Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
I need to change the blade, but am unable to loosen the nut holding the blade in place. the nut and square spacer underneath move together.
  • jrevcvo Jul 06, 2008
    i'm having a similar problem except my blade is loose. i cannot tighten it because the nut and bolt turn together. i took the motor apart and tried using a vice grip on the bolt, from the top of the mother, but the blade and nut still turn together.
    Champion:
  • 313 Answers
You need impact gun.air or electric operated impact,run it reverse. it shouldn't be loose like that. i am guessing the armature drop could be the ring is out of the armature groove. ring are located inside the motor assy.
Posted on Jul 06, 2008
Why does my blade not sit straight on my Milwaukee jigsaw
First, with the power cord unplugged, check the squareness of the blade to the saw with a square, adjust the 'foot' of the saw (the part that sits flat on whatever you are cutting) to be 90 degree with the blade. To do this, usually on the back of the saw there will be a nut or a screw that holds the foot in place. Loosen it, and move the foot until the blade and the foot both touch the square along the entire surface of the blade and the saw 'foot' and retighten the foot. Many jigsaws have this problem.
Oct 18, 2017 | Blade Saws
How do I change the blade
Unplug the saw. I repeat, unplug the saw and then lift the guard all the way up. Set the teeth of the blade in a wood board to keep it from moving and then loosen the blade. If that doesn't work, go to a bike repair shop and ask to borrow/rent a thin wrench that fits behind the blade. Probably a 3/4 or 7/8" wrench. Use that to hold the blade secure then loosen the blade nut.
Sep 13, 2014 | Saws
10 inch table saw blade not square with table
Sounds like the bolts that hold the motor assembly on the table may be loose allowing the blade assembly to move. Look underneath the table and clean out all the dirt and loosen all the hold down bolts and realign the blade and tighten back up.
Oct 25, 2011 | Craftsman 10" Table Saw
How do you change the blade on a miter saw
first unplug the tool, raise the head and loosen the bolt that holds the lower guard in place. DO NOT disassemble the lower guard, pull it down and it will move out of the way somewhat. Next there is a spindle lock that you push in rotate the blade until locked and hold it while removing the hex bolt, which should be left hand thread, I would use a pair of gloves when holding the blade just for safety. Remove the outer flange and spacer (if needed) reassemble in the opposite order and before trying rotate the new blade by hand to make sure turns freely. Let me know if you need more assistance.
Feb 16, 2011 | Saws
How do you keep the blade from moving while you loosen the nut to change the blade on a Troy-Built 9" lawn edger?
stick a block of wood inbetween blade and sheild or spacer behind blade may have a hole to put a punch or nail to keep from turning. hope this helps
Aug 14, 2010 | Garden
Shaft turns while trying to remove blade on B&D MM875 elec. mower
Here's the scoop on the MM875: it has a plastic piece called a "blade insulator" (part # 241381-01) that "locks" the shaft to the blade, so that you can remove the nut by stopping or blocking the blade. If it has been damaged or stripped out, then stopping the blade won't do anything. However, the metal spacer directly under the nut IS still locked to the shaft (because of its shape), so you can use a pipe wrench or something to hold that in place and unscrew the nut. You might even be able to get someone in a home improvement store to do this for you. But you will still need to replace the insulator, which is only a few dollars.
Jul 22, 2010 | Black & Decker 19" Electric Lawnhog...
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
Have a 12 inch tradesman miter saw and can not change the blade
the nut maybe a left handed thread. the norm is righty tight. lefty loosy, try the oposite.
Apr 09, 2009 | Saws
How do I remove the old broken lawn mower blade. I can't seem to keep the bolt and nut from moving together when I try to loosen the bold. thanks in advance
i uses impact gun with 3/4 " socket.run it in reverse or you have to remove the stationary parts of the motor.mark them so u will know how to put them back together & somebody has to hold the armature will u r turning the nut on the blade.
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
Black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
May 19, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
105 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
