Question about ASUS A7V8X Motherboard
No video Hi I have a HP with this motherboard with all disconnected except for main board I turn it on the fans both work, the keyboard lights up but I get no video. I placed a new video card in the video pci slot on the board and still nothing the monitor show no picture what so ever as if the board lost the Bios. with the memory pulled I have no beeping from the sound so it isn't the memory but it will run on and on as if there was nothing wrong. Check the battery on the board and that was good I figure it is either the board or the chip
  • 983 Answers
If there is problem in bios then you can recover bios by changing the jumper to recovery mode ..
for this you can refer to your motherboard manual ...
due to this you might not getting the video ....
or there may be some problem in the cable of the monitor or pin ...
or the video card might not have placed correctly remove it & reinsert it & then try..
if you still persist the same problem then the IC might have gone which will be near the PCI slot ...
so you just have to contact the motherboard technician & get the IC replaced ...
any doubts you can reply me
i am always here to assist you
thank you
bye
dnt forget to rate my solution
Posted on Jul 02, 2008
Motherboard Power Problem
Hello Alienware,
Could be a few things.... such as the micro-fuses that have gone on the MB....
But what I dont understand is this:...."Then I disconnect the 4-pin cable that goes from the Power Supply to the motherboard near the CPU and the pc turns on fine"
How????
You have just disconnected the cable from the PSU to the motherboard....it CANT turn on! LOL.
Do you mean that the lights turn on?
Or you hear the HD spin up (if you left it connected to the MB that is)?
Please advise so I can help you more.
Nov 11, 2013 | Biostar P4M80-M4 Motherboard
How to clean the fan in my laptop
As with any hardware on your laptop, the fan may stop working. Your laptop's fan serves as the dedicated cooling system for the CPU. If your CPU overheats it will cause severe damage to the motherboard. It may also cause electrical damage hardware devices nearby the CPU. Most HP laptops are designed with CPU fan located on the top side of the motherboard. There are a few HP laptops with the CPU fan located on the bottom side of the motherboard.
Shut down your laptop, and fold down the LCD screen. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Disconnect the AC power cable and any external devices. Place the laptop face down, and rotate the computer so the front opening is facing forward. Locate the battery pack in the upper right or left corner of the laptop. The location depends on your laptop model. Press on the battery's release button, and then lift the battery out of its compartment. Place the laptop face up and open the LCD screen all the way. Insert a flat-head screwdriver into the right side of the keyboard cover. The keyboard cover is a thin strip of plastic situated between the keyboard and LCD. Gently pry the cover from the laptop, and set it aside. Remove the Phillips-head screws located above the top row of keyboard keys. These screws secure the keyboard in place. Grasp the top edge of the keyboard, and then place the keyboard face down over the palm rest area. Disconnect the keyboard's large ribbon cable from the motherboard. Remove the keyboard from the laptop. Locate the small circuit board near the top of the laptop's upper casing above the keyboard compartment. Disconnect the cables from the circuit board. Remove the Phillips-head screws securing the circuit board in place. Close the LCD screen. Place the laptop vertically. Position the laptop with the back of the LCD hinges facing upward. Remove the single Phillips-head screw from the back of each LCD hinge. Place the laptop face up, and open the LCD screen until it is in the 180-degree position. Locate the LCD video cable extending from the left side of the LCD panel. Disconnect the cable from the motherboard. Remove the Phillips-head screws from each LCD hinge. Lift the LCD screen panel off of the laptop. Set it aside. Locate the CD/DVD drive inside the right section of the laptop's upper casing. Remove the Phillips-head screws securing the drive in place. Grasp the face of the drive and slide it out of its compartment. Place the laptop face down. Remove all remaining Phillips-head screws from the bottom casing of the laptop. This includes any screws inside the battery compartment, and on the back panel of the laptop. Flip the laptop over, and remove the remaining Phillips-head screws from the laptop's top casing. Locate the touchpad cable situated just above the touchpad area. Disconnect the cable from the motherboard. Remove the top casing from the laptop's base. Locate the CPU fan in the upper left corner of the motherboard. Remove the Phillips-head screws securing the fan to the motherboard. Disconnect the fan's power cable from its connector on the motherboard. Lift the cooling fan out of the laptop and set it aside. http://www.youtube.com/watch?v=qcy0YSOmX4E How to Clean the Fans on HP DV4 - Overheating This might not be you laptop but it might give you some insight. Hope this helps.
Jan 09, 2013 | Computers & Internet
Hi I have a hp dv7-3173nr laptop,that will turn on with lights but no video on the display or vga,or hdmi ports.The fans runs and the leds light up and that is all.I replaced the motherboard from hp and...
Hi, you better use usb mouse, the one with light at the bottom to see if it is on after you power on you pc. If you did not see the light on, that means the video chip on the motherboard or processor is bad. You have to try 1 memory at the time, then try the processor, if it is still not working, the motherboard is bad.
Dec 17, 2010 | AMD 486542-001 - HP Pavilion DV7 Series...
Hp pavilion a705w. no peripheral response
The fact is *********** board is very likely the matter. See all devices that do not need the motherboard to respond are all working (cd/dvd tray opens and closes, fans are on etc). On the other hand all devices that need the motherboard to respond are not working (keyboard, optical mouse, etc). It is more or less conclusive.
Dec 04, 2009 | Computers & Internet
I have an ACER AM5640 and it does not start. I replaced the power supply but still dead. No PST, no lights on keyboard. Nothing.
hi im rain ok it sounds like you may have a dead motherboard. acers are proned to motherboard failure. if the fan nore the led lights in front of your unit
are not working then you most likely have a dead motherboard. make sure all connections are correctly
seated. if so then your motherboard is most likely the problem. also check the power cord to insure that the cord is not the problem. further more try disconnecting the main power source to the motherboard wait 5 minutes to insure there is no ecsess power left in Motherboard. reconnect the main power connector back to motherboard and try booting up. if this fails then *********** board is the problem.
Nov 14, 2009 | Computers & Internet
No disply of my motherboard plzz help mee.
Good day sir/maam, hi, if your motherboard wont turn on, you need to make sure that these 5 things are in good order. (By the way, disconnect everything except these listed 5.)
  1. (PC is on) Your power supply, make sure that the exhaust fan is spinning as you turn it on.
  2. (PC is off) Your memory module, (ddr1 or ddr2) clean the contacts using an eraser(pencil) the gold plate contacts and a clean brush your motherboard memory slot.
  3. connect the casing's pc speaker on the motherboard.
  4. connect a video card, make sure its good. If you are using the motherboard's VGA, dont connect a video card. Temporarily reset the CMOS, use or locate cmos battery jumper setting. usually its 1&2 set the jumper to 2&3, then back to 1&2. connect a good monitor.
  5. Connect a keyboard.
Now power on your PC, check your Keyboard, you should see two sets of lights: first set (NUM LOCK + CAPS LOCK + SCROLL LOCK) then a few seconds the second set (NUM LOCK only). at this point you should hear a beep from the PC speaker.
If not, you may hear 1 long and 3 short beeps. bad video card. OR continous beeps, bad motherboard.
If you did not hear anything, do it all over again several times.
Still not working? replace your motherboard, its bad.
hope this helps.
Oct 10, 2009 | Dell (E210882) Motherboard
HP Pavilion dv4 not turning on
You must be facing any of these four issues:
1) power issue
2) No POST
3) NO Boot
4) No video
Power issue - the system does not turn on at all. In this case check the AC adapter and the battery.
No POST - You may have to check the Memory, Hard drive and the optical drive. Can also be an issue with the video card2.gif/ key board/ mouse/main board which can prevent the system from turning on.
try reseating all the components above except the motherboard.
No Boot - Issue with the Operating system. Try booting into safe mode and check whether the system turns on perfectly. If so try to uninstall all the software you do not use. and may also consider a system restore2.gif else consider a Dell Complete factory restore.
No video - Try flashing light on the screen and look for the desktop. If you see the icons then probably the back light needs to be changed else the issue is with the display itself or the video card.
Kindly comment with more details about the problem.
Sep 23, 2009 | HP Pavilion dv4000 Notebook
Hi there, I installed a motherboard p4vmm2 and can't get the monitor to get a signal or to get the keyboard to power-on. Any help in this matter would be greatly appreciated. Thanks in advance for all your...
if you cannot get the keyboard to power on, and i assume there are only USB ports on this, means that you cannot work with the BIO settings.
no luck there, return it.
if you can't return it, jumper setting on the motherboard allows you to reset the bios to factory default, if then the USB keyboard still doesnt work, probably a dead board.
Aug 24, 2009 | Computers & Internet
Orange light, no start
Well it could be the power supply, but, first try removing all the cards on the motherboard except the video card (remove and reseat that) assuming the video is no built in. Then turn it on. See what happens. Post back with results
Apr 04, 2009 | HP Pavilion 520w PC Desktop
ASUS A7V8X Motherboard Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
