Question about Toshiba TZ50V61 50" Rear Projection Television
Picture problem Right side of the TV picture looks fine, but but the left side is fuzzy. All the words, pictures shown of the left side are outlined in green and purple. It is like they are overliad or something and not lined up correctly anymore. You see two of everything in green and purple.We have had the TV for about 9 years and it has worked fine until today.
I have the exact same problem a month ago. I replaced the two STK392-110 ICs with the STK392-110T adn everything went back to the way it was.
Posted on Aug 06, 2008
Half of tv screen is fuzzy
t-con board has failed on the back of the screen. its fitted to the screen rear panel. replace with same part number and version number.
Feb 02, 2018 | Televison & Video
How do I set time and date
To set the clock, have good batteries in. Slide the selector to Setup (middle setting).
Push the large right button marked MENU.
Push one of the right side buttons, above the word SHOT, these are the right > and left < buttons. Push repeatedly until you see
Set Mode
Set Clock
Set where the last Set should be outlined in dark. Now push the OK button which is the large left button.
Choose the field to update with the right side buttons > or <, once you have the one to update, use the left side up and down buttons to change the value shown until it is correct. Choose the next field with the right side < or >, update the value with the left side buttons. Only when you are completed with updating all of the date and time values, do you hit OK to set them all.
After this all pictures will have the correct time available. Though you have to choose in one of the other menus whether to show the timestamp on the picture. The picture will have the date and time associated with the file when you take the card out to view it later.
Jul 02, 2015 | Simmons 119422C ProHunter Trail Cam 6mp...
The left half of the picture has gotten blurry, with pink, green outlining what seems like 3 different pictures of the same thing. The left half works fine and the HD of direct TV is good on that side. I...
The tv have a problems known as a tv convergence pictures problems,it is dead.Tv set have any colors lines like R,G,B mis alingnments,have colors shadows pictures or a 3D pictures look alike?Yes,than the tv set convergence board it is dead to causes all these pictures problems.The tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set covergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Sony KP-65WS510 65" Rear Projection...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
LG 50PX1D Plasma TV with dark and fuzzy picture
Z-Sustain PCB will cure it.
It is inside the TV, on the Right Hand Side.
www.chsinteractive.co.uk or Google for a replacement.
Sep 08, 2009 | LG 50PX1D 50 in. Plasma Television
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
RCA P60752EBLG1 Convergence Problem
If you wish to get some details; visit the site linked here. Pull up older posts.
Convergence adjustment to projection TVs are given.
Apr 24, 2017 | Televison & Video
Poor digital picture Toshiba ZP38 TV
Hi. Sounds like DRY JOINTS WITHIN DFS MODULE. This is a pcb within a rectangular metal screened box on the left hand side of set when looking from the front. Will need resoldering be carefull very fine print will need decent soldering iron with fine tip & poss magnyfying lamp to aid looking. If your not at all sure take to repair shop. This TV is nice set has one of the best crt pictures you can get.
Sep 05, 2007 | Toshiba 32AF42 32" TV
Toshiba TZ50V61 50" Rear Projection Television Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
