Question about HP Pavilion ze2000 Notebook
Sound device I had harddrive problems due to a virus. I replaced it and now my sound device doesn't work. How can I solve it?
  • Anonymous Jul 07, 2008
    my friend wiped hard drive,now i dont have au
  • matj465 Jul 10, 2008
    hey i have hp pavilion ze2000 and my brother messed it up windows and everything so i had a corp windows xp pro cd 64x so i installed window and got most of the drivers but the sound still wont work even thought i installed the driver so i dont know what the heck is wrong with it so help me out
    Genius:
  • 2,028 Answers
Make sure the sound drivers are loaded. You can check this, and any other drivers that are needed in the device manager.
Posted on Jul 01, 2008
Boot mgr error
This message usually means your "boot record" on your harddrive is corrupt due to a virus attack or harddrive failure. You will need to repair your boot record. If that doesn't solve the problem, replace your harddrive. If you don't know what this means, take it to a good computer repair shop. It's not something you want to do as a "newbie".
Oct 13, 2013 | Computers & Internet
My toshiba external harddrive usb 3.0 won't work
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
hope this helps you
Sep 18, 2011 | Toshiba Notebooks Canvio E05a075cau3xw 750...
K9N6PGM2-V MSI Mobo no display no beeps after virus attacked,im installing Anti Virus AVAST it stop suddenly the screen becomes dull and grey with white line,so i restarted my PC and it doesn't display...
Your VGA device of motherboard might have problem. and it also can be caused due to some IC failure... you will have to repair your Motherboard as soon as possible. if it dosen't worrks consider replacing your Motherboard.
Sep 01, 2011 | MSI K9N6PGM2-V Motherboard
When i start up my note book it just comes up no bootable device insert boot disk and then press any key.? there is no disk slot to put a disk in.?
Hi there!
This error messages means that you don't have any functioning bootable device. Since you don't have a disc drive, then it is possible that your harddrive crashed or needs to be replace. What you can do is to check in the BIOS if the harddrive is detected or not. If it is, then you just have to reinstall the operating system of your computer. If not, you may have to replace it.
Best regards!
Jun 29, 2011 | Computers & Internet
No sound device
No Sound Device notification suggests that your Sound Card Driver had corrupted due to some sort of file deletion process or change in your registry. (Which could be due to a virus attack).
1 - First and foremost, if your PC is feeling a bit sluggish, download and install a free anti-virus like Avira, from this link:
http://www.avira.com/en/avira-free-antivirus
2 - Check your system for possible viral infection.
3 - Clear or delete any suspicious files.
Now if there is no viral infection and Avira declares your PC free from any mal-ware then go on
1 - Remove the previous installation of your Sound Card Driver using Revo Uninstaller Portable, it can be downloaded from the following link.
http://www.revouninstaller.com/download/revouninstaller.zip
2 - It would ensure that no previous installations of that driver are intact.
3 - Reinstall the sound card driver.
Hopefully it would help you solve your problem.
Thanks for using FixYa.
Jun 04, 2011 | Computers & Internet
There is somethig seriously wrong with my PC. It was attacked by some computer viruses
You can try to run a full virus scan in Safe Mode. To access it, you will either press F8, or Del (depends on what key was designed on your computer to access the Advanced Boot Options), after getting the Advanced Boot Options, select Safe Mode an press Enter key.
If your antivirus software cannot detect any virus, it was either not updated or was disabled by the virus. You need to contact your antivirus company to get help with manual virus deletion.
However, if you don't have any antivirus installed I suggest to just wipe everything off from the harddrive and start from factory settings.
Hope this helps.
Jun 01, 2011 | Computers & Internet
I got a couple of virus infected my PC a week ago (Essential Cleaner & MS Removal Tool). I had to download instructions on how to remove such virus on the internet. I managed to remove the first virus...
Even if you remove a virus, most of the cases, the damage cannot be repaired. Remove the sound driver and install it once again. If that doesn't work, you should consider reinstalling the OS.
May 24, 2011 | Microsoft Windows XP Professional
My browser screen / windows explorer flickers infact shakes vigorously, possible virus attack. try to run couple of anti-virus, but not able to detect. what's the solution?
screen shakes ,,,Due to virus..... It's sound's like fun......
May be it shakes due to signals, keep Ur mobile phone or any other devices away from Ur Monitor
I hope Ur problem 'll solve....
Jan 04, 2011 | Computers & Internet
I reinstalled my window due to viruses.i ran setup in motherboard cd.even then there is a question mark before pci device icon. due to it there is no sound in my pc.my motherboard cd reads mercury...
The yellow question mark is telling you that there is a problem with the device, namely your sound card. It is probably needing the drivers for the card. If you have the disk for the sound card, use it and install the drivers or go to the web site for the card and download and install drivers from there. This will solve your problem. Good luck
Jul 16, 2010 | Computers & Internet
Deivis
some file which needed for the operating of that driver might have got corrupted or is not valid ...
once you try uninstalling and reinstalling the driver this will solve your problem ...
if you already did that & still persist the same problem then there may be some file missing in operating system . this might have happened due to some virus attack or while removal of some virus the file which is needed for the operation of that device might have got deleted accidentally ..
so just reinstall the operating system and then try installing the sound driver this will solve your problem ...
if you still persist the same problem then download the driver from net and install this solves your problem (there may be some problem in the driver which you are trying to install may be some file is missing)
so just following these steps your problem will be solved ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution ....
Aug 10, 2008 | Computers & Internet
HP Pavilion ze2000 Notebook Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
