Dryers Logo
Posted on Dec 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The dryer will not start, it seems to hum. Sometimes you can get the dryer to start, and when you put a small load into it, it will not start? The dryer tub moves freely by hand.
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Dec 17, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10835315
Points
101584
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
I have a frigidaire gallery electric dryer. It was working fine for the load of laundry I had in it, then I put the next load in and turned the start button and all I get is a hum. It seems to be sending...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
My dryer won't start. When i activate the start switch I hear a hum like the motor is bound up.. I opened the top and the drum is not stuck and the belt seems in good shape. The unit is about 4 years...
check the blower wheel sometimes objects get caught in it not allowing it to spin. If it is clean open the dryer door push and hold the door switch and push start while it is humming rotate the drum. if it starts to spin then you need a new motor it will run you probably 150 - 200 dollars
Dryer does not start. if you push on the start button you can hear a small hum from the area of the timer, otherwise nothing. door switch seems to be working
one  make sure you advance the timer into the heating area of the cycle if you did that and turned it on and still humming you  have a bad motor
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Heats but dont dry after several attempts and load sizes and more
loose blower wheel/Stopped up filter housing
070a05e.jpgIf I was Karmac I could read your mind and get the model number, probably give a better answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2009 • Dryers
2answers
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Starting dryer
you need to replace the motor
Dec 17, 2007 • Dryers
Starting dryer
the motor needs to be replaced. the bearing are going bad and they are only sold as the whole motor
Nov 28, 2007 • Dryers
Starting dryer
THE HUMMING IS THE WATER VALVE WHICH IS OK,CHECK WATER PRESURE AND FILTERS IT MAY BE DOOR INTERLOCK
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
