Sorry, I don't understand just what you mean by "length to start". Length of what - stitch? hem turn-up?
Let us assume you are taking up a hem of a pair of pants. Try them on and put a pin where you want the hem to finish i.e. this will be the bottom of the pants. Take pants off, turn them inside out (careful that your pin does not fall out!) and fold the excess pants on that pin mark. The excess fabric should be on the outside, not tucked inside the leg tunnel. Measure how much it is from the existing hem to where you folded it over, let us say for the purposes of this exercise it is 4 inches. Your hem is to be 1 inch and you need 1/2 inch to turn under for a neat finish, total 1 1/2 inches, so you need to cut off 2 1/2 inches from the bottom of each pants leg. Fold 1/2inch at new leg bottom (wrong side of fabric to wrong side), press, fold 1 inch hem same way and press. Place pins every 2inches or so at a right angle to the hem edge. Pins should come out 1/4inch from edge of hem where the 1/2inch neatening fold was made (this is where I wish I could draw a picture!). Fold the hem back inside the leg tunnel. The pins should make the fabric fold under only enough so that 1/4inch of the hem sticks out beyond the pants leg. You will sew on this bit using the blind hem stitch (04 on my 7550). You might need to adjust the stitch width - not length - so that the straight part of the stitch goes along the hem bit and the zig-zag JUST bites into the pants leg fabric.
I do hope this lengthy explanation is of some use to you!
