Question about Sony Cyber-Shot DSC-S500 Digital Camera
Picture comes up with horizontal lines
When I take a picture then view it it comes up with horizontal lines all over the screen but when I take video, the video comes up fine. what is wrong with the camera? Now that we need it the most.
  • Anonymous Sep 28, 2008
    Same problem
    Genius:
  • Sony Master
  • 1,689 Answers
The viewfinder is failing, or it may be a bad flexiboard, or ribbon assy. The proof is that the pictures look okay, but the viewing is not proper.
If you want it serviced, you will have to send the camera to the Sony authorized service rep. They will be able to change the necessary parts and re-adjust as required.
Jerry G.
Posted on Jul 01, 2008
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Photosmart M537 Camera, when I take pictures they show up as a ghost like picture in the view screen, with horizontal lines, but if I take the picture inside it comes out but not real clear.
Try adjusting the Contrast on the on screen menu because it sounds like either the exposire is set too high or if your pictures come out OK when you play them on a computer the contrast is too high.
Hope this helps
Sep 18, 2013 | HP Photosmart M537 Digital Camera
Screen has gone grey and has fine horizontal lines on entire screen. Blue screen is out.
Either the screen voltage to picture tube is more than normal, or the video processor IC has damaged. There is an other possibility that there is no voltage at the video output card, plugged on to the neck of the picture tube. Anyway, your set need a through checkup, and the work is somewhat skilled one. Just check this site. Soemtimes you might get some details about this fault. The fault is called vertical retrace lines. Thin horizontal lines all across the screen with an inch apart. One among the posts published in the following site have details about this fault.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
Nov 23, 2012 | RCA F32672SB 32" TV
Compaq C700 laptop screen shows horizontal lines and the screen seems to be split into several sections
The LCD screen is faulty and will need to be replaced, go to www.ebay.com Type: make and model refine search to screen, first! hook a spare monitor to the video output usually on the back, if picture okay! the above mentioned needs to be changed, but! if both show the same symptom it is the video graphics card that is part of the motherboard.
Apr 19, 2012 | Computers & Internet
Horizontal lines appear in newly saved images
the only thing i can think of is the sensor being misconnected or kaput. are you viewing them on the camera screen or a pc? it could also be camara screen...
Jul 05, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Red vertical lines and horizontal flashing lines on viewing screen plus fuzzy picture.
Its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
LCD screen is black with horizont lines when trying to take photo
U ARE LUCKY !
it is CCD PROBLEM
thousands facing the same see the link but the best part is u can get it repaired free of Cost bcoz it is a manufacturing fault
see the link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Pls rate me FIXYA for help
Mar 27, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Horizontal Lines
your camera needs repairs as the auto apparture system is not working.
Nov 02, 2006 | Canon PowerShot S500 IXUS 500 Digital...
Sony Cyber-Shot DSC-S500 Digital Camera Logo
56 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
