Kenwood KDC-215S CD Player Logo
Posted on Jul 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio issues the radio is just static no matter what i do to it. there is some background noise on some stations but thats about it. cds work fine.
Jerry Greenberg
Level 3:
Genius:
  • Kenwood Master 1,691 Answers
  • Posted on Jul 01, 2008
Jerry Greenberg
Kenwood Master
Level 3:
Genius:
Answers
1691
Questions
Helped
736122
Points
3767
The tuner secton has defective components. It is servicable by an experienced tech who is familiar with the model and has the setup to troubleshoot and service it.
Considering the cost of service compared to replacement, I would think it would be best to replace the unit rather than invest in to servicing it.
Jerry G.
Why do radio stations have static?
Why are all my radio stations static? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Feb 20, 2014 - on all of the radio stations in my car, there's a static background noise. no ... It sounds like the receiver has lost it's sensitivity. either that, or the ... Why am i still getting static on my radio?
Sep 16, 2013
Why are all my preset radio stations static?
Sep 3, 2012
Why do AM radio stations have so much interference and static ...
Jul 2, 2009
My car radio makes so much static noise with engine running, but ...
Jan 17, 2007
More results from answers.yahoo.com
1helpful
Sat nav and radio not working
Good Afternoon Michael
Sounds most likely to be an antenna issue. Most everything going into the radio needs an antenna to be picked up. Sometimes, a station or two might still be heard above the static if they are local and fairly strong signals.
If you can get normal sound from other inputs, like MP3 players or CDs, then the amp and output parts of the unit are fine, and it's an issue of getting an input signal to use.
If you have the tools, pull the stereo head unit from the dash and make sure the antenna input cable(s) are firmly in place. Likewise, depending on location, you can likely get to the base of the external antenna, where the other end of the cable plugs in, and make sure it's in snugly.
lacking the tools - you can talk to your dealer or a local car audio place. They'll likely have the tools, and a check for antenna cable connection would not likely be too expensive or time-intensive.
Good Luck!
Honda radio stopped working but still has power
Check the antenna cable where it connects to the antenna. If that is good, it may be time for a new unit.
My Radio dont work.....It plays dvds,cds just fine
has the radio ever worked since you had it put in? There is a chance that either the installers never reconnected your antenna, or it wasnt seated all the way and finally wiggled loose. Could also be mute wires are wired wrong.
2answers
I noticed static on fm station on my radio. the
i would get the alternator checked, sounds like its leaking ac current which can also kill the battery
Excessive static on am stations when engine is running
two types of noise accur on radio's first is known as a whine,, goes up and down with engine rpm secound is static...normally static is from bad plug wire or plug... you probably have coil packs.. one of them could be arcing.. check it out in the dark of night and look for the spark light. most time good tune up fixes let me know
2007 Chrysler 300 , AM radio not working , but FM works fine
Usually when you lose only AM it is an antenna issue. Check for a loose antenna plug on the back of the radio or connection to the antenna.
Degen DE1103 background tone
the background tone is due to frequency static...the design of the stereo is not good... it lack of noise destortion cirquit..and almost all stereo that is analog usually poor in in design..change the stereo.try stereo that is digital in design..
AM static
the easiest way would be to move the radio farther away from the furnace.
3answers
Excessive static on AM stations. Waves in and out. Not so on car radio. Is there an antenna to eliminate this?
Turn on the radio and turn the AM/SW BAND switch to the AM position. MW appears in the display. Use the outer ‘fast’ tuning knob to find stations, fine tuning with the inner ‘slow’ knob
when needed.
• If there is interference from adjacent stations, place the BAND WIDTH control in the NARROW position. If there is no interference, leave it in the WIDE position.
• If there is excess background noise, turn on
the SW LPF switch, which may minimize the noise.
• If a station is so strong that audio distortion occurs, reduce the gain level with the AM/SW RF GAIN control knob by turning it counterclockwise.
• The telescopic antenna does not have to be extended for AM reception. The radio has an internal, directional, ferrite-bar antenna for AM reception.
• To optimize AM reception, swivel the radio until maximum signal strength is achieved.
All of that being said: It's very tough nowadays to receive AM in this 2008 electronic world. If your able install a longwire SW antenna outside, and have access to a good earth ground, you can boost the AM signals and beat the noise being generated all around you.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
