Question about Compaq Pavilion ZT3280US Notebook
Monitor screen The bottom one third of my laptop screen is not working. It either goes black or is jumbled.
You seem to have a bad connection at your video cable. If you can get the get to it simply unplug it and reconnect it
Posted on Jul 01, 2008
Laptop has jumbled horizontal muli-colored lines flickering and rolling, can't see screen
You should try to connect a VGA monitor to your laptop and see what happens. It sounds like a video card failure, and often the hdmi and the VGA are powered by different graphics chips.
If it works with a VGA monitor, try to install a new driver for your graphics card. Otherwise, try a system restore. That often solves your problem.
If a restoration doesn't help, your graphics card is probably broken. Get a new laptop. Avoid Acer :)
Feb 15, 2013 | Acer Aspire Computers & Internet
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
Auxilliary monitor on Dell Latitude D610 laptop goes black.
motherboard and graphics adapter may need replacement
Dec 22, 2009 | Dell Latitude D600 Notebook
Hp 2009m screen goes black - no signal
change frequency setting to 60hz from the option of graphic setting using another monitor then agin connect your problematic monitor.
step1.open properties on desktop using right mouse click.
step 2.goto last tab (setting)
step3.goto advance optinion
step 4.goto third tab(monitor)
and there is option of frequency change it to 60hz save it and press enter.
now shutdown computer then connect your screen goes monitor check it.hope it works.
when screen black its mean the range of signal frequency higher then compatible frequency.
Aug 01, 2009 | Computers & Internet
Replaced LCD Inverter, now screen comes on and bright but choppy
Does the external monitor display a normal image?
If the images is OK then the video card is OK.
The inverter supplies high voltage to the CCFL lamp which provides the backlighing and does not jumble the colors on the screen. If you get a pinkish hue or a flashing screen then this would indicate
the CCFL lamp is faulty.
From the description of the fault, it indicates that the fault could be a faulty video cable or video connector. Try reseating the video cable/connector on the motherboard.
Jul 19, 2009 | Dell Inspiron 6400 Notebook
The bottom third of the screen has turned to black
Possibly the HOT (horizontal output transistor). When this goes out (slowly usually!), the screen gets eaten up by a black hole!
May 21, 2009 | Televison & Video
Jumbled / black screen
Have you run an on line virus scan such as Bit defender, it is free and I came cross this once before and it was a virus that the up to date anti virus in residence had missed. Its worth a try, good luck
Jan 10, 2009 | HP Pavilion dv4000 Notebook
Bottom third of screen went black
Vertical section problem
change all caps in vertical sec and replace vertical IC
Oct 10, 2008 | Dell UltraScan 1000TX 17 in.CRT...
Acer Aspire 5000 Monitor screen; bottom two thirds are unusable
that means your lcd is going south..happens over time..this thing under warranty by chance?
Jun 15, 2008 | Acer Aspire 5100 Notebook
Black screen, White blinking line on bottom of Monitor
During the move was your laptop dropped or bumped ? If so you might of unseated the video adapter from your laptop. Have you tried another monitor? I wouldnt rule the monitor as the problem. Try another monitor. If you have more questions or problems feel free to get back to me and I will do my best to talk you through a solution.
Sep 19, 2007 | Dell E196FP 19" LCD Monitor
Compaq Pavilion ZT3280US Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
