Question about Frigidaire GLRS237ZA Side by Side Refrigerator
Frigidaire Gallery - ice maker not working
The water was not working for a while and then the ice maker stopped working. So we replaced both water valves and now the water is flowing great and it is cold. But the icemaker is not making any ice. I don't hear the water loading into the icemaker either. What do we do next?
  • 3 more comments
  • Anonymous Jul 12, 2008
    valve are good waterdispenser works fine filter new but will not make ice
  • Anonymous Jul 27, 2008
    my ice maker is not working properly either. Whenever I have company and use up all the ice in the bend, it takes several days to refill. It does not sound like water is being filtered through properly. I have checked and the ice lever is in the proper place.
  • jolinG45 Aug 16, 2008
    The water works fine, but slow. The ice maker just stopped completely. Any help fixing it myself..?
  • radtoy99 Oct 04, 2008
    Ice maker just stopped working. The lever is in the correct position and I hear the switch make contact when I push it down. The water is just not getting into the area to make ice. Please help.
  • Anonymous Nov 17, 2008
    I have the same issue. But with mine, it'll stop working for a month or so, then work fine for a month or so, then back to not working.
  • 1073 Answers
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
catriver
  • 878 Answers
SOURCE: My subZero Model 245 Icemaker stopped making ice
Ice maker, I don't know where you can find the manual but I'll give you a few ideas of what to look for. First make sure that the inlet tube is not frozen over. Next, look at the center gear on the module and see if the clips in the center are not broken. If so you will have to replace the module. The ejector blades should be at the 2:00 position when home. If you get a jumper wire and jump T to H, this will by pass the bi-metal and run a cycle. The ice maker should fill at around the 12:00 position. Test points L & N will verify if you have 120v to the ice-maker. Test points L & H will test the resistance of the heater, 72 ohms. plus or minus 10%. Hope this gets you going, Catriver...post back.
Posted on Aug 21, 2006
  • 43 Answers
SOURCE: the Frigidaire Gallery freezer has ice build up restricting air flow
#1. DEFROST TIMER stuck or defective. Not allowing DEFROST CYCLE to occur. Most probable.
#2. THERMOSTAT (cold control) has gone bad.
#3. CIRCULATING FAN. It pulls air from the FREEZER side into the REFRIGERATED side.
#4. and lowest in probability. LOW (leaking) coolant charge.
Posted on Mar 09, 2008
22yooper
  • 828 Answers
SOURCE: frigidaire water leaks
I suspect that when the water valve was replaced, that the plug's were reversed that provide the power to the valve. Exchange the two plugs on the water valve and you may find the problem is fixed.
Posted on May 26, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Professional Series - FRS26ZSH My ice and water maker have stopped working. First the water stopped then about 5 days later the ice maker stopped.
you will need to replace the water inlet valve, this runs your water and ice,, before you replace it take your water line off and hold it in a pot, then have someone turn the water back on , this will let you know for sure you are getting water to the valve,, if no water comes out then you have a water line prob,, have that fixed then hook it back up and turn it on, then you will need to run the water for about 2 -3 minutes to purge the air out of the line,,, if you rplace the valve you will need to purge also
Jan 19, 2011 | Frigidaire FRS3R5EMB Side by Side...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire GLRS237ZA Side by Side Refrigerator Logo
2,810 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
