Question about HP Pavilion N5150 Notebook
Blank screen on pavilion n5150
I turn on the pavilion and everything works, except the screen which would be great, how do i get it back on or what could some problems be that i could check into?
Mine does not work with an external screen......
and it turns off after afew minutes....
please help!!!!!!!!!!
thanks in advance
Posted on Oct 01, 2008
    Genius:
  • 2,028 Answers
Use an external monitor to check if you have a bad screen or deeper problems. If the machine works properly with the external screen, then your screen is out and needs replacing. If it doesn't work, then you have other issues. in the latter case, let me know and I'll see if we can figure it out.
Posted on Jul 01, 2008
I am new to the video world and just purchased a Canon HF S200 from a guy here locally it is used but looked to be in great condition and working properly. But less than 15 minutes after the purchase and...
Have you got the user manual? If not, you can download it from www.iusermanual.com.
I am not familiar with you videocam but the mannual shows all of the buttons and functions etc. There are what appears to be at least one critical button on the outer edge of the LCD screen itself. Perhaps this may affect its functions and be causing your problem.
Anyway, have a good look at the manual and be sure you understand the functions of the buttons.
Because everything else works OK it is most likely caused by pressing the wrong button at the wrong time. Alternatively, there may be a bad contact at the connection between LCD screen and camera.
May 31, 2011 | Cameras
I just got a Toshiba T135 laptop just this week and so far so good, except for one thing. Whenever I shutdown the laptop and leave it for over an hour or so, and turn it back on, everything turns on (as in...
This is not normal behavior for this model of laptop. I would contact the manufacturer to have it repaired under warranty, as this is likely not a software issue.
Mar 14, 2011 | Toshiba Computers & Internet
Hi sir/madam, My laptop's screen doesn't turn on. I thought the screen is gone n need a new one but after trying to turn it on like ten times it turned on everything was perfect but when I tried to restart...
Hi if you are getting nothing at all from the lcd screen (black screen with no cursor or icons) there are two possible causes 1st is the LCD itself it starting to worn out or sometime it is just the simple wire connecting the LCD to the mainboard to get the display that needs to be replaced.
If your getting a black screen with blinking cursor and you can still see the hp logo at startup you just need to update the video card driver of your laptop.
Have the HP check first the hardware side of your system so that they can replace the broken parts. thanks
Jan 14, 2011 | HP Pavilion dv9000z Notebook
I run my DV 9428 for a while and everything is working great then the mouse pointer freezes up and I sit back and watch the screen go cloudy until the screen is totaly white. Then sometime after a min. or...
Do you run a decent anti virus programme like Norton? It could be a virus causing that problem. If it were the laptop I would expect it to crash and not recover.
Hope this helps.
Nov 16, 2010 | HP Pavilion dv9428 Notebook
What is the default password bios of the HP
There is not default password as such but it comes up only when it is created.In order to get rid of the password we need to boot the computer to the BIOS .
Turn the notebook off and then when you turn it on or lets say as soon as you press the power button to turn it on start tapping the f10 key on the keyboard repeatedly till you get a screen that says BIOS SETUP UTILITY ,once you are on that screen press the f5 key on the keyboard it displays a mesage that says load default,press y for yes on the keyboard and then press f10 that displays a message which reads save and exit again pres y for yes and the computer restarts .Once it boots up should not for the bios password.
hope this helps you ...all the best
May 21, 2010 | HP Pavilion N5150 Notebook
Hp 99dv30us, screen is blank
Common issue you will have to reflow the GPU or replace the motherboard. Check out www.msbin.com for a diy guide.
May 14, 2010 | HP Pavilion dv4000 Notebook
Hp 99dv30us, screen is blank, computer shut itself down, I restarted it and everything seemed to function except the screen.
Plug an ext monitor into it. If you now see desktop the monitor is faulty.
If still no go,onboard video is faulty / vid card
Mar 16, 2010 | HP Pavilion dv4000 Notebook
Computer works fine but has a blank screen. I have it hooked up to a monitor right now and it is fine except for the blank screen.
can you see anything on the screen at all? Look very closely at the screen from different angles under a strong light and see if you can see a faint image on it. If you do it means the back-light is not turning on which is usually a failed inverter board (cheap and easy fix). If you can't see anything at all on the screen then either the cable is not seated properly or is bad (not very common) or the screen itself went out (more expensive repair)
Feb 26, 2010 | HP Pavilion dv5-1125nr Notebook
HP Pavilion N5150 Notebook Logo
113 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
