Question about Mitsubishi WD-52525 52" Rear Projection HDTV
DVD's play in black and white
The DVD device is somehow stuck on black and white. Cable is in color, it's only the DVD device that seems to be affected. Even the DVD "blue" screen is in black & white, which suggests to me that it is the TV and not the actual DVD player. I can't find anything in the manual that even begins to suggest that this could ever happen. I'm sick of messing with it. Please help.
  • 51 Answers
Anytime you connect componet signal (green red and blue)to regular video inputs (yellow) end will have same effect. make sure that if you are using component signal from dvd player you have to connected to component input in the set.
component signal will use green red and blue for video and red and white for sound.
Posted on Jul 02, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Will only play DVDs in Black and White
Onkyo DV-CP706B 6-Disc DVD Player (Black) - Amazon.com
www.amazon.com/Onkyo...Player-Black/.../B001AMS...
Amazon.com, Inc.Color: BlackChange .... It's quieter than it was before, and it plays ALL DVDs, even if you can see some visible damage ..... THere was no color-just black & white.
Onkyo dvd player no color only black white Questions ...
www.fixya.com > Forum > Tags > dvd player no color only black white
Onkyo dvd player no color only black white related problems. Ask your Onkyo dvd player no color only black white questions. Get free help, advice & support ...
Onkyo dvd player plays black white Questions & Answer
Dec 29, 2015 | Onkyo Dr-s2.2 5.1 Dvd Home Theater...
When playing a dvd it black and white no color
what output connection are you using? (svideo can cause this if it's not properly supported on both devices)
What format is the video stream NTFS or PAL? some devices don't like one or the other format. This issue could be linked to your dvd player or your TV so please investigate what I have suggested and post back here if you have no luck :O)
Jan 30, 2010 | Bose Lifestyle 38 System
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Install s-video cable now dvd is black & white
you might have a bad cable just because you get a great picture but no color.i would exchange the cable where you bought it and try another one.
Dec 06, 2008 | Toshiba Cinevision DVR2000
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
if you are using S-video cables for your video, try replacing the cable. svideo has 2 lines in it, one for color (chroma) and another for brightness (or black and white-ness (lumina) if one of those little pins is broke, or missing, or the cable is bad, this may be the case.
Aug 13, 2007 | Sony DVP-C660
DVDs Play in Black and White
this may be the problem with your dvd player
Feb 14, 2007 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
