Question about Canon EOS 400D / Rebel XTi Digital Camera
I have a new canon eos 400d and it wont recognise any cf card keeps saying card error and when i try to format the card it reads'err99' also i have lost all of the photos from the card that i was using before this started
  • merking Jul 02, 2008
    i have tried using 4 other cf cards and the camera response is the same every time, it continues to read 'cf card error' all of the cards cant be corrupted does anyone know what might be wrong before i send it back to england to be fixed, please
    the camera wont read the card and keeps giving a message' cf card error' this is the same with every card that i have tried, the original card has lost all data even when i tried to upload to a computer via a card reader
    Guru:
  • 1,342 Answers
Err99 is a generic Canon error code. It does not pin point the problem it is just telling you there is a problem. Try turning it on without the card. If you still get the error it may be the lens or some other issue with the camera.
Posted on Jul 02, 2008
  • Georgia B
    Georgia B Jul 02, 2008
    Error Message:
    CF card error!
    Translation:
    This
    error can occur when using a CF (Compact Flash) card that is greater
    than 32MB with some models of Canon cameras. If the CF card is
    formatted in Windows XP, by default, Windows will use a file format
    that is not compatible with your Canon camera.
    Solution:
    According
    to Canon, there are two ways to resolve this issue. First, if you are
    formatting a CF card greater than 32MB in size in Windows, change the
    File System menu to FAT. A card formatted using this format should work
    without error in your camera.
    Alternatively, you can also
    reformat a CF card using your Canon digital camera. Each camera will
    require different menu steps to reformat a card, so refer to your users
    manual. If in-camera formatting fails, try removing and reinserting the
    CF card into the camera and reformatting again.
    Source: Canon
  • Georgia B
    President:
  • 1,257 Answers
If the card has images in it, a damaged file could be the source of the problem; try to download the images to your computer using a card reader and search for a corrupted file/image. If none could be found it still could be a file matter, at least you saved your images (if you succeeded in dowloading them).
Clean the card pin-holes with a camera blower, check that the card is dry and/or not overheated. Leave it rest for some 10/15 minutes wrapped in a soft cloth with some silica gel and give it anoteher try.
If the above didn't work, it is now time to format your card, using your camera or your computer application of choice and put it back in the camera. Is the camera now working? If not then the card still has problems. Try to find another camera to test that card on, if still doesn't work then that card has probably died, unless there's a specific incompatibility between that card (brand/size) and the camera you tested it on. Refer to the card help manual or manufacturer's assistance to know more.
Posted on Jul 01, 2008
  • 405 Answers
You could also try cleaning the contacts in the card slot and on the card with isopropyl alcohol(rubbing alchol). If this is caused by dirty or bad contacts this may work.
I wish you luck
    Genius:
  • 3,422 Answers
HI,
There are two solutions which can fix this problem:
1)Format the memory card which you've already tried.
2)Replacing it with new batteries.
  • Priya darshan Jul 01, 2008
    Please try replacing it with the new batteries once.
    "Memory Card Error" is usually related to a a faulty battery.
    Master:
  • 848 Answers
Is your prblem that your card is not detected in camera or it is not getting detected when connected to pc .
    President:
  • 2,712 Answers
It looks like the card is corrupted, and the only solution here is to go in for a new one. Unfortunately, there isnt any much more you can do..
Canon EOS 400D - Error message - There is a problem with your CF card- needs replacing. We have original card and also replaced with new card - message keeps appearing. What else could this mean?
Look inside the card compartment to check for broken or bent pins. Have you tried formatting the card in the camera? This will erase it so download any pictures first using a card reader if necessary.
Oct 06, 2010 | Canon Cameras
Windows XP wont dowload ALL images from my Canon EOS 400D
Your canon must be making multiple folders on the card and the computer is only reading the first one. Use a card reader to download your pictures.
Aug 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d. card empty but cf light flashes red
Hi! Rachel, Mark here see if i can help.
Try different cf card see if it works.
Next if that worked or not take cf card place in computer & format card. Retry in camera.
Hope that fixed ya if not comment back me happy to assist you further. Good Luck! please rate.
Mar 15, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Camera won't turn on
Does the camera do this with any CF card? If you've tried another CF card with the same problem, check in the slot that the CF card fits into with a strong light to make sure no pins are bent and touching each other.
Also, was the card formatted with a Windows 2000 or Windows XP system? If you format with Windows, make sure you specify FAT32 as the file system (rather than NTFS).
Err 99 is a 'catch-all' error message that is non-specific. It indicates that the camera detects an error within its operating system, but cannot determine the specific reason.
In summary, try another card. If you get the same error, and no pins are bent, you probably need to have the camera serviced.
Aug 31, 2008 | Canon EOS-20D Digital Camera
CF Card
Please post back the error message you notice.
Mar 22, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Error99... pls help!!
here is a link for further steps to take on Error 99: Canon info
The article refers to the 30D, but the same troubleshooting will work for your camera too
Feb 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
CF error
My canon xti had the same reading cf card error 99.
Since my camera is out of warranty. I had to find a way to fix it. After reading all possible solutions in this site, I looked at the pins (that used to connect to the CF card) and found out that one pin in the middle bent. That caused the problem. I used the tiny screw driver to bend that pin back to the original position. Inserted the card back and it worked. I felt so happy!!!! (Please make sure to have the battery removed while fixing...to be saved.)
Dec 28, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
