Question about Uniden TRU9480 Cordless Phone
Phone battery cover disorder
The back cover to the battery pack will not close properly on one side. We have changed the battery to lay with one wire on each side, but nothing works. I really do not want to take it back to Wal-Mart if it is not necessary. Thank you. jansolorio@yahoo.com
    Sergeant:
    Champion:
  • 306 Answers
The wire goes down the middle of the pack and not the sides. tpo or bottom it doesnt matter
Posted on Jul 02, 2008
How to activate a vtech phone
Instructions
    • 1Remove the battery cover from the back of the phone. Most models have a door that slides downward to reveal the battery compartment.
    • 2 Install the battery by inserting the connector on the battery wires over the pins in the handset battery compartment. The connector will only go on one way.
    • 3 Insert the battery pack into the compartment and replace the battery cover.
    • 4 Charge the phone by sitting it in the charger for a minimum of 16 hours on the first charge.
    • 5 Place the fully-charged phone onto the cradle of the base unit and wait for the display to show "PRESS FIND HNDST 4 SEC ON BASE." If the message does not come up, lift the phone off the base and put it back in the cradle.
    • 6 Press and hold the "FIND HANDSET" button on the base unit for approximately four seconds. The display on the phone will change to "PLEASE WAIT," then "HANDSET X REGISTERED."
    • 7 Test the phone by making a call.
Jul 14, 2014 | Vtech Lands Phones
Do the black & red wire underneath the speaker phone be connected & wher to
If you are talking about the compartment on the right side of the base of a Motorola M681, then you do not have to connect anything. You can add an optional battery (the same battery pack as for the handset) to keep the phone working for a few hours during a power failure. (If the wires have been pulled loose, than the backup battery might not work. However, I'm not familiar with the wiring for this model.) The handset battery must be properly inserted and charged for that to work.
You also must plug in the AC power cord (to the phone and a good outlet) and the telephone line cord.
I hope this helps.
Dec 16, 2011 | Motorola Mobility MD681 Cordless Phone
Brand New Phone won't charge
Apologies for asking the obvious, but have you removed the battery cover on the handset to ensure that the battery pack is connected? There should be two wires from the battery pack, black and red, which terminate in a plug. That plug must be securely fitted into the corresponding socket inside the handset.
If that is all OK, then I suggest you swap the battery pack from the working handset and see if that works in the one that will not charge. By doing this you should be able to determine if it is the battery at fault, or the handset.
Mar 08, 2010 | Uniden Cordless Phone
New out of the box wont power on
Hi.. Let me try to help you if I can... I'd like you to check a few things,
1) Open battery cover on handset & make sure that the battery pack is installed correctly, and not upside down. Also make sure the little wires that come from battery pack are plugged into the tiny jacks of the phone (usualy red & black wires) in handset is fully attached & pushed snuggly into the handset... and if No wires, check to ensure the part that does connect the battery to handset is not covered with a plastic film of tape or paper as right from a manufacturer they sometimes do that to preserve length of battery until product is sold to you..
2) Check the bottom of the handset phone, that sit in the cradle of the electric part of the recharger, and make sure there is nothing like plastic or paper covering the connections between the bottom of the handset and the charger. Make sure there is a full on connection for a full charge to the handset. As with some cordelss phones Ive had the red LED light will not come on if there is something blocking a full connection for a charge.. The red LED light on base, only comes on when the electricity is flowing into the handset. The slightest tilt not allowing handset a full charge, wont give it a FULL charge.
3) You say " NEW. Out Of The Box" I hope when you connected the battery pack into the handset, and made sure it was connected right, you then allowed handset to charge at least a FULL 12 -24 hours before trying to use your new cordless phone. as the batteries right out of the box, are rarely already fully charged when any cordless phone is bought and then it does need 12 - 24 hours for a FIRST FULL CHARGE...
If you can check all 3 of these questions, and let me know how things are back on this posting, if you stilll can not solve the problem after a full charge to battery, I may have some other ideas that can help.
Good Luck
Stevie
Feb 14, 2010 | Uniden Cordless Phone
I have a cordless KX-T7885 and can't get the battery to charge. i replaced the batteries and both phones but they both will not work. They sat for two years and I have just recently tried to use them. They...
If you have a multi-tester, check the voltage on the battery packs. The voltage should be equal to or greater than the voltage listed on the battery pack. If the voltage on the packs is too low, either the battery packs are defective or the charging systems of the phones are not operating properly. If the phones are not charging properly, it is likely not cost effective to try to get it repaired.
Oct 10, 2009 | Panasonic KX-T7885 Cordless Phone
Screen is not readable- thinking it's the battery
Have you tried to adjust the contrast on your display? If that doesn't help chances are its your battery.
how to change battery:
Remove the battery compartment door, the bottom half of the back, should slide down.
Disconnect the cord attached to the battery pack and remove the battery pack from the handset.
Insert the new battery pack and connect the cord to the jack inside the battery compartment.
Put the battery compartment door back on.
Jun 18, 2009 | Uniden Cordless Phone
Vtech 2656 cordless phone battery not charging
You need to replace the battery pack. Wal-Mart, Best Buy, Circuit City and a few other stores may carry this battery. Just call them first so you don't make a wasted trip.
Mar 26, 2009 | Vtech V2656 Cordless Phone (vtechvt-v2656)
The 3 5 9 and # buttons on my sony ericsson w200a aren't working properly. instead of the digits and letters coming up that are suppose to when you push them different screens are coming up. this problem...
there might be some short circuiting happening inside your phone. try letting the phone dry using your regular hair blower before turning it on again.
note: remove first the battery, sim pack, and outer covering before drying your phone
Aug 09, 2008 | Lands Phones
5.8 GHZ Motorola Cordless Phone, Base w/1 additional phone
This is not a problem with the battery but rather the phone has lost sync. You can get it back by going to the menu screen then going to register. The phone will walk you through from there. Mine lose sync from time to time and I get the same error. I have these phones both in my shop and home.
Hope this helped you out...
Feb 09, 2008 | Motorola Mobility MD41 Expandable Handset...
Uniden TRU9480 Cordless Phone Logo
53 people viewed this question
Top Uniden Lands Phones Experts
Dave Ellis
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
