Question about Minolta Office Equipment & Supplies
Minolta dialta malfunction code c0070. toner in correctly but how to reset machine.
  • Minolta Master
  • 5,729 Answers
What is the model see the code C-0070. But what model
Posted on Dec 28, 2014
2 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: My minolta dialta copier has
This code deals with the AIDC or Automatic Image Density Control failure. Most always this code is caused by toner collecting on top of the sensor. If you happen to know how to remove the Imaging Unit and then the Drum from the Imaging Unit then you could clean the sensor yourself. If not then I would recommend you call a service technician to correct the problem.
Basically what is happening is there is a thin mylar seal called the anti-spill mylar which is suppose to keep the toner off of the sensor. But these start to fail over time and allow toner to drop down onto the sensor which results in false readings and the C0F24 code. The mylar must either be replaced or what I do as a field fix is to reform the mylar back to it's like new shape so it seals. Then clean the sensor area of toner then re-install the drum and imaging unit back into the machine.
Good Luck and Thank You for using Fixya.
Posted on Aug 04, 2010
Toshiba e-Studio 456 Error Codes F901
The challenge is with the speed of LGC is not corresponding to the model of the machine installed now try to check it if theres no harness for connecting to the connectors of LGC Board of CN311 and CN316
Jan 09, 2017 | Toshiba Office Equipment & Supplies
Bizhub C250 using to much toner. Images are very dark. Ink can even be rubbed off pages. How do you adjust?
Check that the fuser is not in enevople mode. two green handle up not down. check the files
Oct 28, 2016 | Konica Minolta bizhub C250 All-In-One...
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
I have a donated photocopier for the scout group and it has a code which no-one knows. Speaking to an IT Engineer we should be able to rest to factory settings. We have tried Admin as user name and admin...
Really depends on the model/maker.
Sharp photocopier? try one of those: (note the capital A and S )
Login Name: Administrator
Password: admin
or
Username: admin
Password: Sharp
Oct 02, 2014 | Office Equipment & Supplies
We have forgotten the Administration password for our EStudio 350 & 450. Is there any way of resetting? Thanks Ben
The default password is either 12345 or 123456.
If neither of those work then, turn machine off then power on while pressing the 0 & 8 keys then enter 263, then press Start. It will then display the Admin Password.
Mar 17, 2014 | Toshiba Estudio 200L Copier
Colour cyan not printing
Did all of the packaging come off the toner successfullywhen first installing. Can you see cyan toner on the transfer roller? (Black roller on actusl cartridge)?
Dec 08, 2013 | Office Equipment & Supplies
How to set two sided printing in konica minolta pagepro1390MF
It might be better to place this problem in the computer section.
Oct 17, 2013 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
restart machine ,then press the 0 & 8 keys,enter 263, then press Start. You should see admin password on the screen.
May 05, 2009 | Toshiba Estudio 200L Copier
110 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
