Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony wega k - 50inch flat screen
I have light brown spots on the screen, a damp cloth wont wipe it clean. what should i use?
  • kelog Jul 01, 2008
    my three year old wega 50inch tv . shows light brown spots , that look like dirt clouds, if i watch golf and they show the sky it's most noticable. i took a damp cloth and wiped the front of the screen down, that did nothing. what should i use or is it inside the t.v.?
  • Sony Master
  • 5,568 Answers
Since the lens plastic is not tough to damage, I wouldn't use anything more harsh than a window cleaner such as Windex or similar.
Depending on the circulation of the air inside from the fan, there could be spots on the inside.
By viewing them from an angle with a flashlight, you may be able to see if they are in- or outside the lens.
If inside, you will have some panel removal to do.
Posted on Jul 01, 2008
How to Clean a Flat Screen TV?
Use a screen cleaning solution, very cheap little canister of anti static spray and usually comes with lint free cloth for light polishing.
Couple of quick squirts of solution then very gently wipe over the whole screen until all the dust has been absorbed and the wet streaks evaporate.
Don't need to go mad scrubbing, just light polishing.
A damp cloth is just as good but only damp and not dripping water, just wipe over screen. The only problem with that is it leaves streaks so just wipe over with a dry kitchen towel or something similar.
Oct 19, 2016 | Televison & Video
Tip
PC Tools- How to clean your computer
  • Cleaning the Computer
If you've noticed that your computer's keyboard feels sticky or the monitor screen appears spotted under the light, it's time to clean these pieces before internal damage occurs. Cleaning your computer's keyboard does not require special knowledge or skill. But you should take precautions to avoid damaging the internal parts when caring for the external hardware.mike_alozie_0.gif
1. Unplug the computer and all accessories before getting started. Anytime you attempt to clean an electric appliance it is important to disconnect the power source to reduce the risk of electrocution or shock. After unplugging the keyboard and monitor, along with any accessories that may be plugged in, use a damp clean cloth to wipe all the cords that are connected to the monitor and keyboard and remove dust balls or hair, along with anything else that might cling to them.
2. Move the computer monitor and keypad to one side of the desk and wipe the area clean where the equipment usually sits. Be sure to wipe a large parameter around the monitor area and let it air dry completely before returning the keypad to that area. You might want to use a clean towel or dry cloth to rub over the desk to be certain it is dry, as dampness can damage the machinery or cause it to stick to the table's surface.
3. Rinse the damp cloth in clear hot water and wring it nearly dry. Gently wipe the monitor screen, including all the corners, to remove dust and spots. Then wipe the surrounding areas and framework of the monitor, including the indicator lights that show when the system is operating. Don't forget the back of the monitor as well. If you have a laptop computer with a top that folds down and closes, wipe the hinges carefully, using a cotton swab for grooves and the latch. Check the latch to see if it is sticky or closes readily.
4. Next, go over the keyboard with the cloth, lightly rubbing around each key and button. Wipe around the sides of the keyboard, catching the off and on switch and CD player. Then use a cotton swab to ease around the edges of each key and row to retrieve minute amounts of dust and crumbs. Carefully clean around the lights, plug openings, and speakers, as well as other areas of your computer. Check to be sure you are not leaving wet traces on the equipment, as this means your cloth is too damp and should be wrung out more.
5. Allow the machinery to air dry, or use a soft cloth to pat the keyboard and monitor dry. Don't use fabric with lint or that is tough enough to scratch the screen. Reassemble all the cords and parts when you are sure the entire unit is clean and dry.
Plan to clean the keyboard and monitor every month or two. You may want to schedule maintenance for an interior cleaning once or twice a year. A clean computer is more likely to work well and last longer.
on Apr 25, 2011 | Computers & Internet
What's the best way to clean a tv screen
Mild soap and water with a microfiber cloth with TV off. Then I wipe only water on the cloth to remove any residue then quickly dry with a dry microfiber cloth.
Sep 06, 2014 | Televison & Video
Suggest method to clean any flat screen tv
Lightly wipe with a clean damp cloth, the best is microfiber or similar. Cleaning solution not needed, unless very light. Don't use harsh cleaning products, they may scratch the viewing surface.
Jan 06, 2013 | Televison & Video
My son took a baby wipe to the LCD tv screen and now there is a purple streak I tried a damp soft cloth but that didn't work any suggestions how to clean the baby wipe off?
Try a 50/50 solution of water/rubbing alcohol and a micofiber cloth. DO NOT SPRAY THE SOLUTION ON THE SCREEN ITSELF but on the cloth then wipe down the screen. I hope the screen isn't damaged !!!
Sep 22, 2012 | Televison & Video
How to clean a plasma
Warm soapy water with mild detergent (like dish soap) on a damp cloth, then rinse with a clean water dampened cloth.
Apr 30, 2012 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
How do I clean the monitor? my cat has put nose prints all over it, and when I attempt to wipe it off (turned off, of course) I still cannot get it clean.
The best way to clean an LCD monitor is to take a lint free cloth and spray it with Windex or vinegar and water solution, or in a severe case, summer windshield washer fluid (the kind meant to remove insect guts). Make sure the cloth is DAMP, not WET (we don't want anything dripping out of it) and wipe the screen thoroughly.
Dry with another lint free cloth while the screen is still damp.
Jul 17, 2011 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
How do you properly clean a sony bravia lcd tv?
as to cleaning on the back with the air louvers take a canister vacum with the brush attachment and make sure set is off and run the brush over the louvers to extract the dust
as to cabinet a damp micro fiber cloth not wet but just damp
and for the screen they have special wipes in a soloution at the at your dept stores for cleaning that part
Oct 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Samsung LCD screen cleaning technique
Hard crusties? what do you do to have this type of matter on the screen?
Be carful with what you use on the screen, a damp cloth is permissable. This does not mean spraying liquid directly on the screen and wiping it
Spray into the cloth or dampen cloth and wring out well. Do not let any excess water drip down the screen especially if it gets into the TV via the outer frame around the screen.otherwise poof it will never work again
please rate our help to keep the service online
Aug 18, 2009 | Televison & Video
Scratched Finish on Screen While Cleaning
Here are some solutions to consider. Try in an inconspicuous place first.
1) Use a clean WHITE pencil eraser. Yes WHITE pencil eraser. Some people use a pink eraser and then a white eraser over that for faster removal. Wipe residue off with a damp cloth.
2) Use White Petroleum Vaseline Jelly over the stratches. This may have to stay on an hour before wiping off.
3)You may also get commercial LCD scratch removers on the 'net.
An LCD screen should only be cleaned by using a damp(not wet) with water microfine cloth. Never use household cleaners of any kind.
Mar 13, 2009 | Sony Televison & Video
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
166 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
