Question about HP Pavilion ze4300 Notebook
Keyboard k key seems to be stuck
Anytime that I go to the address of attempt to write in word the page is filled with k's I would like to know how to remove the keyboard so that it can be replaced
    Genius:
  • 2,028 Answers
Laptop keyboards usually come off two ways. 1- remove the screws on the bottom of the machine, sometimes marked with a K. It's always better to remove too many screws rather than not enough. It won't hurt anything as long as you get them all back in. 2- the screws are located under the power button strip at the top of the keyboard. The strip just snaps into place, lift one side and work it up and off. I would start here, since the strip is easy to take off. Here is a couple of links that have diagram. You may be able to find a breakdown diagram for your machine.
http://repair4laptop.org/notebook.html
http://www.eserviceinfo.com/service_manual/datasheets_d_600.html
Posted on Jul 01, 2008
The letter "g" keeps filling up my password spot. I checked the keyboard and the letter doesnt seem to be stuck. Have you ever seen this before? Can u help?
they key may not look stuck, but if something sticky, or a piece of debris got under it, then that would cause it. if it's a standard keyboard, you might be able to pop the key out and look under it. before you do that though, what type of keyboard is it? laptop or PC?
Oct 03, 2017 | The Computers & Internet
When I try to type in an address, it just keeps saying HHHHH. What can I do
It seems like the H key on the keyboard is stuck, you can check for it or else you have to try with a new keyboard.
Oct 18, 2013 | Computers & Internet
I have a new acer netbook. In attempting to type an email address, I cannot type the @ symbol. It comes up as ". There are green symbols and lettering on some of the keys. HELP!
Where did you buy your Netbook?
What language or locality have you chosen for your system?
US keyboards have @ on the shift 2 key
Various other keyboards have " for shift 2 - these include various European and Latin American layouts. You need to specify a locale that matches your hardware.
This useful page may help you for your setup.
http://www.terena.org/activities/multiling/ml-mua/test/kbd-all.html
In Windows you can adjust settings from
Control Panel\Clock, Language, and Region\Keyboards and languages
Jan 10, 2011 | Acer NSK8458AN Keyboard
Left click key doesn't bounce back when clicked. Seems stuck
The key is stuck you have to be very careful if you are going to attempt to repair this.Turn the computer off and remove the battery before you attempt to repair it.Try prying it up with a thin knife blade.If this pops up and is working make sure it works as good as the other side.If not you will have to replace the palmrest.
Good Luck
Mar 21, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Keyboard problem with an Asus Pro Series 31: Running Vista Premium
Hey,
According to me one of his keys is function keys (like : Fn,Ctrl,alt,shift) is stuck or gets stuck now and again , so whenever in msword u try and type nething its actually getting pressed ctrl + something, and hence weird functions keep on popping.
This generally happens either when he has spilt milk/water ne other liquid onto the keyboard, Solution to this would have to replacement of keyboards(Some keyboards are designed in such a way that liquid can be removed from then but i don't really know how).
Another reason would be over/improper use of the keyboard and particularly those keys causing them to get stuck
solution in such a case would be to remove the particular key and try cleaning it.
This problem is pretty common in laptops all you can do i use more carefully...i dont think there is any fool proof solution.
Cheers
Kushal
Aug 27, 2008 | ASUS A6U Notebook
Keyboard not responding or typing random letters
You have stuck keys from when you removed to clean. Remove the stuck keys and see if it works OK when you press the rubber cap instead of key
The back space one may have a link under it if it is a wide one ensure it is fitted correctly
Aug 09, 2008 | HP P2360AA Keyboard/Mouse
Backspace doesnt work
in all likelihood your shift key is stuck. try pressing and releasing both shift keys in an attempt to "free" them. Also, check to ensure that "sticky keys" is not enabled on your computer(pressing and holding the shift key for about 10 seconds should pop up a window if it is. if the window appears, just make sure that the key is not "stuck" by windows).
Solution: mechanical agitation for your shift keys to attempt to free them, and a good thorough cleaning for all of your keyboard with canned air and/or a lint free cloth damp with dilluted isoprophyl alchohol to prevent this from happening in the future with these or other keys. Alternately, replace your keyboard.
Jun 29, 2008 | Logitech Cordless Desktop EX110
Keyboard & Mouse Problem
Seems like you Ctrl-key is pressed all the time somehow.
Make sure that none of the Ctrl-keys is stuck.
If you try another keyboard, everything should work fine, so just check your keyboard. Maybe you need to replace it.
Apr 14, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard data entry
Sounds like a classic problem for a driver/firmware update. get an update here before trying anything else- http://www.palm.com/us/support/downloads/tungstenc/tungstenc_update_30.html If it still doesn't solve it you might need to format it and reinstall everything from scratch. Good luck
Apr 22, 2006 | Palm Tungsten C Handheld
HP Pavilion ze4300 Notebook Logo
170 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
