Question about LG Electronics LRM-519 Digital Media Recorder
Where is the litlle black button
I have my cover off and I don't see a reset button.
  • xjnation May 11, 2010
    There are 2 buttons, very small about in the center if I remember correctly. No words or directions or anything else. I'm not even sure if they really are reset buttons or not but they "reset" mine when I pushed them. Thats about all I can tell you. Good luck. Tim
Not sure if this works - need to try it myself (I can no longer download the program guide). But I found this possible solution on another site - good luck:
Here is how to reset your DVR to factory settings:
To reset your own settings (such as ZIP code or phone number), press
and hold (Play) and (Stop) at the same time on the front of the
Recorder until the Recorder restarts.
Posted on Jul 09, 2008
How i reset iptime n504
there must be a litlle hole backside, and a button inside hole... Must press it to reset
Apr 22, 2014 | Computers & Internet
No power in in my kd-r400 car audio
It looks like to me that it went into the protect mode, There shoul be a reset on it some where, bit before you look for a reset, Check that none of the speaker wires come off.
Nov 03, 2012 | Car Audio & Video
Makita MAC700 pressure switch won't power on?
Pressure switches do not have reset buttons built in. The reset button is usually attached to the frame or cover and marked with amp rating. The pressure switch only responds to pressure in the tank. There is however a switch incorporated in the cover or on one side of the switch. Usually a red button that you pull, red or black switch/knob/lever to turn on top or side. If on/off switch broke off in the off postion, the compressor will act as yours does. Try to find a picture of your switch on ebay using the brand name or shape /look and determine where the switch should be positioned. If the switch is broken or fallen off /lost, replace the pressure switch with generic. Usually about $18. Pay attention to port size, number of ports and pressure cut-out. Good luck
Jun 10, 2012 | Makita MAC700 2.0 HP Air Compressor
We bought a house with this lock and don't know how to cancel the previous code and start a new one. We don't know how many digits to put in for the code.
To change your code:
1. Remove the inner cover plate from the lock.
2. Locate the small round reset button near the left side of the circuit board (Red or Black).
3. To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
4. To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
hope this helps
John
Sep 16, 2011 | Weiser Lock Powerbolt 1000 Lock
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I just changed the oil in my vue and don't know how to reset the change oil light
If you open the hood and pull the fuse panel cover. With the ignition switched on (key on, engine off), press the red button in the underhood fuse panel for at least 5 whole seconds. The may flash a few times but then go off. Now you're reset.
Jun 18, 2011 | 2003 Saturn VUE
I have a Canon Pixma MX 330 which I brought with me to the Philippines. A month prior to my departure, I used generic brand of black inks (210). A month after arrival, it started to prompt "error...
Please reset the printer
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Dec 24, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Error 5100 upon intial set up
Reset the printer
Sep 08, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Error 5200
Needs reset
Aug 23, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Canon MP145 printer can not recognise replaced Black cartridge
When you got Error 4 on your printer canon MP145 It’s means one of your cartridge color/black has detected no ink. It happened maybe the printer MP145 is not used for long time. Don’t thinking your Cartridge is damaged. We can not do resetting procedure MP145 to resolve this I have tried it and failed.
When it happened to me I don’ want to go to the service center. We can guest what they say about that “your printer cartridge need to be changed” don’t believe. I go to Search Engine, browse and browse again finally today I found the guide for resolving the canon MP145 Error 4.
how to resolving error 4 on printer canon MP145 Press Reset/Stop Button about 5 second or more until the error 4 disapper. It worked! Save your money for newcartridges.
Jan 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
LG Electronics LRM-519 Digital Media Recorder Logo
253 people viewed this question
Computer Repairing
Computer Repairing
