Question about Maytag Neptune MDG5500AW Gas Dryer
Too long to dry my clothes
I have heat but not hot enough it takes way to long to dry clothes i have cleaned the lint out under and inside and still problem help please I have the same problem (long drying time on my front loading Maytag Neptune gas dryer) and I've checked the venting and cleaned out the entire route from the internal lint collector to the outside vent and it is all clear...the dryer seems to heat okay and the drum is turning so the only thing I can think of is that the humidity sensor is turning off the heat too soon in the cycle. Has anyone else had this problem? Any alternative suggestions as to cause/possible solutions?
  • 6,487 Answers
Stop using your dryer and check every inch of your exhaust duct. If you have lint build up, or a bird/rodent nest so the air cannot exhaust, this would make your clothes not dry on time. It can also start a fire. Also, make sure that the vent on the outside of your house is un-obstructed.
If the vent is clear, your dryer may need repair. This happened to me last year. The dryer got hot, but I noticed the clothes were not tumbling. The belt had slipped off the cylinder. It took me about 10 minutes to unscrew the back of the dryer, put the belt back on, and replace the panel. Free and easy, just make sure it is unplugged before you do anything.
Check also this link http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Hope that helps............
Posted on Jul 01, 2008
    Genius:
  • 3,422 Answers
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Frigidaire gleq442ces0
I had this same problem 3 weeks ago, and here is what I found.
The dryer was so clogged with lint it could not dry the clothes. I had to take the whole machine apart and clean all the lint out. I found the felt around the drum was worn out, and that was allowing the lint to go everywhere it shouldn't. With the felt replaced and the lint gone, it worked well.
Be blessed.
Jun 23, 2013 | Dryers
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
Dryer won't get hot enough to dry clothes
mAKE SURE THE VENTING SYSTEM IS COMPLETELY CLEANED OUT. a MOISTER SENSOR DETECTS ANY BUILD UP OF LINT CAUSING TO KEEP THE HEAT IN CHECK WHICH TAKES LONGER FOR THE CLOTHES TO DRY
Jun 13, 2010 | Hotpoint NBXR463EBWW Electric Dryer
My dryer is heating up but it takes a long time to dry.
If the clothes are coming out wet and hot after the first cycle then there is a blockage in the exhaust. This blockage could be at the lint trap or at the exhaust tube leaving from the back of the dryer. You need to check the lint filter area by removing the lint filter and with a flashlight look into the area where the lint filter was to see if there is any build up of lint. If so, you will need to clean this area. Also at the back of the dryer there is a hose that comes from the dryer to an outlet to the out side. This hose could be clogged with lint or possibly kinked to where the proper amount of air flow is not allowed to leave the dryer therefore causing the clothes to have to dry longer. Check these two areas first before going any further due to these checks are simple and may solve the problem.
Good luck hope this helped
Dave
Mar 30, 2010 | GE DVLR223 Dryers
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
My ge dryer takes 5hrs to dry a load of clothes, it seems hot enough inside when i open it but the clothes used to dry in 90mins or so now its hours
Have you checked your lint filter? Do you empty your lint filter after every load? If it is hot inside the dryer then the most likely suspect is a clogged exhaust vent. Check the lint filter, if it is clean pull the dryer out from the wall and disconnect the exhaust hose. You may have to clear out the exhaust hose...compressed air usually does the trick. After you have done this, put everything back together and your problem should be gone.
Sep 17, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
LONG dry time is an indication of a clogged or restricted exhaust. Clogged or restricted exhaust is the primary cause of failure in all residential dryers. Blowing the the system with a shop vac is only a temporary solution. The system needs to be cleaned (2 to 3 times per year) with a rotary brush to scrape lint collecting from the sides of the pipe. Suggest going to Lowes and purchasing vent cleaning kit. Read instructions CAREFULLY. Also consider replacing flexible plastic or foil pipe with rigid metal type. Dryer will vent 30% to 40% better. If condition persists for too long, a high limit fuse mounted on the heater will open causing the heater to no longer operate.
May 03, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
345 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
