Question about Lands Phones
Where do you connect a External Paging Port on Nortel Key Telephone System NT5B05?
I need to know where do you connect an External Paging Amplifier on a Nortel Key Telephone System NT5B05. There is only 3 lines coming into this Key Telephone System. But, the Key Telephone System 3 lines connect to a 66 Block. I desperate need help and a good explanation how to make the hook up to an External Paging Amplifier. The Telephone
System is programmed for paging using the Telephone Internal Speakers by picking up the receiver and press "Page 1 Button", then you can hear the paging through the telephone speakers. But, I need to hear a louder page by using connecting up a External Paging Amplifier to the proper port.
Your immediate help will be deeply appreciated. Thank you in advance.
  • Intercom Man Jul 02, 2008
    I still do not know what output pins are the External Paging Output to connect to the Paging Telephone Amplifier Input too. So, someone be specific and tell me exactly what pins or terminals are the output that I need to connect to the input of the amplifier. I will be conneting the Paging External Output to a Bogen TPU-35B Telephone Paging Amplifier that only has a 2-Terminal Input to receive the Paging Siganl.
  • Anonymous Mar 28, 2014
    I have a Conair Big Button telephone and I need the directions to know how to use it.
    Guru:
  • 859 Answers
Battlesmith sounds about right, but I don't think he answered your question. The 66 block pins carry voltage, around 37 and when the line rings 100. When you attach a meter you will be hunting Tip and Ring. I set my meter to VAC at 150v, as the phone line has rung on me while checking lines on a large 66 Block. Since you have three wires coming in I would think this is a common ground. The neg and pos terminal relationship or Tip and Ring are easy enough to distinguish. When you have the polarity right with your meter leads you should read around 37 volts when no one is on the line, a line open drops this voltage significantly. So if you have them reversed you will only get around 8 volts.
Question: does the terminal have red/green or blue whie/blue wires coming off it? or a +, - mark. Depending on the age of your existing wires you have re/gree and black/yellow in the Cat3 bundle, or in newer Cat5, you have blue/blue-white as the primary number and Orange/Orange-White as the secondary line.
Here's where you have to test and use your cell and a helper to answer your call and page. Run Blue in on the block to blue out to your terminal and so on. Reverse those if when you call the line and the helper pages you don't hear anything. This testing is only if you have no help from markings on the amp terminal. Digital PBX voltages are different but reasonably the same. Analog PBX systems (more common today for their simplicity) are what I described to you.
Regards,
Worldvet
Please ask any questoins you may have about this using the comment box below.
Posted on Jul 03, 2008
    Master:
  • 382 Answers
It has 3- RJ-11 jacks for co-line interface and one male 50-pin amphenol connection is used as the interface for the stations; the amphenols is also used for connection of external devices such as Music on Hold source, loud speaker paging and a relay contact for auxiliary ringers.So pls use this s0-pin amphenol for connecting the External Paging Amplifier So that it is louder too..Please feel free for any assitance..hope it helps you..thank you!!..
Posted on Jul 02, 2008
    Master:
  • 638 Answers
This is the link to help you.
http://www.britishtelephones.com/qfmenu.htm
this will help you for sure.
but a service technical at your place will be more better choice.
because if you make one wrong connection some of the function would not work properly.
rate the solution as fixya if it helps you in solving your problem.
  • hemant somaiya
    hemant somaiya Jul 02, 2008
    have you checked the link .
    update
    Genius:
  • 1,142 Answers
This will help you
http://assets.twacomm.com/assets/pdf/4230.pdf
How to program the page button
Can you please be a little more specific? Are you referring to assigning the paging feature to a button on the phone or programming the actions the system performs when you press the existing paging button on the phone? Normally, when you press the predefined paging button on this phone the system prompts you to select where your paging output goes. Depending on how your system was set up it may ask you to select "set", meaning when you select this soft-key the system will sound a short alert tone through all of the speakers in all of the phones connected to the system then allow you to talk through all of the phone set speakers. The other option is to select a soft-key that directs the output of the paging to an external PA system that is connected to the NAM through a punchblock connection. You can usually also select "both" which directs the output through the phone sets and the PA system. I am not certain what, if any system programming might be involved - I am fairly certain that if your system has not been connected to a PA system the paging function is just available to output through the phone set speakers. If your phones have no buttons assigned to the page feature then you'll need to refer to the system programming procedures to find out which feature code is assigned to paging and then access it by pressing FEATURE + the paging code or assigning the paging feature code to an unused button.
Oct 16, 2013 | NorStar Meridian M7310 Phone
Nortel Meridian M7208 page not working...
Press Feature * 3
press the 5th line key you want to use for paging
enter the page-all code (feature 601-603 as you wish)
Aug 20, 2017 | Nortel Meridian M7208 Corded Phone
I would like to use an intercom system on my phone. Is this possible with a 4412d? If so how do I do this?
when you say intercom system, do you mean overhead paging?
YES, it can page a phones speaker or an external paging system.
Also, a 4412 can be used on a few different systems, you will need to know more info, and I would call a technician, as this might be some pretty tricky programming, especially if it is an IP Office.
Jan 12, 2011 | Avaya AT&T Merlin Handsfree Answer Back on...
I'm trying to disable paging on my T7316E phone. Paging is EXTREMELY loud and bothersome. There should be a function key sequence that disalbes it.
You can disable paging through system programming but it might be easier to turn down the volume by pushing the volume down arrow when a page is being announced.
Sep 23, 2010 | Nortel T7316E 2-Line Corded Phone
Getting the M7208 to work
Nortel M7000 series are proprietary sets which require a nortel MICS, CICS, or an older 8x24, 6x16, or 3x08 in order to work. If you have the system, it maybe that the jack isn't activated with a system port.
Nov 24, 2009 | Nortel Meridian M7208 Corded Phone
Problem with power supply in PBX o KSU
Power supplies come with the main chassis. You may need to have the chassis replaced. are you sure it is receiving power ok? You can replace the cards and the flash card into the new chassis and restore programming.
Oct 21, 2009 | Nortel Norstar 16-Line PBX Speakerphone
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
Sep 24, 2008 | Nortel T7316E 2-Line Corded Phone
ALCATEL 4028/4029 PHONE. WOULD LIKE TO KNOW IF IT PLAYS MUSIC SO I CAN HEAR IT WHILE I WORK?
Depends which Alcatel system the 4028/4029 is connected to.
If OXO, you will require an external music source to be connected to the AUDIO-IN port on the CPU (RJ45 plug using pins 1&2) and is recommended to install MOH/Paging isolating transformer. To enable background music on 4028/4029, hold the green speaker key for several seconds. Starts flashing and the volume can be adjusted with the + & - beside the mute key. To disable, just repeat hold process.
If OXE, will require engineer to program softkey & again will require an external music source...
Good luck...
Sep 03, 2008 | Alcatel Lands Phones
158d system
The paging connects to one of the line ports on the system. Its needs to be specified in system programming which line you will be using. When you login to System programmiing (feature-0-0-left intercom--left intercom) you can go to Loudspeaker Paging Line #617, then select an unused (available) line. (feature-0-0) to save. Then go to the system and the port of the line you selected is where you will connect the signal leads to the paging horn. Then use Intercom *70 to page or program a paging button
Aug 25, 2008 | Lucent PARTNER18 Corded Phone
Lands Phones Logo
1,436 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
