Question about Labtec 961307-0914 Webcam
Webcam not connecting to yahoo messenger
I cant get my webcam to connect to yahoo messenger. It keeps saying, " Server is busy, close window & try again in a minute".
  • 6 more comments
  • Anonymous Dec 07, 2008
    help me!
  • Anonymous Dec 17, 2008
    my cam showing its working in another program
  • meowhubby Dec 28, 2008
    hi,i'm using Acer laptop with Crystal Eye webcam..the problem is i can see myself when i turned the cam on,i also have set to 'No Proxies'.even turned off my firewall but still getting the same error which is 'Server is busy,pls try again a few minutes later' when i try to broadcast.pls help me...btw,i'm using broadband connection with Huawei E220 modem.thnx in advance.
  • jeri_1112 Jan 04, 2009
    when im trying to connect my cam to yahoo it always says the server is busy close this window and try a little bit later,I also try to go preference and select no proxy when I try it its still the same problem.
  • Anonymous Jan 09, 2009
    sorry, no webcam was found on your system
  • Anonymous Jan 17, 2009
    hi i have the same problem. whenever i try to broadcast my webcam it would always say "server is busy please try again in a few minutes". I have tried the solution advised bout clicking on preferences and connection but it didn't work!!!!!
  • Anonymous Apr 24, 2009
    when i broadcast my cam it says that " the server is busy. pls close the window and try again in a few minutes",.
    maybe in 500 tries i only connect my webcam once,.
  • pal sidhu Oct 05, 2009
    when i try connect it with yahoo messenger, it always showing ur web is not connected
!st, let me explain the problem more clearer, then I'll explain the solution.
Problem) My camera worked fine. Even when logging on to Yahoo messenger, i could still veiw myself when chatting. But when I clicked on the "broadcast" button, the "idle" status would change to "connecting" for a few seconds. Then the the following message would pop up, " The server is busy, Please close this window & try again in a few minutes".
Solution) In Yahoo messenger, click on "Messenger", scroll down & click on "preferences". In Category:, click on "connection". Make sure that "no proxies" is selected.
Posted on Jul 02, 2008
My webcam wont connect to yahoo messenger
Posted on Jan 13, 2009
Whenevr i try to connect my webcam alwys shows server buzy and close the window and try again
Posted on Aug 20, 2010
Try checking the fire wall in your cable or DSL modem. You need to enable TCP port 5100 for inbound and outbound traffic.
Posted on Jul 31, 2009
My web cab not working in yahoo messanger
Dear Sir,
plzz folow this step to solve your problem
Check your webcam hardware here using different software - Hit "allow" in the top window and check the result in the left panel. If you have a reasonable result,move on.
http://www.testmycam.com/
When you come to test your cam in Yahoo later - if you have a blank box - you will know the A4 software failed to load properly.
Configure webcam to Yahoo Messenger.
It's good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, unless the software has a feature for this.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face. ( If not abort configuration and re-load A4 software )
DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make your selections ( who you will allow to view you) > Apply > OK
IN USE
When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( 1 minute) before they see you, so dont be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
There is a shortcut ( webcam icon ) down by your pic as well
Your contacts needs to configure their connection the same as (INTERNET CONNECTION - less webcam reference ) above, or they may get a "webcam not connected" message
If you complete the above and still have problems - check to see if your cam is compatible with Yahoo
YAHOO SPECIFICATION
To find out what the requirements are for messenger webcams, check out the following.
http://help.yahoo.com/l/uk/yahoo/messeng…
I used to get "Server Busy" messages when I was on dial-up, especially at weekends. I guess Yahoo cull all the cams with low bandwidth to preserve server resources when necessary )
You say you have re-installed messenger - I hope you cleaned out the old Messenger folder before downloading - the uninstall software from the Control Panel can leave a lot of software behind to create conflicts.
With Vista, the whole Messenger folder should be deleted on uninstall.
Start > Computer >> Local disk (C) >> Program files >> Yahoo >> Messenger
Thanks For Your Time,
Apr 09, 2010 | Yahoo Messenger
My webcam cannot broadcast. Everytime I activate it, I get the message ''The server is busy. Close the window and try again later.''
I haven't seen that message since I was on dial-up connection, using msn and yahoo messenger - so I think you have a resource problem and operating below the bandwidth for webcam broadcasts.
Since upgrading to broadband 3 years ago its been OK.
Jan 19, 2010 | A4tech PK5
Problem on cam
I used to get this when I was on dial-up but never since going broadband - so the bandwidth may be fragile.
You need to interrogate what is happening when the webcam is transmitting by opening the webcam menu on the webcam frame and click "statistics" Its best to transmit the "small" image and use the zoom 200% when established ( same as sending large photos by email ) - if I go for speed rather than quality on the slider I can achieve 5-6 frames per second ( small size) but I normally transmit about 1-2 f/s.
I have my webcam under VFW (video for windows) control as I used to get freeze problems. This involves a registry change - detailed in Messenger help
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamfix.html
You can tell when its under VFW control because VFW will be on the bottom of the Statistics box. You may need a little bit of software to make it work, if like me you do not have Directx on your pc - if so download the software featured here.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstatestcamie.html
Dont worry about using the proxy server in "Connections" - Use it when you have to - I had to use it today to make my my webcam work - I also had to increase my virtual memory but that was as a result of error messages
Aug 12, 2009 | Labtec 961307-0914 Webcam
"SERVER IS BUSY, TRY AGAIN IN A FEW MINUTES" Broadcasting problem
theres no problem in your webcam but definitely you have a problem in your messenger. try re installing the messenger, will surely work.
Jul 15, 2009 | Labtec 961307-0914 Webcam
make sure that you dont have it opened in another window if you do it will say that and also try to update the drivers
Nov 27, 2008 | Computers & Internet
ACER ASPIRE 4730Z
uninstall yahoo messanger and then try.
install again.
Nov 17, 2008 | Acer Aspire 5610-4648 Notebook
Yahoo mess3nger
hi i am using internet through proxy server my cam is good though i am facing a problem while connecting web cam error  the server is busy. please close the window and try again in a few minutes.
Jan 26, 2008 | Yahoo YHT-630 System
Acer crystal eye webcam cant use in yahoo messenger
Image Size not Supported By Webcam ...Then Later On It Says Webcam Not Found ....In Yahoo Messenger Can Anybody Fix it up
Dec 15, 2007 | Acer Aspire 5610-4648 Notebook
Will not work with yahoo
My Lifecam vx- 1000 wasn't working on Yahoo messenger initially. After hours of researching i came across the solution that worked for me.
In "properties" limit the USB bandwidth used - by unchecking "Auto" in configuration and decreasing the speed manually (bring it down from 6mbps to 3).
This is what worked for me, hope this helps!
Oct 10, 2007 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
Labtec 961307-0914 Webcam Logo
11,909 people viewed this question
Top Labtec Computers & Internet Experts
micky dee
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
