Question about RCA Lands Phones
My new RCA Model 25205RE1-1 1815MO does not want to record a OGA. It appears to be recording as it so states and counts the seconds as you are speaking. I press EXIT and the OGA is not played automatically as the manual says it would. Furthermore when going to playback the OGA is reported as empty.
The RCA Manual in incorrect. Step 8 reads "Press Set/Save to start recording. Speak within 6 inches away from the Mic located under SPEAKER button." Step 9 reads "Press EXIT to stop recording." Step 10 reads "The OGA is played automatically for your verification. It will then return to the OGA REC menu to start over or to record another OGA."
Step 9 should read "Press Set/Save to stop recording and the OGA is played automatically for your verification."
Step 10 should read "Press EXIT if recording is acceptable. Press Set/Save if you want to re-record."
By following the Manual you never save your message. "Playback" always has the Default message that comes on the machine. Furthermore, Customer Service at 310-953-9028 doesn't have a clue.
Posted on Jul 02, 2008
How do I record an outgoing message for my RCA 25250 Answering System?
Call your number from that phone you should record that way from the prompts
Jan 22, 2015 | RCA Lands Phones
I miss a few words...how do I back it up to get to that spot. When I try it...it goes all the way to the beginning. Very frustrating. Thank You.
Hello I think what you want is to over record on a top of the previous dictation, but this recorder does not work that way example: let say that you are counting 12345678910 and you want to correct and add ACBD between 5 6 to listen back 12345ABCD678910. This recorder don't work that way, the only feature that this unit have is add or insert to the end, on the file that you are listen. During playback press REC for more than 1 second the record indicator appears and "ADD" will flash for 3 seconds in the display window the indicator will turn red and the new recording will be added at the end to the current message.
I really recommend if you want to used a Digital Recorder like the old style analog recorder with a slide switch this unit is really easy to operate and all the features that anyone needs, I think the price is not bad, is really a professional digital recorder http://www.tvps.com/Products/Philips-9380-Pocket-Memo-Digital-Recorder---New-LFH-9380__PH-LFH-9380.aspx
Apr 19, 2011 | Sony ICDB600 Digital Voice Recorder
I can record an OGA, but when people call they get the automated default message. How can I set the OGA so that it replaces the default message?
Once you record your own message, it replaces the default one. If callers are still getting a different announcement, it's likely they aren't ever reaching your machine. Make sure that your telephone line voicemail service isn't picking up the calls instead. I've known several people with this same trouble, and they needed to modify their home voicemail (or whatever your service provider calls theirs) settings or turn it off. Then their phone answering machines worked properly.
Jan 01, 2011 | RCA 25250RE1 2-Line Cordless Phone
My rca cdrw120 2 disc cd recorder does not play or record any cds. what's wrong?
firstly call customer service to see if here are updates on this unit, else, there are two possibilities, the mechanism-which you can easily identify if the cd is spinning at all. the second is that a new optic assembly is required.the first you can do,easily; the second you can research before putting money into it.
Mar 04, 2010 | RCA CDRW120 2-Disc CD Recorder
Need setup help for ep5962
first set day and time... menu, mailboxes, set day/time, scroll to day, set, select, ok... then scroll to current time, set, dial pad four digits, 2 for am or 7 for pm, select save. now power on line 1 or 2 or both. phone is preprogrammed with 'hello, please leave a message after the tone.' to record your own use menu, mailboxes, select setup 1 or 2, then review/chng oga, then record new oga, then ok. record when screen changes, choose stop when you're done. shortcut: press and hold record, press and release mailbox line x, release when finished. you only record one line at a time, so you can have different messages on each line. even if it's the same, you must record each line. since you can only record one message the shortcut would be useful for an 'out to lunch, be back about 1-30' sort of message. then re-record a standard message when you get back from lunch. 'course, you really don't need an 'out to lunch' message, since people are accustomed to answering machines at any time of day. all the caller needs to know is that 'i can't get to the phone right now.' and they appreciate it when you keep it short.
Mar 05, 2009 | AT&T EP5962 5.8 GHz Corded / Cordless...
Unit will not record DVD's
remove cover clean burner eye a little toilet paper,put a little grease on linear bearings, very little using a toothpic use verbatim dvd rw discs from cdw inc. 1x4 speed
Jan 22, 2009 | RCA DRC8300N DVD Recorder/VCR
RCA 25205 wont answer correctly
Yeah, I've wasted all morning messing with this. My personal outgoing message keeps reverting back to default. I just got off the phone with RCA and here's the fix for that part of the problem. Go into "Configure Out-Going Announcement" (page 23) and then select "personal," This finally made it stay there. The number I called for help is 1-800-511-3180, or 1-866-285-4651. Good luck!
Oct 27, 2008 | RCA 25205RE1 Phone
RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
Aug 07, 2008 | RCA 25205RE1 Phone
Change message
oga recording shortcut... press and hold record... press and release line 1 or 2... release record when finished. or use the menu screens to get to record and playback oga.
Feb 21, 2008 | AT&T EP5962 5.8 GHz Corded / Cordless...
Lands Phones Logo
345 people viewed this question
Top RCA Lands Phones Experts
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
