Question about Garmin nuvi 200W GPS Receiver
Nuvi 200w When I turn on the unit it says, "loading maps", then it goes to a small picture in the middle of the screen with a picture of the nuvi and a wire going to what looks like a computer box. That is all it does. HELP
    Scholar:
  • 162 Answers
If you are not connected to a computer, there may be a small pin hole on the back of your unit marked RESET. Try that first and see if that doesn't help. Next call Garmin.
Posted on Jul 25, 2008
Hard format nuvi 245w
Downlaod software from this link RMPrepUSB and chose settings from this picture
Jul 24, 2015 | Garmin Nuvi 200 200w 205 205w 250 250w 245...
When I turn on my nuvi 200 I get the message "no
If you got the unit from somebody they could of used a SD card and its looking for it and the ynever switched back to the regular map... to check try this..
Settings ... Map.... on he bottom of screen you will see Map Info .. press it.... it should now say what map is loaded on the gps...
It should have a checkmark in the City Navigator North American NT, if not put one there
Nov 04, 2010 | Garmin nuvi 200W GPS Receiver
My nuvi 205 touch screen is acting up
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 01, 2010 | Garmin nuvi 200W GPS Receiver
I have a garmin nuvi 200w and want to download any updates
I'd be interested in this too. I have a Nuvi 200W loaded with US maps. I'm now in Australia and would like to load Australian maps but can't find them.
Feb 19, 2010 | Garmin nuvi 200W GPS Receiver
On Start up Garmin 255wt goes to screen Can't unlock maps
you may not have installed the maps correctly. that error is shown when the maps have not been unlocked properly ( the license for the maps was not allocated to the unit correctly) go through the map install process again.
Oct 11, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 not charging
I also have a Nuvi 200 that didn't charge. The problem is the charging port disconnected from the circuit board. You can disassemble the unit and reconnect the charging port but it takes a small torques wrench and a small screw driver. You will also need a soldering iron preferably with a fine tip and a very steady hand. Good luck.
Sep 24, 2009 | Garmin nuvi 200W GPS Receiver
Unit goes into computer mode when I plug in the car charger lead. I go through the 'loading maps' screen, then the PIN screen, and it defaults to computer mode and I can't get any maps to show.
The rear mini-USB port is defective, making the unit think its connected to a PC. The port needs to be resoldered or replaced. Please see this link:
See the section about the PC icon.
http://www.sharc.net/gps_charger_repair.htm
- Jim
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
WHAT IS SD CARD FOR??
Hello TRICOUNTY,
Your Garmin GPS has an SD card slot. You can use this slot to insert a removeable SD memory card into the unit SD memory cards for used for storage by many portable devices. The most common useage for the GPS is to view pictures taken by a digital camera (which also uses an SD card) with the GPS's picture viewer function.
I am not sure what the ads you are referring to are. Where are you seeing the ads? On the GPS screen? After inserting a SD card into the GPS?
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 22, 2008 | Garmin nuvi 200W GPS Receiver
NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
May 24, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
216 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
