28" Toshiba TV has no audio when TV is turned on. the speakers are fine as you can hear a video tape. need help
    Master:
  • 848 Answers
First check that any muting control is not activated. This might be a button on the remote or set itself. If you have a headphone jack, it may have dirty contacts as plugging in a headphone usually mutes the speaker. If the set is mono or only one channel of a stereo set is out, then check for bad connections to the loudspeaker. Test the loudspeaker by disconnecting one of the wires (with the power off!) and measuring its resistance with an ohmmeter (it should be less than 100 ohms - probably less than 8 ohms). Or momentarily touch a 1.5 volt battery to the speaker terminals - you should get a click or pop from the speaker. Next, trace back from the speaker output terminals to the circuit board and look for bad solder connections or a loose or dirty connector. If these tests do not reveal anything, you probably need a scope (or audio signal tracer) and schematic. Or at least the part number off of the chip. Is the final amp a chip also or just a transistor? Have you tested the transistor? If there is little or no buzz from the speaker, that would indicate a problem fairly near the output. If the tuner/if were bad, I would expect some noise/humm pickup from the low level audio stages. Get the part number off of the chip. If it is in a socket, check the contacts for corrosion or looseness.
Posted on Jul 01, 2008
  • 6,487 Answers
Check if the speakers are switched on in your Menu:
Press the AUDIO button on the Remote Control or the Menu button on the TV set to display the AUDIO menu. Repeatedly press the AUDIO button on the remote or the ADV button on the TV set until SPEAKERS is displayed in magenta
Press the + or - button to call up the SPEAKERS ON/OFF mode on screen display. Each time you press the button ON or OFF mode alternate. Make sure is is switched to on.
Also there is a switch on the back of the TV to control which speakers you use, it says MAIN SPEAKER EXT-INT make sure this is set to INT.
If this doesn't work you'll have to contact Toshiba service.
Hope that helps..........
Headphones plugged into TV audio output but speakers don't turn off
use the tv's setup menu to set the audio properties,eg. speakers on or off when headphones are plugged in.
Dec 22, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba satellite m105 s3041 sound only works through headphones
Go to your "Start" menu at the bottom, left of your computer's desktop. Select "Control Panel" from the menus. Select "Sounds and Audio Devices" in the Control Panel.
Look at the settings under the "Volume" tab. Make sure the slider is not turned down. If it is all the way to the left, you need to move it more to the right. Make sure the "Mute" button is not checked.
  • Go to the "Audio" tab. There you will see "Audio Playback" with a drop-down box. Make sure it is set to your computer's sound card. For example, if your computer uses Sigma Tel Audio, make sure that is the name in the drop-down box. If it isn't, then change it to read your sound card's name. If you still do not hear sound, your speakers may be damaged.
  • 7 Test your speakers on another computer before you decide if they are broken. The input jack on your computer might be the problem.
  • God bless you
    Sep 28, 2012 | Toshiba Satellite M105-S3041Notebook
    I have a LG47" tv
    Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
    You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
    Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
    I hope this helps and good luck! Please rate my reply. Thank you.
    Mar 25, 2011 | Audio Players & Recorders
    I'm not sure how to connect my Toshiba SE-R0346 to my Sanyo TV. I plugged the cable line into the "Antenna in" port & then another cable line from "Antenna Out" to my TV. If I...
    Exactly as you have done is fine all you need to do now is play the tape, (so you know what to look for when it is displayed on the screen), decide which channel you want to view the vVCR through, say 9, select the channel and set the TV to search tune on that channel. Store it when your taped programme appears.
    Alternatively, have the set up as you have described and press auto install. That will retune the whole of the TV and include the VCR.
    Hope this helps.
    Nov 03, 2010 | Toshiba Televison & Video
    I am trying to use my Denon AVR-1802 to connect my cable box to my TV. The problem is that I don't have any speakers connected to the 1802, I just want to route the cable box's video and audio to the TV...
    connect your analog output from the cablebox to the receiver md/tape in. then connect your tv audio input to the md/tape out of the receiver. or you could just pass it straight from the box to the tv, bypassing the receiver altogether.
    Nov 03, 2009 | Denon AVR-1802 Receiver
    No audio output
    Were you playing it very loudly when it died?
    The manual is here for reference...
    http://www.docs.sony.com/reflib/docget.asp?manualid=11654&template_id=1&region_id=1&DL=',600,560,10,10,'Manuals'
    It discusses troubleshooting this problem on page 50.
    When you turn the receiver ON does you hear a light click in about 5 seconds? That would be the protection circuitry turning OFF to allow the amplifiers to function. The delay is to allow the circuitry to stabilize before it sends any output to the speakers. If you don't hear a click the unit is Protecting the speakers due to malfunction somewhere.
    If no click and no apparent messages try turning the speakers OFF using the Speakers button directly below the Power button (1/0). This will eliminate or point to external shorts as the cause.
    Does the unit click after 5 seconds of Power ON with the speakers OFF? Isolate your shorted speaker or wire problem.
    Still no sound at the speakers when you turn them ON?
    We need to establish if there is any programming flowing through the receiver.
    A quick basic check would be to tune an FM station, if you have a tape deck attached, place it in Record or Record/Pause mode so it can display the input signal levels. You should see the record meters fluctuating with the level of the program selected. If you don’t have a tape deck, run an RCA cable pair from the audio output for a tape deck to an analog audio input on your TV. Select that input on the TV and you should hear the FM station, or anything the receiver is configured to play. If it's silent then there is no audio signal circulating in the receiver to get out to the amplifiers.
    If you hear the program on the TV but not through any attached speakers, then the amplifiers are all disabled for some reason.
    If there is no audio flowing through the receiver the problem could be a switch in the wrong position, source not selected, muting on or a multitude of other things.
    Let me know how this turns out.
    Apr 03, 2009 | Sony STR-DE695 Receiver
    I have a Toshiba laptop L305D-S5895 and a Toshiba Hi Def LCD 37AV502U tv. I got an audio cable, that I have in the headphone spot & the original cable needed to connect the pc to the tv. I am getting all...
    Which cables have you attached to your TV (the video and audio)?
    Does the TV has left & right audio inputs (RCA connectors)?
    When you attach a headphone to the laptop, the speakers on the laptop switch off and the sounds divert to the headphones. Try and connect a cable (stereo) from the headphone outlet on the laptop to the audio stereo inputs on the TV.
    Mar 28, 2009 | Toshiba Satellite L305D-S5895 Notebook
    Audio recording not very loud in play back
    You may have a tape alignment issue, but, before you try anything rash, have the "control head assembly" cleaned. If you're not squeamish about opening this, you can then load a tape and look to see if the very top edge of the tape is "curled" over anywhere from .5" or greater. If this is the case, you'll need to fix what's causing that before you can do anything else....accordianman
    Dec 16, 2008 | Toshiba M674 VHS VCR
    Volume loss after VCR recording
    Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
    Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
    No Audio only video is visible.
    Replacing the speaker part number 152959011 2,0 cm should solve the problem. If you need more info please advice. Arpi
    Mar 15, 2007 | Sony Handycam DCR-TRV18E Mini DV Digital...
    Televison & Video Logo
    37 people viewed this question
    Top Televison & Video Experts
