Printer always prints in red regardless of software used.
Mmm, I think your print head has passed its used by date, but try this.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Posted on Jul 03, 2008
Epson Stylus SX445W printing pictures with a red tint
Dear Kate,
please run the Epson maintenance software and check your printer cartridge.
i think printer head cleaning is the solution.
please run 1 or 2 cleaning cycles and give a try again.
if problem still there its time to go to technician.
regards,
nuwan.
Jan 10, 2014 | Epson Stylus Sx445w Inkjet Print Scan 5760...
Font problem with Epson FX-890 prnter
i am the expert of kyocera mita 6230 or 6330 if any one have problem plz contact with me feel freely ranatayyab786@hotmail.com
Nov 20, 2013 | Epson Fx Office Equipment & Supplies
When printing i get a blanc document in between my printed documents
Hello
If you don't use the printer often (at least once a month) you probably have cartridges drying up on you. If by chance you have an epson or canon, the print head is inside the printer, so regardless of how many new cartridges you put in there, you will encounter the same problem.
If you are using a generic or third party ink, it may be too dense or of low quality clogging your print head.
You can try to run a bunch of print head cleanings. (your manual will tell you how) If by about 8 you are not seeing any improvement start with a new printer. Do a print head cleaning once a month ALWAYS as a preventative measure. This will ensure you get a long life out of your printer, and a top quality print from your cartridges.
Feb 17, 2011 | Office Equipment & Supplies
Page alignment
Hi rene_schuste: This info may help you with your problem.
If you used an older or different HP LaserJet printer driver (printer software) to create the document,
or if the printer Properties settings in the software are different, the page format might change when
you try to print using your new printer driver or settings. To help eliminate this problem, try the
following remedies:
● Create documents and print them using the same printer driver (printer software) and printer
Properties settings regardless of which HP LaserJet printer you use to print them.
● Change the resolution, paper size, font settings, and other settings.
Graphics quality
The graphics settings might be unsuitable for your print job. Check the graphic settings, such as
resolution, in the printer Properties and adjust them as necessary.
Apr 08, 2009 | Office Equipment & Supplies
Printing duplex and legal size.
I don't have legal size paper to test this with so it's a theoretical point but it looks like the printer will not do duplex in anything other than:
  • A4
  • Letter
  • B5 (JIS)
  • Executive
You can always print in duplex manually which is always an option regardless of paper size.
Hope that helps.
Mar 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
I have an old Lexmark Optra S 1620. When attempting to print from my mac os x 10.4 I get a message to load paper, regardless of the amount of paper in the tray, regardless of the program I'm printing from....
did you install the latest printer driver for the MAC?
the following link have the latest driver.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
discontinue use of automatic installation.
use manual installation. meaning go to printer and configure the communication port 1 and install the driver by selecting the correct printer.
Dec 08, 2008 | Office Equipment & Supplies
It prints "RED" pictures
can you give me more info on wot it is doing
Nov 07, 2008 | Epson Stylus C46 InkJet Printer
No RED color; prints brownish shade instead
I had the same problem until i used every cleaning option on the printer about 10 times. It works fine now.
May 18, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Bills are being printed too Long
what driver and software are you using? it sounds like you are printing with a driver that is set to A4/letter, change the paper size to roll.
Aug 18, 2007 | Epson TM-U220 Matrix Printer
Printer doesn't recognize red cartridge
The ink cartridge is either either clogged or running out of ink. Run the software cleaning utility (almost always accessible from the printer) in order to fix a clog. Replace the ink cartridge if the clog cannot be fixed or if the cartridge is almost empty.
Apr 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
136 people viewed this question
jasbo
jasbo
