Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
Posted on Jul 01, 2008
Connecting Laptop to Samsung HL-R4266W
I cannot for the life of me get my DLP to talk to ANY laptop. I have a Sony Vaio and also a Dell. They are older so I am using the S-Video inputs. Have tried holding Function F8 down. tried tapping it,... Have gone into the monitor thing in the control panel and none of it is working. I continually get the error message that the signal cannot be found or has been lost... Am I doing something wrong?
A
Anonymous
I right-click on the desktop > properties > settings > advanced > diplays and select the desired output. (on my toshiba - mmv)
Sony vaio laptop unable to detect new hard disk
Try connecting the drive to another pc with a usb adapter, create a partition and format it. Then put the drive back in the vaio and reinstall windows. This should fix the problem.
My Samsung DLP TV HL-R4266W is making a noise when I Turn it off. It sounds like the fan is rubbing on something. I took the back off and all 3 fans look fine. Could the noise be the Color Wheel and is...
Yes, the Color Wheel would be the only thing left. I am not sure about this exact model but the Color Wheel in other Samsung models are replaceable.
Hope this helps,
Skyassoc
Samsung HL-R4266W 42 shutoff
have the power supply checked it may be faulty
9helpful
3answers
SONY VAIO BATTERY CHARGING
This is not a problem, this is a designed function to increase battery life. To adjust this, go to "vaio control centre", and then power management. Inside this is battery care, here you can adjust the settings or de-activate this function.
Firephox
Connecting a sony Vaio vgn-fe570g laptop to a Samsung Monitor
There is an issue with the vga port on 2006 - 2007 sony vaio laptops. It doesn't push enough power to samsung lcds. There are all sorts of complicated solutions suggested by all sorts of people. Don't waste your time. Get yourself a connection cable with gold contacts and you'll be straight. It costs approx. $33.99. I got this one and it works fine (and I have a weak-*** TZ):
http://www.circuitcity.com/ssm/Nexxtech-VGA-SVGA-Monitor-Cable-6-N6VGASVGA/sem/rpsm/oid/192558/catOid/0/rpem/ccd/productDetail.do
Bulk Life
Identifying the correct lamp code
Before placing an order online, you must identify which lamp code you need. The lamp code is located usually on the left side of the TV
http://fixyourdlp.com/blog/?cat=4
Samsung hlr4266wx dlp tv shuts off
This tv usually if detects a fault will display via leds a error flash code. Refer to Owners manual for What the codes are for. If you go to Samsung Website Copy and paste link for manual.
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=televisions&group_cd=&type=televisions&type_cd=02010000&subtype=dlptv&subtype_cd=02010300&model_nm=HLR4266W&dType=D&vType=R&mType=&model_cd=&menu=download&prd_ia_cd=02010300&acc_ia_fl=N&disp_nm=HL-R4266W
Problem may be lamp is failing or ballast which operates lamp may be Bad. Could also be Temperature fault from Inoperable fan or Color wheel. Bulb of course is first choice of possible problem followed by color wheel then ballast. Color wheels usually will start making bearing noise when they start to fail. Hope this helps.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
