Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
No picture but the sound is just fine.
Well, I've got a problem with my TV that has been touched on numerous times here in the forum but I haven't been able to see any threads that have worked the problem through all the way. So here is my attempt to help myself and hopefully others.
I bought this TV second hand about 6 months ago and it's been working flawlessly ever since, until the other day. After a round of golf, I fell asleep on the couch watching television. When I woke up there was sound coming out but no picture. After a few attempts to turn it off and on, no luck. Tried unplugging it. No luck. Currently I'm receiving a signal just fine because the audio works off of all the input channels but no video at all. Not even the menus or input designation that is usually in the upper left hand corner.
There were no indications that this anything was wrong until the picture stopped. No color or sound problems, a typical 5 second warm up time which I assume is normal.
I've taken apart the back of the set and cleaned out the dust with compressed air. Checked the 2 main ceramic fuses (T5H250V) that I could find and they pass an ohm test. Not sure where to look next.
I'm fairly mechanical and this seems like it shouldn't be that difficult. Okay, I'm actually just hoping that I don't need to spend $300+ in order to watch Scrubs again. Is there hope?
What are the next steps I should take?
Thanks for any input.
  • 1 more comment
  • Michael Nesis Jul 02, 2008
    Excellent suggestion, that was pretty in line with the posts I was reading. Now, where is that? I'm looking in the back of my set and there are 3 main boards. A thin one to the right where the power cord comes in. A large one in the middle that has the big transformer looking thing on it with thick cords that run to the tubes/lights(flyback). And lastly an equally sized large board that has the connectors (red,yellow,white; s-video; component).
    From what I've read so far, the vertical output IC is on the middle board (with the flyback) on the lefthand side towards the front of the TV.
    Is that right?
    okay, just going to check it now. I just felt that I needed to tell you how great it is that there is a message board like this and you are pretty killer being able to give directions on this. thank you.
    By the way there will most definitely be another question after this.
  • Michael Nesis Jul 08, 2008
    Okay, With your help I found the heatsink that the IC is attached to. Took me a few days to get the circuit board out. Who would have thought that they held it in with screws. So now I've taken the board out. Most of the connectors were pretty easy, but I did have a bit of an issue with the wires on the flyback. Hopefully the wires when removed are supposed to look like a spark plug wire when you pull it out of the boot. (about a quarter inch of bared wire at the end) Is this right or did I just break that too? I've already ordered the part and did verify that it is stamped with TDA8177. Should be a couple more days until I get it in. Any hints on the desoldering/soldering of the piece? Looks pretty straight forward but I've never done components like this before, just soldering wires together.
  • Philips Master
  • 8,617 Answers
Rear projections have a safety feature built into them that shut the picture tubes off when they experience vertical deflection problems, the audio will still work. i would recomend first trying to resolder the vertical output IC. If that doesnt help, the next thing would be replace the Output IC and if that doesnt do the trick you may need a deflection Board known as the LSB for your model. Let me know if I can assist you further.
Posted on Jul 01, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Jul 02, 2008
    If you look at the flyback you will see two large heatsinks right next to in line with the flyback. the vertical IC is on the heatsink farthest from the flyback. It will have TDA8177 stamped on it. its closet to the left side of that board with the flyback and even in line across from the flyback. It will have a liitle clip holding it to the heatsink.
  • Sonny Berry
    just let me know when you need help.
  • Sonny Berry
    Sonny Berry Jul 08, 2008
    no the wires are susposed to have the bared wire on the end. Some de-solder braid may make removing the old solder frem the IC to aid in the removal of the old output IC, or Radio Shack has a de-soldering Iron that works best.
I have a 99 Subaru legacy. Recently after putting a new axle in it started thumping real bad. No matter what speed,hot or cold it thumps loud. Sounds like something is rubbing. I've had many people try...
You need to put it on a lift, or four jackstands, and start the car and put it in gear and look under the car while the wheels are turning. I am guessing one of the joints on the axle is stiff, causing the axle to flop a bit.
Jan 24, 2013 | Cars & Trucks
Tcl tv freez no sound/picture
are you using a cable box, tried to reset the box.
Oct 13, 2012 | TCL L32D20
Audio Issue
Hi Sharon,
I have the same exact TV and the same exact problem....except today the screen went black and I no longer get a picture from any source. I've had the TV for exactly 13 months. IF you've had your TV for less time, I'd return it.
Jul 20, 2012 | Toshiba 55G310U LCD TV
Re, all i get is a distorted picture of the game screen. I've tried fine tuning the TV around that channel but it doesn't help.
hi sounds like the av sender inside the ps could be getting dodgy, have you tried it on another tv?
Apr 07, 2012 | Sony PlayStation (PS) Console
I have no picture
Hello
You haven,t specified any thing about the sound condition. If sound output also is absent, the amin baord of your Hisense TV is faulty. To make it sure, you have to check the set by refereing its repair book. I've this doecument, but I can't upload it to you by this window, as it does not allow me to upload it to you by this. If you are interested, inform me by Fixya comment box. I'll give you instructions to be followed. OK.
Dec 18, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
My HTD HD7 has suddenly decided to not respond to any touch functions whats so ever. The screen nore the three function buttons at the bottom register any touch. The remaining buttons, power, volume and...
I'm having the exact same problem.
An hour ago I was using my phone fine, and then it randomly shut off and turning it on again I have no touch function, while the volume and power are fine.
I've done everything recommended, much like you and having no luck :/
Oct 10, 2011 | HTC HD7 Cell Phone
No picture but still has sound. switch off and picture comes back
i haven`t got a solution, however mine has just started to do the same. can you let me know if u got the problem solved. thanks
Jan 31, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Numbers on my tv screen
It sounds like your tv has a programming problem not to do with the remote but the actual tv you will have to take it in to get repaired or you just might have to buy a whole new tv
Mar 20, 2008 | Universal Remote Control Remote Control
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
