Question about Whirlpool RBS245PDS Electric Single Oven
Whirlpool oven accubake system
The electricity  went out to my home. When it came back on the key pad said F3. Now nothing works to my oven. Not one button on the key pad will work. But the clock and the light still come on.
  • Anonymous Dec 11, 2008
    My power went out and when came back on the oven said E2 F3 message. Tried shutting the breaker and no help also tried resetting the buttons as well. The fan blower stays on and the upper coil stays hot to the touch even when oven is not on. No problems before this. Any suggestions ?
    Whirpool RB5245PDQ12
I have a whirlpool accubake wall oven. Half-way through baking a pie ,unknown to me, the oven went to the self-clean mode , the door locked and the pie started to burn. I tried to turn the oven off but it would not cut off. I immediately ran to the house's main power and turned off the oven breaker. I waited for a short time to let the oven cool enough to open the door and get the burned pie out, then went back to turn my breaker back on and the oven (even though in the off mode) started heating again with the bottom unit turning red again. I had to then go back and pull the power. We tried this several times trying to push the off button but the oven will not go off until we throw the breaker. Help please!
Posted on Nov 11, 2008
If you haven't already done so, try resetting the braker (turn it off and then back on). If that's not the problem try holding down the reset button until you here the beep.
Posted on Jul 27, 2008
  • timdehoff
    timdehoff Sep 10, 2012
    Hi Jim, can you tell me where the reset button is located?
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
How do I change the temp fro m degrees C to degrees F? I have a Accubake System single oven. Thanks!
From Page 15 of the Manual:
Press and hold the "Custom Broil" pad for 5
seconds. A short tone will sound
NOTE: The temperature display will go off
and the temperatures displayed will
after a conversion. The temperature display
be converted. To switch back to "F, repeat the instructions above.
NOTE: The temperature display will go off after a conversion.The temperature display will reappear the next time you press a cook function command pad.
Jul 16, 2011 | Whirlpool RBS275PD Electric Single Oven
I have an accubake system electric oven and stove. When I tried to set the temperature on the oven the degree number kept rising to 500 degree on its own. Now it is displaying E0 F2 on the screen. Whats...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%$#
Aug 09, 2010 | Whirlpool RBS275PD Electric Single Oven
What does f5 mean on a whirlpool accubake oven?
It either means that the door lock is bad or there is a stuck key on the touch pad.
Jul 24, 2010 | Whirlpool RBS305PDS Electric Single Oven
Just bought a used whirpool accubake sc 465, keep getting E0-f3 error code, any ideas for a good fix?
Hello- The F3 error code indicates an open circuit in the temperature sensor. Pull back cover to access sensor wires.  At room temp the resistance should be 1000-1100ohms. If open, replace sensor. This should solve the problem. Let me know if this info helps- have more if needed. Thanks- Ed
Mar 13, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven doesnt heat, after a few minutes displays error code F3 E2
F3 E2 USUALY IS THE SENSOR IN THE OVEN IF YOUR LUCKY YOU CAN REMOVE THE 2 SCREWS INSIDE AND PULL THE WIRES THROUGH. MAKE SURE YOU UNPLUG IT FIRST.
Jan 12, 2010 | Whirlpool RBS275PD Electric Single Oven
Whirlpool accubake self clean oven. Error code(s) E2 - F3?
You can get all the codes here.
F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control.
http://www.repairclinic.com/0078.asp#Westinghouse
Good Luck and Please Rate FixYa!
Jan 07, 2009 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool RBS245PDS Electric Single Oven Logo
1,772 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
