registry clean up. still doing it. the laptop about 2 to 3 month old.
hope this helps
Oct 31, 2010 | ASUS (90N804SH021) Hard Drive
My computer HDD have bad sactors please help to remove this on
When a hard disk has bad sectors, these sectors can be fixed by running check disk. This is a temporary fix as the hard disk is nearly worn out and it will get more bad sectors and evenually the hard disk will fail completely.
Bad sectors occur when the magnetic oxide on the disk platters is worn out and data cannot be written or read from these sectors.
To run check disk click Start - My Computer - right click on C Drive and click on Properties - click on Tools tab - then Check Now in Error Checking
I suggest once this has been done, you back up your data and purchase a new hard disk ready to install Windows etc. when the hard disk fails completely. You may want to install a new hard drive before the old hard drive fails completely.
Aug 21, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Tip
Information: There are some few guidelines that you can follow to maintain your computer and keep it running smoothly.
Free Up Disk Space
• Remove temporary Internet files.
• Remove downloaded program files (such as Microsoft ActiveX controls and Java applets).
• Empty the Recycle Bin.
• Remove Windows temporary files.
• Remove optional Windows components that you don't use.
• Remove installed programs that you no longer use.
Tip: Typically, temporary Internet files take the most amount of space because the browser caches each page you visit for faster access later.
To use Disk Cleanup
• You add a large number of files.
• Your free disk space nears 15 percent.
• You install new programs or a new version of Windows.
Tip: You should analyze a volume before defragmenting it to get an estimate of how long the defragmentation process will take.
Important: Be sure to close all files before running the Error-Checking utility.
Tip: Only select the Automatically fix file system errors check box if you think that your disk contains bad sectors.
on Jul 05, 2010 | Computers & Internet
Lags and says has bad sector after 14 months
Good day sir/maam, hi, 14 months is too short for a hard disk operating span, what we do is run the diskmanager software that comes with the seagate hard disk, on the diskmanager menu, run the low level format which usually removes the bad sectored space out of the way, and mark it as not usable. then may I suggest you partition your hard drive to 2, one for windows and the the other for data. call your computer dealer if they have in house techs for service, or get the copy of disk manager for your seagate. Hope this helps, thanks
Nov 04, 2009 | Seagate 750GB BARRACUDA SATA 7200 RPM 32MB...
Problems with boot
the solution to your problem is format. just reformat your pc then after the completion of it, run the checkdisk ( i suspect that your hard disk has a bad sector)
to run the check disk..
1. go to start
2. look for the "run" command then click it
"run" command is a dos prompt that will allow you to key in some commands.
3. type chkdsk c: /f
Using /f will automatically fix the system and hard disk error if there is any
after that test, if the chkdsk found some bad sector in your hard disk, may i suggest that you have to buy new hard disk because using hard disk with bad sector it will face you a trouble in the future.
Apr 01, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Sleep mode
A drive in sleep mode doesnot shorten the life.But old drives in sleep mode are still passively active and reallocating the bad sectors of hard disk. so New disks have no problem. but once bad or weak sectors develop then its unsafe to make it go in sleep mode.
Oct 08, 2017 | Western Digital 120 GB USB 2.0 Hard Drive
16 bad sector
Scandisk(or whatever) should mark those sectors as bad, thus preventing them from being used. But no, you cannot erase them, they are physical areas of your disk that cannot properly hold data. Bad sectors are not uncommon, and nothing to be alarmed about, but a loud hard drive is...
Mar 01, 2008 | Seagate (9W2892-337) 80 GB Hard Drive
HP Pavilion dv6000t 15.4" Notebook Laptop PC PC Notebook Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
