My laptop just had SP2 installed and now I cannot connect
to my network via the wireless connection. I am running
a Netgear MR814 router/access point with the Microsoft
MN520 network card and using the Microsoft Broadband
Networking application. The error that I am getting is
that it says that I have the incorrect security key. I
have entered the key several time and several different
ways. I have connected the laptop via a cable and even
cut and pasted the security key in and still no luck. I
have also updated the MS Broadband Utility from the MS
website. I have a second laptop, a centrino setup, that
does not have any problems connecting, even after SP2.
2 Other Users Have The Same Problem
Comment by Guest, posted on Jul 08, 2008
Is there any way to get the MN-520 wireless card to use WPA for wireless security ? It will not connect to my wireless network because the wireless card is using WEP.
Comment by Guest, posted on Feb 14, 2008
won't connect
Rating: 0%, 0 votes
I had spent all last night trying to get my internet working. After getting
SP2 and the updated MBU. I eventually gave up and went to sleep. This
morning I remembered about these newsgroups. Your suggestion helped me out
a lot. It fixed my problems. Thanks a bunch.
Rockfang
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Application. Once you remove that program go to the
wireless network properites and click the check box that
says "Use Windows to configure my wireless settings." I
have the exact same set up and had a very similar problem
and once I did that I had no problems. My guess, judging
from the errors is the SP2 and the MBU are not compatiple
at this time, I am sure MS will get to this sooner or
later but the MBU is not really needed. Best of luck.
Rating: 0%, 0 votes
Instead, use Windows built in Wireless configuration to set it up.
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
http://mvp.support.microsoft.c om/default.aspx
Post a New problem for Microsoft Broadband Networking MN-520
Email this problem
