Question about Cell Phones
My LG VX 8550 phone was not working properly so i brouth it into the Verizon store and they replaced it with a new one. My music is downloaded on the memeory card which was placed in th enew phone which is the exact same model. when i tried to play songs an error message comes up saying File Not Supported or Cannot Read.
  • Cell Phones Master
  • 6,487 Answers
You need first to format the memory so it will work with the new phone:
Formatting a memory card - LG Chocolate (VX8550)
This procedure will erase all data on your card. It is recommended that you have a recent backup of your data; unless you are willing to lose it.
  1. With the handset open and from the main screen, press the center of the 5-way navigation pad to choose Menu.
  2. Select Settings & Tools then press the center of the 5-way navigation pad to choose OK.
  3. Select Memory then press the center of the 5-way navigation pad to choose OK.
  4. Select Card Memory then press the center of the 5-way navigation pad to choose OK.
  5. Press the right soft key to choose Options.
  6. Select Format Card then enter the Lock Code for the device.
    The default code is the last 4-digits of the mobile number.
  7. Select Yes then press OK.
Then put the music back in....
Hope that helps..........
Posted on Jul 01, 2008
  • 983 Answers
May be files in the memory card are corrupted or the software which is needed to play the format is not installed ...
if that software is installed then there may be some firmware problem ....
try giving the restore factory settings once if there is any firmware problem it will be solved
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 01, 2008
    first give restore factory settings after that then try to play that ...
    if the same problem persists then the memory card might have got corrupted just try formatting the memory card & inserting the same music again....
    again if you get the same error message then just there is a software missing which must be installed in your phone to play those formats ...
    it might be given in the manufacture cd just have a look in it if so install it & then you will be able to play that.....
    let me know what happens after that
My Verizon LG is stuck on Music Only Mode!
You can try to do a master reset by going to Settings--Security--and Master Reset.(backup your info first!) If that doesn't work you can take the phone into a Verizon store for them to flash the software
Jul 11, 2010 | Verizon Communications LG enV Cell Phone -...
I need to put music on my lg chocolate vx 8550 phone but i dont have the disc can i get some type of free software to put my music on my phone
if you have a memory card then you can get the adaptor you got with it and put it in your computer then drag and drop the music files from your pc to the folder in the memory card
Jan 05, 2010 | LG CHOCOLATE VX8500 Cellular Phone
HOW TO ENABLE JAVA ON LG CHOCOLATE VX-8550
can u help me with my 4 digit cod my phone is a lg chocolatevx8500
Aug 25, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Lg envy music download says no available space
Go to Menu, then under the "Settings & Tools" section, choose option 8 (Memory). Choose option 2 (Phone Memory), then option 1 (Phone Memory Usage). This will tell you the available MB on your phone.
Or, go to Memory, choose option 3 (Card Memory), then Card Memory Usage.
If you have 0MB left on both, then you will need to delete some ringtones, wallpaper, music, etc. to clear up some space.
If you still have room, you will have to take the phone to a Verizon store. More than likely if this is the case, the phone has a glitch in the downloading. You may of downloaded a virus while downloading music/ringtones/wallpaper.
Apr 09, 2009 | LG ENV Cellular Phone
I need to unlock a chocolate vx 8550
i NEED TO UNLOCK MY LG CHOCOLATE VX 8500
Dec 04, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG VX-9700 and bluetooth headset cuts out and choppy
Solution is questionable. Talked to Verizon Tech (Good support) and shortly to Plantronics. Both claimed to know nothing of a problem with the LG Dare and Bluetooth. Went back to the Verizon shop in the Mall to get it checked. We duplicated the problem on both phones and also used their phones (not the VX-9700). So, they are sending two new LGs to us via FedEx. When we came back to pick up the phones, the Tech did some research and did find info (Verizon) and Bluetooth. He did not elaborate.
Also there IS a Firmware Update for the VX-9700 and you must take it in to a Verizon that has a flash machine to upgrade the probably 03 to the latest, 05.
Thanks Also, hope this helps someone else experiencing Bluetooth problems.
Lou
Oct 03, 2008 | Cell Phones
Music not playing on replacement phone.
If you downloaded your music from the internet, you can go to your cell phone provider internet account a re-download again into your cell phone. Customer service can guide you thru.
Artgirl
Jul 02, 2008 | LG CHOCOLATE VX8500 Cellular Phone
I can't hear anyone but they can hear me. Also, the ring on the phone never makes that burr noise to i never know if i have connected to the line Please help thanks
Your phone's Flex cable or speaker is bad. I would bet on the flex cable being the culprit. LG VX 8500/Chocolate has a BAD rep for it's flex cable being inferior. Very common problem for the VX 8500....they fixed that really fast with its replacement, the VX 8550.
Jun 06, 2008 | LG CHOCOLATE VX8500 Cellular Phone
LG vx9900 cdma sofware drivers form pc to cell phone connected.
You may also need the verizon music sync package for that phone, it comes with a cable to connect it to the P.C. The CD will have a program that syncs music. Just install it because the drivers are built into the software and you have to have it installed in order to use the drivers. Once this is installed, download BITPIM ( google it, its free ) or find some other converter program that can convert to 3gpp files for you, then you can creat and add music, ringtones and pictures and convert video file onto the phone for free.
Remember to have the verizon software installed or the PC wont be able to detect your phone.
Good luck
Mar 17, 2008 | LG enV VX9900 Cellular Phone
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
William Alequin
meteshadow
Are you a Cell Phone Expert? Answer questions, earn points and help others
