Question about Refrigerators
It is a chest freezer the compressor runs but it doesn't freeze
    President:
  • 1,462 Answers
If compressor runs but not cooling, points to compressor failure or a blockage in pipework
for either fault, not a do it yourself job
Posted on Jul 02, 2008
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
I have whirpool chest freezer defrosted and off for 4 months then turned on 2 red lights going motor is running but not freezing turned up temp to coldest tempurature with amber light on stil the motor...
Since the motor is running, the compressor it is connected to must also be running. The compressor is the thing that provides the cooling under normal circumstances. The only thing I can think of as to why you are not getting cooling is that the refrigerant charge has leaked out of the system. I don't know anything about the red lights you mention.
Aug 25, 2014 | Whirlpool 10 cu. ft. / 283 liter Chest...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
I cleaned my freezer and now it won't freeze
When you say "cleaned", did you defrost it? And. if so, could you have damaged the internal lining? Often the coil inside the wall of a chest freezer can fracture if hit or stabbed at during defrosting.
Other than that, is the compressor running (you would hear it)? it may have overheated. If not running, see if it feels hot (siezed) or cold (no power from thermostat). If cold, put it on fast freeze and see if it kicks into life (thermostat faulty) or not (compressor fault, time for a new freezer!)
Let me know how you get on!
Jul 05, 2012 | GE 14.8 cu. ft. General Electric Chest...
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
I have deep freezer chest that does not freeze but when you plug it in you can hear it click on but will not get cold at all has been unplugged for a few years but stored in a dry building
If it doesn't get cold at all, then your compressor is not running. Which could be the start relay or start capacitor or even the compressor. The relay and capacitor are not that expensive and pretty easy to replace, but if it is the compressor then you might not want to put that much money into an older unit.
Aug 13, 2011 | Haier 5 cu. ft. / 142 liter Chest Freezer...
My GE chest freezer stop freezing. the light is on no sounds from the freezer. what could be the problem?
There are many reasons why is not working. 1.if the compressor is not running, Relay or overload burn, they are attached to the side of the compressor 2, thermostat may not be working. 3. if all of the part i mentioned are working fine your compressor may need to be replace.4 if the compressor runs but still don't get cool, there is a internal gas leak inside the freezer. The only way to find out theses issues, is by having the necessary tools and experience.
Jan 17, 2011 | General Electric Chest Freezer FCM7SU
Avanti chest freezer cf199 will not freeze. A
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Nov 19, 2009 | Avanti 7.1 cu. ft. / 201 liter Chest...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
