Question about Carrier Heating & Cooling
Carrier A/C motor needs replaceing: Neet Manual
My Carrier A/C motor needs replaceing and I need a repair/service manual and a new .25 HP motoer with capacitor. Can anyong help??
Thank you,
William Magnuson
  • 1 more comment
  • magnus98 Jul 01, 2008
    It is a Carrier Model 40ES
    When the a/c kicks on, it makes a high pitched noise. but the noise stops after about 2 to 3 minutes-- usually.
    I have a brand new compressor (last year)!! The problem is up in the air handling unit in my attic. I went up there and listened to it. It is coming from the fan motor! What I need is to know where to get a repair/service manual and where to get a Carrier .25 HP motor (provided Carrier's OEM motors are not proprietay) and a standard, generic motor can be used.
    Master:
  • 848 Answers
Give details about the model
Posted on Jul 01, 2008
  • gopinath pasupathy Jul 01, 2008
    there may be some problem with your compressor ............it may be having some short cycle problem
I have proplem with paper jam , so I replaced motoer of model 510 with motor of model 500 . I printed one copy but it didn't complete seccessfully , what should I do ???? The motor of model 510 d
Both Disc encoder & Motor same for 500 & 510... But its not motor fault,
1. Clean Media sensor P/N:C7769-60168
2. Clean disc encoder.
3. Clean drive roller encoder PCB P/no:C7769-60172
Pl share the error message after doing this activity..
Jan 09, 2013 | HP DesignJet 500ps (42 in.) InkJet Printer
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Need a free service or repair manual for a 20 hp mercury outboard
what u need to know i am the 20/25 merc man 20 years on 20/25 mercks
Oct 25, 2011 | Light Outboard Motor Boat Bass Fishing...
I keep getting an error message (B200) on my MP620. Any ideas about how to fix this?
Print head failure. All you can do is to remove the cartridges, flip up the securing lever and extract the print head assembly from the carrier then clean its contact and the pins on the carrier. If that doesn't fixes it then either the data ribbon cable that connects the carrier to the board or the processor are damaged. In both cases the repair will cost more than a new printer so it's time for a new one.
Sep 29, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Need service manual
I don't have a service manual but would be more than happy to answer any questions about service you may have.
Mar 09, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
Need to replace back half of a.o smith pool motoer
Do you mean A.O. Smith motor? This is the back half of
the Pool Pump. A.O. Smith motors are the most common motor drive for household pumps, so I believe
that you can easily find the replacement. Just specify
the horsepower (HP) rating, voltage: 220/110, single
phase or three phase. Just send your e-mail comment
for more info. God bless you.
Oct 21, 2009 | A.O. Smith SQ1102 Pool Pump Motor
Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Jun 15, 2009 | Boating
Ranger 6900f-25 has no output
either the transmitter is grossly out of alignment or one or more of the new parts are already defective.
power = voltage X current. it's usually what happens when someone attempts to repair a piece of equipment like this by "swapping parts" while not in posession of the necessary test equipment and technical expertise.
May 16, 2009 | Galaxy Radios DX-95T Base CB Radio
98 forester blows oil 2.5
You have a problem with a gasket, basically the gasket on the head of valves, then you only have to change the gasket, this a common problem when the gasket is broke or burned.
Sep 20, 2008 | 2006 Subaru Forester
Heating & Cooling Logo
139 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
