Question about Compaq Computers & Internet
After a system recovery using recovery disks I cannot open anything on the desktop or start menu. System is not locked. Acts like security won't let me in.
  • mnhoward Jul 01, 2008
    This is on a Compaq Presario 7970.
    Problem Solver:
  • 12 Answers
Since this is only a Win98 computer it seemed very suspicious that I couldn't get into anything. I opened a command window (DOS prompt) and by accident found out that was enough to let me open anything else normally. I just added a Command window to the startup file to make it easier. Can't seem to figure out how to get it to close automatically tho'. That would make it a complete fix. Now the only thing that I have to do when it boots is close the command window and everything is normal. How 'bout that!
Posted on Jul 11, 2008
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Aug 26, 2013 | Acer Veriton Z290G Desktop Computer
Tip
How to install Recovery disc on your laptop/computer
Formally, when you purchase a laptop or desktop computer, an operating system disc comes with it. But these days, such disc does not come with most laptop or desktop computer because it is already installed in them which is called recovery disk. This has a great advantage, because if it was on a disc, it will have a scratch and it cannot last forever because it might get lost or damaged. So, having it already installed on your laptop or desktop computer by your computer's manufacturer is a very good idea.
Most people are not aware that this recovery disc is on their laptop or desktop computer. And some might know, but don't know how to use or install it.
A Recovery disk is used to repair windows operating system when it has a virus or when operating system is malfunction. Reinstalling windows with recovery disks helps to recover your computer from any damage.
First, you need to confirm whether your laptop or desktop computer has a recovery disk on it or not. To confirm, click Start Menu, scroll to "My Computer" and click on it. Beside your system's "Local disk (C:)" you should find "RECOVERY (E:)" Click on the recovery disc and you should find a golden padlock with "RECOVERY" in front of this. Also confirm the and make sure it's is a minimum of 6GB.
Now, to install/run your system's recovery disk, go to;"Start menu" > "All Programs" > "Backup & Recovery" > "Recovery Manager". Read and follow instructions and you will definitely perform the recovery successfully.
Lastly, make sure you perform the recovery white your laptop adapter plugged to AC and do not run the recovery on battery. There must not be interruption of any kind in the process of the installation.
Good luck.
on Nov 07, 2010 | Computers & Internet
Trouble with complete restore on eMachines W3619
may be you can try to fix the issue by software, and restore your system by a recovery disk. Windows Boot Genius may be available to you.
Jan 21, 2013 | eMachines W3619 PC Desktop
My acer aspire will not boot can you help
I think the operation system is corrupted and the action to do is press the key specified on screen to get to the boot menu ..and select the recovery partition if you have one ..In this option select to total reinstall the operation system and will work after that .
To engage the recovery if it does not work with the boot menu ..try to see if F11 works ..usually this key is reserved for recovery procedure alone ..
If you do not have a recovery partition you will need a recovery disk and the same procedure Boot from disk and reinstall the system or ..a Boot-able disk with operation system on it to reinstall the system from scratch ..
let me know if you have other issues related with this ..
Dec 21, 2011 | Acer Aspire X3810U1802 (PTSC102005) PC...
I need to reset my laptop. It's locked and i've forgotten the password, and it won't let me get in.
If you are talking about the user password..you have no choice but reinstalling the operation system ...Use the recovery partition if you have one ..or recovery disk ..Or if non of these are a choice ..try with a boot able disk of the operation system ..
the procedure is pretty simple ..with the partition ..if it is present ..just restart he computer and press the F key for boot menu on start ..(its written on the start menu ,,usually is f12 or f11 for hp ) in the boot menu ..choose the recovery partition ..and choose complete reinstall of operation system ..It will bring it to teh factory settings ..
with the disk is a little different ..Insert the disk ..press same boot menu button ..and choose to boot from the disk ..it will ask you to press any key to confirm booting from disk ..and start the procedure..
if you use a operation system boot-able disk ..you proceed like with the recovery disk ..Insert it ..restart ...use the f12 key ..and choose teh cd /dvd as boot device ..and confirm by pressing any key ..and follow instructions ...I suggest to format the C drive before loading the files..(you will have the choice ) ..this way you get rid of any viruses for sure..
You will also need the drivers for it if you use a OS boot-able disk ...so ..download and store them before starting ..
Please ask if you have any questions ..
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Apr 05, 2011 | Compaq Presario CQ50-215NR Notebook
Hp screen wont start up i just get the blue hp screen f10 = start up esc= boot menu f11=system recovery f9 = dignoses when i pree these buttonms nothing happens tried unplugging everything and still...
If pressing F11 ("system recovery") does nothing, then your disk-drive, which contains a "system recovery partition" is inaccessible,
i.e., your disk-drive has failed.
You'll need to buy a new disk-drive, install it, and use the original "System Restore" set of CD/DVD disks to reinstall Windows onto the new disk-drive.
Oct 11, 2010 | HP TouchSmart IQ770 PC Desktop
System locked. need recovery disks.
If you are sure you need recovery disks, you will need your serial number to order them from here:
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
I believe they are around 20$, plus shipping.
Hope this helps.
Jan 27, 2010 | E-Machines eMachines Desktop PC
I NEED A RECOVERY DISC FOR GATEWAY LAP TOP IT HAS WINDOWS VISTA HOME PREMIUM IT IS BRAND NEW I DOWN LOADED A PROGAM IT MESSED IT UP
a lot of computers don't come with a recovery disk.
The System Recovery Options menu in Windows contains several tools that can help you recover Windows from a serious error. You can perform repairs to the files that Windows uses to start itself, perform a restore operation using System Restore, and restore your entire computer and system files using backups that you have made previously.
Note
  • If your computer does not include the System Recovery Options menu, your computer manufacturer might have provided other recovery options. Check the information that came with your computer or go to the manufacturer's website for more information.
  • If your computer has preinstalled recovery options:
    1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
      Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click the arrow next to the Lock button getcontent.aspx?assetid=eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c&documentset=en-us&renderkey=signed1, and then click Restart.
    2. Do one of the following:
      • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
      • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
    3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include the System Recovery Options menu as a preinstalled recovery option.)
    4. Select a keyboard layout, and then click Next.
    5. Select a user name and enter the password, and then click OK.
    6. On the System Recovery Options menu, click a tool to open it.
    7. i hope that this will help you.
Aug 16, 2008 | Gateway Computers & Internet
Emachine T5224
Repeteadly Press F1 during boot. Then at the menu press F8 to go to advanced options. Then select System Recovery, and you can get into the recovery manager to restore the original factory system.
Jul 07, 2008 | E-Machines T2742 PC Desktop
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
